Question about Honeywell Heating & Cooling
Can i use a honeywell Ruth 9580 wifi thermostat with a gas fm water boiler
5 Suggested Answers
SOURCE: require room thermostat for ferroli combi boiler
Get a Ferroli wireless programmable room stat. City plumbing supplies can get hold of them but you'd be looking at approx £130. Part number 30800009. No wiring involved, the receiver connects to the boiler pcb. Had same problem but now fine.
Posted on Mar 12, 2009
  • 659 Answers
SOURCE: hot water boiler will not ignite
Check all your limit switches on this unit. One of them is either tripped or bad.
Posted on Apr 07, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: I have a Honeywell Thermostat CM67NG The flame
You may have a broken thermostat wire. Disconnect the wires from the thermostat and please note what colors are hooked to which terminals. Cross the R and W wires and see if your heating system turns on. If it does not, you have a broken wire or bad connection at the heating system. If it does start, you have a bad thermostat or bad connection at the thermostat.
Posted on Nov 30, 2009
  • 3087 Answers
SOURCE: Baxi 3 Solo Boiler will not ignite
it could just be the presure switch try bridging it out and see if burner lights
Posted on Jan 21, 2010
Wiring Honeywell 9580 to old furnace with no C wire
This is not going to be easy. Check the wiring in the wall to look for the third wire. If they did not run one, you have to run new wire to the furnace and thermostat. If they stapled that wire to the walls inside studs, then it is going to be even harder to run the new wire. Once you run that new wire then you have to locate the connection in the furnace that has the common (c) wire for the transformer. Check you tube to see if the have any how to video.
Oct 13, 2015 | Honeywell RTH8580WF WiFi Thermostat
Boiler not responding to thermostat
The thermostat controls the gas valve is this sticking open , There must be a over heat that should cut in . Rebinded ??
May 07, 2017 | Honeywell Programmable Thermostat Heater
The wifi connection from worcester boiler to room thermastat Honeywell Cm921 , boiler not receiving signal
Can't help you directly, but Honeywell will have user instructions on their website.
It's something like holding the 'stat within a metre of the boiler when the batteries are inserted. Best to RTFI.
Jan 27, 2013 | Heating & Cooling
What should ther honeywell relay read in ohms on a r8222u 1006
did you check power to the gas valve? Pilot lit? Or electronic pilot on? Need more info on boiler.
Nov 05, 2011 | Honeywell Programmable Thermostat Heater
Boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Oct 05, 2009 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C - hot water not working
some digital thermostats do no not work with zone valves is this a new thermostat that you had installed
May 08, 2009 | Honeywell Programmable Thermostat Heater
Hot water boiler will not ignite
Apr 07, 2009 | Water Heaters
Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
