Question about Bosch Washing Machines
What is fault 16 on Bosch Maxx Lifestyle Washing Machine
SOURCE: Bosch Maxx Instruction Manual
F:16 - Doors are not properly closed. Check the doors are closed with no obstacles.
F:17 - Water is not running. Check the tap, hose and filters. Also water pressure can be low.
F:18 - Too much water remaining. Stop the drying program and start Spin program. Otherwise something is bolcking the water exit from the machine.
Posted on Jul 16, 2009
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
SOURCE: i need a manual for my maxx 6 bosch washing
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Go to this link. Just downloaded one for my Maxx7
Posted on Oct 03, 2009
Chesc
  • 59 Answers
SOURCE: Error code F18 for Bosch Maxx 7 Silence washing
F-18 means the pump is blocked.
First checkthe filter for coins or other junks. Make sure the drain hose isn't blocked, restricted or kinked. Make sure there's no obstruction in the drain standpipe or U-bend.
If this doesn't work, might as well change the drain pump assembly. http://www.espares.co.uk/parts?k=pump
Hope it helps. ;)
Thanks for using Fixya. A 4-thumbs up for answering your question is greatly appreciated.
Posted on Jun 04, 2011
ZJLimited
  • 17970 Answers
SOURCE: I Need user manual for Bosch Maxx Lifestyle
I suggest visit this link for Bosch WAE24460AU User Manuals.
Hope this helps (remember to rating this free answer).
Posted on Oct 07, 2011
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Bosch maxx 7 varioperfect
On the bottom front there is a panel, that panel is the 'sump' area. Make sure that is cleaned out so that all water can eject during rinse cycle.
Nov 19, 2013 | Washing Machines
Washing machine won't drain
Bosch maxx 5 washing machine will not drain This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 19, 2012 | Washing Machines
F14 fault on Bosch Maxx 7 I have low water power, could this be the problem? Machine bleeped at me then stopped. I have turned my machine off, but the washing cycle had not finished.
Hello
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
You may need to restart wash cycle.
Apr 06, 2011 | Bosch Washing Machines
Washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
Mar 28, 2010 | Bosch Washing Machines
Bosch Maxx - softener not dispensing into machine
It blocks very often , give it a good clean..remove soap dispenser to do so
Sep 28, 2009 | Washing Machines
I have a bosch maxx Wlf1600 front loader washing machine
This will require a replacement door lock,easy replacement & part very cheap
Jun 08, 2009 | Audiovox Bosch 718 World Cellular Phone
Jan 22, 2008 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
