Question about Samsung Dryers
Samsung has the manual and a trouble-shooting guide on the product support page: http://www.samsung.com/us/support/owners/product/electric-dryers-dv400ewhd . The direct link to the manual is currently http://downloadcenter.samsung.com/content/UM/201501/20150120165209818/HUDSON_DRY_DV456_DC68-03170A-09_AA.pdf .
Usually if the drum won't tumble, the problem is with the belt, the drum rollers, bearings or shaft that the connect the drum to the motor or the motor.
Can you turn the drum by hand easily? Then look closely at the belt. Replace it if it is damaged. If the drum won't turn, disconnect the belt and check if the drum turns. If it doesn't, check the drum support rollers for wear. Replace all of the support bearings at once if any are faulty. Check the support rollers and shaft at the back of the drum for damage. If you hear a lot of noise as you turn the drum, then the bearings are possibly bad. Check that the plastic slides that stabilize the front of the drum are fine.
Finally check the motor. Replace this if it is faulty. To see a parts diagram and price lists for any parts, see http://www.appliancepartspros.com/parts-for-samsung-dv400ewhdwr-aa-0001.html . Other sites also have the parts for the dryer.
I hope this helps.
Posted on Aug 12, 2017
SOURCE: Defy Tumble dryer not heating
Is this an electric dryer? If so, the most common problem would be a burned-out heating element. There could also be a defective temperature sensor inside. This will need to be evaluated by a qualified appliance repair technician to find the exact cause.
Posted on Jan 18, 2008
SOURCE: dryer does not tumble, but heats up
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
if this helps please vote me a fix ya
Posted on Jul 15, 2008
SOURCE: Whirlpool Ultimate care ii Dryer wont tumble
If your dryer doesn't tumble, check these:
Belt,
Motor,
Door switch.
Remove the belt,
Check for obstructions in the blower fan housing,
Manually rotate the shaft of the motor.
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Posted on Nov 09, 2008
SOURCE: Fisher & Paykel Electric dryer wont tumble
I had the same problem,fixed it today with a replacement capacitor,cost $10 2nd hand (only cos I couldnt find a new one today and wanted it fixed now!)Unplug appliance, took off the back panel,underneath the motor on bottom left is the capacitor,remove the 2 wires, pull the capacitor out its bracket,replace,refit the 2 wires,replace back panel and Badabing Badabang!! My machine is working to full capacity again.
Pays to check out these forums doesnt it!!!
Posted on May 18, 2009
SOURCE: its a hyundai trajet,aa said crankshaft sensor not
it is inside the timing cover in most cases with hyundai the timing belt will have to be removed so the crank gear can come off the sensor is usually behind the gear especially if it is a 6cyl if it is a 4 cyl then the wire goes behind the timing belt make sure the timing marks are lined up so when you reassemble it is lined up
Posted on Aug 29, 2009
Testimonial: "Thank you for the advices Ill get cracking on it"
May 02, 2017 | Samsung Dryers
Mar 04, 2017 | Samsung Dryers
Jan 06, 2017 | Samsung Dryers
Dec 27, 2016 | AEG Dryers
Oct 14, 2013 | Samsung DV218AG Gas Dryer
Nov 24, 2012 | Dryers
Jun 21, 2011 | Dryers
Feb 18, 2009 | Kenmore 62602 Electric Dryer
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Jun 13, 2008 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Apr 18, 2018 | Samsung Dryers
Apr 15, 2018 | Samsung Dryers
46 people viewed this question
