Question about Cell Phones
BlueParrott B-350XT power problem
Will not hold charge
My blueparrott not taking a charge can any one help me
It is actually very easy to remove the battery on the BlueParrott B250-XT. To remove the earpiece, just pull it out of the socket but be careful not to pull the wire attached to it when you separate it from the body. Next, remove the five screws to access the battery compartment. Disconnect the battery from the board and leave it disconnected for 10 minutes or so. Re-connect the battery and re-assemble. Connect the headset to your charger and after a couple of minutes, it should start charging showing red until fully charged. If it still won't charge, you may have to order a new battery. You can find a replacement battery on EBAY for around 10 dollars. Repeat the battery replacement and check to see if it starts to charge. If it works, you are good to go. If it does no work, you may have to send it to the manufacturer for repair. Good Luck!
Nov 11, 2014 | VXI Corporation Blueparrott B250-XT...
Will not charge
check if the cable is properly plug in. wait for until 5 minutes and see if it's charging. if it's still not charging, it needs a repair.
kindly rate this post and thank you for choosing fixya.
Jan 09, 2012 | VXI Corporation Blueparrott B250-XT...
Have a blue parrot B250. When I unplug the unit from being charged, the lite goes off on the side, and if I hold it down it will not come back on. The unit will not come on anymore, have any solutions.
If you have a B250-XT the first thing we want to check is to make sure the lights haven't been accidently turned off. Hold the headset up to your ear and hold in the Multifunction Button - two rising tones indicates the unit is turning ON, two descending tones indicates the unit is turning OFF. If the unit turns ON, try making a call, while on the call quickly press and release the both the volume up and volume down buttons at the same time, this action turns the indicator lights on and off.
If a Blueparrott will not activate at all there is likely an issue with one of the control circuits and I recommend calling VXi at 800-742-8588 for warranty repair information.
Aug 28, 2011 | VXI Corporation Blueparrott B250-XT...
Doesn't seem to hold a charge anymore. I have not used it in about 6 months.
There may be an issue with one of the control circuits in the unit, I'd recommend calling VXi at 800-742-8588 for repair warranty option information.
Aug 23, 2011 | VXI Corporation Blueparrott B250-XT...
How do you put blue parrott B250--XP in discovery mode.
From the power off position, switch the unit on by holding the function button for 3 seconds. Keep holding the function button until the indicator light on the function button flashes red and blue in an alternating pattern. The unit should now be in discovery mode and ready to pair with another device..
Aug 03, 2010 | VXI Corporation Blueparrott B250-XT...
Cell Phones Logo
51 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
