Question about Samsung LN-R408D 40 in. LCD HDTV
No picture but can hear volume
I can hear the volume but no picutre i tried to disconnect everything and replug everything in then turn the tv on and nothing!
Who can i contact if i am not sure how to reseat these cables
is it worth the money it would cost to have fixed or just to get another tv?
thanks for all your help
  • 67 Answers
Try unplugging the TV cable from the mains and leave it off for a few hours. The longer you leave it disconnected from the mains ( i recommend overnight) the better the chance it will reset the TV.
When you switch the TV on, try pressing the SOURCE button until you get a picture from the cable/sat box or whatever connected to the TV.
If this fails you may have a problem with the power circuit board. This will cost approx £150 for parts and labour from you local TV repair man.
Good Luck
Posted on Jul 27, 2009
When I turn the tv on, I get volume but the screen just flickers.
Sounds like the "display panel" went out. The clicking sound you are hearing is the inverter attempting to make it work. Yikes! If under warranty try contacting manufacturer. If not, it might be less just to replace it. Hope this helps!
Feb 21, 2012 | Televison & Video
I have no sound from my tv
Hi You don't need to use the volume on TV when you have it plugged into an amp/stereo.
also you should not have to turn the tv up to get sound out of. Turn your TV 1/2 way and then use your amp/stereo to crank the volume up.
Jan 02, 2012 | Element ELCHW402 40 in. LCD HDTV
Sanyo DP32648 Volume can barely hear. Tried unhooking the cable box and even hooked up dvd direct and still same problem...nothing wrong in settings either. I am pretty technical and if its a board or...
Here is some things to check/try.
>Go into the sound menu and make sure the TV speaker is turn on.
>Try turning the volume down and see if the volume decreases from the level it is at now.
>You can also try disconnecting at least one speaker and connect a know good one instead. (the ohm must match and the watts should be at least as high). (Maybe a cheap computer speaker). It that works then it the speakers that must be replaced.
Feb 26, 2011 | Sanyo DP32648 32 in. LCD TV
Hey, i bought a DLP Toshiba HDTV off a guy on graigslist, when i went to go pick it up he turned it on by remote and everything worked fine as it should. When i got back to my place I tried turning it on...
These DLP tvs sometime u unplug suddenly and replug it back wright away,tv will go into protective mode and will not work wright away.Tries tv unplug,replug it back about an hour later,now the tv will reset itself back to the factory setting.The tv should work now.
Nov 17, 2010 | Toshiba 65H93 65" Rear Projection...
Picture on TV stuck on one picture
Ok fixed it. Just unplugged the box and plugged it back in and it works fine.
Apr 05, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Freeze up
Most likely it's your memory ic (eprom). Sometimes depending on the make, an authorized service center can flash the eprom back to normal. This is something you can not do but I hope this helps a little.
Feb 22, 2008 | Televison & Video
Sony KV-27S42
If the screen won't come on then the diagnostic will never show. The 4 blinks is an error code. If the set is older than 12 years then it doesn't owe you anything, you got your money's worth out of it. Average life of any tv from that genre is 8-12 years. It's time for a new set, or take it in for an expensive repair ( pending parts availability).
C-Dog
Feb 10, 2008 | Sony KV-27S42 27" TV
Surround sound not working through ordinary tv
Try connecting the red and white audio cords to your system from your cable box/satellite receiver instead of your tv. Worked for me.
Oct 01, 2007 | Audio Players & Recorders
TV-not working
How about the buttons on the side of the tv?? work?? if so the trouble is in the remote: if they don't work either, the trouble is in the set = goose cooked-- sorry
Jun 17, 2007 | iLO 3200 32 in. LCD Television
Samsung LN-R408D 40 in. LCD HDTV Logo
249 people viewed this question
Jerry Greenberg
Jerry Greenberg
