Question about Toys
I have a balaenoptera musculus toy boat I have no power to the motors when comanded with the rods touching. I have already checked all the wires all the antennas are attached both at boat and controller. I do have proper voltage at the circuit board. Any help would be great need to see how to check signal input
freetek
  • 5568 Answers
SOURCE: HEAT/AC blower motor stopped working
It's even odd that you were getting a step-type voltage when you first checked.
Many speed regulators are simple tapped resistors with the switch selecting which tap is connected to the motor.
More elegant controls would use a semiconductor (transistor) and a few other components to supply step-variable voltage to the motor.
To determine which is used on your car, you will at least need the electrical diagram for it, preferably an aftermarket service manual - Haynes or Chilton should be available at least in the US and Canada.
Those will contain not only the electrical info you now lack but possibly instructions that will aid in locating the controlling circuit.
I suspect that circuit is faulty; if the resistor type, it will be a device with mulitple taps, if solid state, a few parts on a small board.
Posted on Jun 18, 2008
SOURCE: I have a Carrier 38tra048340
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Posted on Jun 23, 2008
  • 3 Answers
SOURCE: heat-a/c blower motor stopped
check for ground going to fan. If there is no ground replace a/c control panel located under radio it what you use to turn on the heater/ a/c
Posted on Aug 27, 2008
thabrain
  • 76 Answers
SOURCE: power windows and blower motor
check for inline fuses. wire that will melt if theres to many amps running through it usually under the hood. hope this helps
Posted on Nov 06, 2008
SOURCE: Climate Control Blower motor stopped working
I had the same problem with my 2000 Mercury Grand Marquis. I ended up replacing the blower and the resistor which is on the passenger center side of the firewall tucked in where it is hard to get to. Everything worked fine for about two years. It just went out again here about a month ago. I am going to try to replace the resistor again, but I am wondering if it doesnt have something to do with the climate control switch. I do not want to replace the same part every year or two, so if anyone has a idea of what could possibaly be the bigger problem, please let me know.
Posted on Nov 22, 2008
Info about blue whales
The blue whale (Balaenoptera musculus) is a marine mammal belonging to thebaleen whales (Mysticeti).[3] At 30 metres (98 ft)[4] in length and 170 tonnes (190short tons)[5] or more in weight, it is the largest existing animal and the heaviest that ever existed.[6]
Long and slender, the blue whale's body can be various shades of bluish-grey dorsally and somewhat lighter underneath.[7] There are at least three distinctsubspecies: B. m. musculus of the North Atlantic and North Pacific, B. m. intermedia of the Southern Ocean and B. m. brevicauda (also known as thepygmy blue whale) found in the Indian Ocean and South Pacific Ocean. B. m. indica, found in the Indian Ocean, may be another subspecies. As with other baleen whales, its diet consists almost exclusively of small crustaceans known askrill.[8]
Blue whales were abundant in nearly all the oceans on Earth until the beginning of the twentieth century. For over a century, they were hunted almost toextinction by whalers until protected by the international community in 1966. A 2002 report estimated there were 5,000 to 12,000 blue whales worldwide,[9]located in at least five groups. More recent research into the Pygmy subspecies suggests this may be an underestimate.[10] Before whaling, the largest population was in the Antarctic, numbering approximately 239,000 (range 202,000 to 311,000).[11] There remain only much smaller (around 2,000) concentrations in each of the eastern North Pacific, Antarctic, and Indian Ocean groups. There are two more groups in the North Atlantic, and at least two in theSouthern Hemisphere.
ref: http://en.wikipedia.org/wiki/Blue_whale
Jun 04, 2014 | Computers & Internet
I need to disconnect the shift linkage of a 1983 Johnson outboard motor. I already disconnect at the water inlet. The lower unit still will not come all the way down.
some shift rods unhook midway thru the leg ,others you unhook at the top and the entire rod comes out . caution getting the shift rod lenght the same as when removed is critical or you will have shifting problems.
May 16, 2014 | Boating
Geting no power to the power tilt trim. put 2 new solenoids on and still no power just a cliking. please help.
Connect wires from trim motor straight to battery,see if motor now operates,if it does not then motor is faulty or there is a break in the wires.you do not say what make and hp.
Apr 08, 2014 | Boating
Re-attaching shift rod and tell tale pipe for nissan jas3
Sometimes on these small motors it is easier to do it with power head off,then you can see where pipe is going
Mar 30, 2014 | Light Outboard Motor Boat Bass Fishing...
Toys Logo
23 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
