Question about Grilling
AUGER STOPS RUNNING DURING CYCLE ONE AND NEVER RESTARTS ON GREEN MOUNTAIN GRILL
4 Suggested Answers
Junoon007
  • 1011 Answers
SOURCE: machine stops periodically during cycle..If
Dear Sir/madam,
The lidswitch may be defective. If it is, the washing machine doesn't spin.The switch is inside the washing machine main housing near the doorframe. Often you have to raise or open the top or front of the washingmachine to get to the switch. If it's defective, you need to replaceit.
If the lidswitch is defective, the washing machine may not agitate or function atall. The switch is inside the washing machine main housing near thedoor frame. Often you have to raise or open the top or front of thewashing machine to get to the switch. If it's defective, you need toreplace it.
Details for How to maintenance? etc... Click this link for all information........
http://www.repairclinic.com/0088_11_1.asp#Level2_9
Thanks
good luck
Posted on Aug 23, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Stops running during cycle
Replace the timer and all will work ok. The timer is stuck for some reason, you may be able to clean it out if there is any debris but you are best off just replacing it. 25 dollar or so part
Posted on Feb 09, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite stops during wash cycle
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Green mountain pellet grill doesn't heat up. Put a new igniter in it. Goes from 3 degrees to 85. The auger works and the combustion fan is running. Any idea
Have you cleaned out the burner area. Every so often (especially if you see a lot of ash flying around) you need to take the grills and other deflectors out and vacuum the burner area out. You may be full of ash.
Sep 17, 2017 | Grilling
New tvm63x splendide. Dryer stops and restarts during drying cycle. What could be causing this? Thanks.
Check for a lint build up in the vent hose. Too much will trigger a sensor in the dryer to shut off to prevent a fire.
Nov 19, 2014 | Splendide Washing Machines
Auger on Green mountain grill
Call GMG Customer Service at 1.800.603.3398 and press #2 for Technical Support
Dec 24, 2012 | Grilling
The auger on my 9 yr old grill has stopped and my family is not happy! I do not have a Mr Fix-it husband so am on my own. Any suggestions?
Make sure that there electric power to the auger motor. If it's plugged into an exterior wall outlet, unplug it and plug in another electric device (like a lamp) to make sure that outlet still works. If it doesn't, go to your home's Circuit Breaker Panel and check for a tripped breaker. If you find one that's tripped, reset it and try plugging in the auger motor and turn it on. If it starts working then suddenly stops, it probably tripped the circuit breaker again. That would indicate one of three things: The cord from the auger motor may be bad; the auger motor itself may be shorting out; the circuit breaker may be failing. If it's the receptacle or the circuit breaker, I'd advise you contacting an electrician to have them check and replace it. for the Auger Motor, go to Traeger's website home page and look for Trouble Shooting or Customer Support. Better safe, than sorry.
Hope this helps solve your problem.
Feb 08, 2011 | Traeger Industries BBQ075 All-in-One Grill...
Aggetator not moving during wash cycle, why
Does the agitator have an auger at the top, if so you will need to replace the agitator dogs in the auger section. Part #80040 If no auger is present you probably have a broken motor coupler.Part #285753A
May 18, 2010 | Roper RAS8244LQ Washer
Refrigerator will not defrost
Remove the kick plate grill at base of refrigerator and turn the timer clockwise slow until compressor stops. That should be beginning of the defrost cycle. After a few minutes look inside freezer or listen for crackling or hissing noise. That should indicate defrost. After 25 minutes if it does not restart then turn again until it restarts. Replace defrost timer. Let me know what happens, Thanks Sea Breeze
May 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator is somewhat cold as is the freezer side but the freezer side is not generating freezing temperatures. Same temperature btw the refrigerator & freezer. Model 596.50392001. Any suggestions?
Your refrigerator has a defrost timer located near the floor and behind the kick plate. Remove the kick plate grill and turn the timer slowly clockwise until refrigerator compressor stops running. Leave it there for about 30 minutes or until refrigerator restarts. During this time the refrigerator should be in the defrost cycle. Open the freezer and you will possibly hear a crackling noise or the noise of water sizzling as it drips from the evaporator to the defrost heater. If your refrigerator does not restart after this time then turn the timer again slowly until the compressor restarts. If you do this then the timer will need replaced If no defrost takes place during this time then we need to move to the rear of the freezer and unplug the refrigerator and do some test on the defrost heater. Let me know how this worked out for you. The part number for your defrost timer is 10530703
Thanks, Sea Breeze
Jun 24, 2009 | Kenmore 53642 / 53644 Side by Side...
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
When starting, hear a noise like if the motor has problem rolling. The dryer works but stops during the cycle. Smeling heating after a while. And few minutes later, restarts and works, and stops...
sounds like your motor is on the way out. Hard to start-- when it does go it eventually overheats---- wont restart till cools down. sounds like a motor going bad
Mar 07, 2008 | Dryers
Grilling Logo
122 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
