Question about Garden
Ih 115 tractor has noise in rear end it is loud at times and quits then starts again.
SOURCE: John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Posted on Mar 23, 2009
  • 3433 Answers
SOURCE: Loud grinding noise from front end
You can see the brake disc on the front wheels, Check both sides of each side, looking for scoring. Brake pads have wear insicators on them that are metal tabs that contact the rotor (disc) when pads get thin. It would be better to pull the wheels off to get a good look at the pads. Good luck
Posted on Jun 03, 2009
  • 4 Answers
SOURCE: loud noise coming from rear end when starting and
if this is a popping type noise need to check universal joints or check the play in rear end gear- if both are god pull brake drums off and check to make sure brake shoe has not come loose
Posted on Jun 04, 2009
  • 6 Answers
SOURCE: loud noise comes from rear brake when braking
When you squeeze the brakes, the rubber pad should NOT be flat against the rim. Instead, the FRONT of the rubber pad should be a bit closer to the rim than the back part of the pad (about 1 mm or 1/16th inch).
Also, you can try to put fine sandpaper (150 grit) between the rim and brake pad, with the rough part facing the brake. Squeeze the brakes lightly and move the wheel a small amount to scuff the brake pad to remove any dirt on it.
Posted on Jan 14, 2010
SOURCE: tractor stalls after approx. 15-20 of run time (1957 farmall cub)
Could you be having a fuel supply problem? I have a 1957 Farmal Model 100 and has its own problem caused by moisture building up in the distributor SLOCITYJOHN
Posted on Sep 18, 2011
Troy bilt mower 42 " rear end noise..forward and revers..very loud.????
Sorry to tell you but either the Gearbox or the rear Axle is broken. This may well be the time to think of buying a new replacement Mower, It is worth asking if they will give you any Discount on your present mower. If you do not ask they will not give you anything. Best Wishes, Malcolm.
Jul 03, 2015 | Troy Garden
Whining sound
check the oil level
Jun 21, 2014 | John Deere Garden
To remove the clutch, do you block the front or the rear so tou can split it? I know you must block up both ends , but what end do you move? Please help!
Hello. Block up the front end and suspend it from a tree. Then with the rear end also suspended roll it back to get to the clutch. Joe
Dec 02, 2010 | Farmall IH Tractor A, B, Super A, AV Carb...
Where is the rear end fill and level holes on a Farmall 400 Diesel?
Just check you hydraulic and transmission fluid levels,the rear end is lubed with hydraulic oil that is supplied by one or the others oil reservoir.
Mar 21, 2010 | Diesel Farmall Tractor 400,450 Gas & ...
Rear end squeak
Noise is coming from a dry u-joint and or the carrier bearing if equiped. Usually a u-joint "cherps" in reverse first then only gets worse with time. If it starts vibrating at highway speeds replace them immediately.
May 25, 2009 | 2005 Dodge Ram 2500 Truck
Gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Dec 28, 2008 | Garden
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
