SOURCE: TOM TOM is frozen
To reset your ONE XL, use a straightened paper clip, or something similar, to
push the reset button. The reset button is next to the memory card slot, on the
bottom of your ONE XL. Then turn your ONE XL on.
If this helps you plz rate this. Thank you kindly.
SOURCE: Tracfone screen says "charge complete", phone won't turn on.
remove battery for a few min. then reinstsll and charge again
SOURCE: Blackberry Storm: My Menu button and end button do not work
This problem happened to me and I just figured out the answer. If you recently installed a new application or a new theme then it will probably mess with your button configurations. Remove the theme/application you installed just before the problem started happening. Once you removed the theme/application convert back to the default theme and your buttons should work again.
SOURCE: won't turn on or charge
Press Mode (bottom left side button) and Reset (left front button) simultaneously, let go, then press On (top left side button).
SOURCE: my htc touch pro wont turn on after being charged all night
Had the same problem. You need new battery! (borrow from friend, if anyone has HTC to test if phone is OK with different battery).
Testimonial: "holy crsp it worked thanx:)"
