Question about Garden
I replaced the blade belt and replaced the deck exactly the way I removed it. Now the belts will not engage?:~(
Peuhayd
  • 11 Answers
SOURCE: removing tractor deck to change belt and blades?
if i am thinking of the right model you may be able to get away with first taking off the blade, then to remove the deck should be a number of bolts under the chassis and on top of the deck where it meets the frame... you can get your parts here if your having trouble finding them
 http://www.ordertree.com/modelinfo/MTD/13A1674G401-%281997%29/62.13A1674G401-%281997%29.1.1.1.html
Posted on Sep 06, 2008
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 1111 Answers
SOURCE: G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Posted on Aug 07, 2009
SOURCE: My Yard Machines MTD blade won't engage
My mtd 20 hp mower, blade will not engage, found a large spring and a small metal piece that came off and I have no Idea where it goes in order to get this blade going again, can some one give me some info Please..
Posted on Aug 12, 2011
Cub cadet ltx1042kw the blades will not engage
Either the pto is not engaging or you missed routed the deck belt. Google your model number and you should get a link where you can see the correct belt routing.
Jul 27, 2016 | Cub Cadet Garden
Why are the blades engaged when mower starts and the handle is in off position?
the belt is routed around both blade pulley rear of belt routed to inside of pully tensioner front of belt routed to moter clutch or or in some cercumstance it is totaly the wrong belt and thats what i think your problem is i think you got to short of a belt
Aug 27, 2014 | Garden
Mower starts and runs beautifully until i try and engage the cutting blade.It smokes badly... doesn't seem the belt is moving. its practically new, just purchased it in July 2013 and only used it three...
Something is jammed under the deck. If the engine runs good until you engage PTO, the problem is in the deck. With engine off, disconnect belt for deck from PTO, then remove deck and flip it over. With belt off try to spin blade. They should spin freely. If not, you have a bad bearing which are fairly simple to replace, just a few bolts. FYI, draw a diagram or take a picture of belt routing before removal, this will be good to refer to for installation of belt when your done. Hope this helps.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 06, 2013 | Ariens Garden
Toro 50" time cutter when engaging blade loud
I would remove the deck and belt, then spin each blade to isolate the loud noise. Also, make sure the blades are not bent hitting the deck. I always balance my blades after sharpening as well. By isolating the bearings spinning them one at a time, this will tell you where your problem lies. Hope this helps!
Aug 10, 2013 | Garden
My MTD riding lawnmower is burning thru the new belts I just purchased.The new belts are 954-0371A which replaces 754-0371A. The old style belt lasted 5 years. Even before engaging the clutch, the belt...
My idea is not about the belts, but is about the deck. If the tensioning mechanism on the deck is getting stuck in an intermittant position than the belt may be just tight enough to turn blades while slipping through the pulleys, this may cause enough friction to start melting your belts. If this is the case you will have to remove your mower deck and see what is preventing the mechanism from functioning properly.
Jul 07, 2011 | MTD LAWN MOWER PART 1909404 BELT
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
