Question about LG Dryers
How do I remove the back of a LG dryer DLG 1002
  • LG Master
  • 2,278 Answers
Both sides and back are all one u-shaped piece. Top and frontbare the accesses to interior.
Posted on Aug 13, 2017
    Top Expert:
  • LG Master
  • 39,416 Answers
Go to www.repairclinic.com and enter DLG 1002. With luck, you will be presented with a list of common replacement parts and may be able to view a generic LG video that shows disassembly.
SOURCE: LG DLG 5988B gas dryer not heating
HELLO:
Have you looked at the over heat sensor on the left hand bottom of the burner pipe?
I found this and with a simple test with a butane lighter.
I used a cheep Digital volt meter and set it to ohms.
The sensor was open meanning that their was no connection between the terminals.
On the rear of this sensor there is a small button.
When I pushed the button I hear it click and the switch closed up.
I reinstalled it and the machine work perfect.
I think this is a fail safe if the exaust flue becomes clogged.
Otherwise why would it have a re-set button on it?
I am not a service / repair person.
Unplug the unit before you take the lid and front cover off.
the burner unit is in the lower right hand corner as you face the dryer.
The top comes off first and then the control panel and then you can remove the door and fron panel to expose the blower and burner.
Be carful and good luck.
Uncle Ed.
Posted on Dec 05, 2007
  • 36 Answers
SOURCE: LG DLG 2524W gas dryer
call svc tech under warrenty, also sensor rellies on clothes touching two shiny strips to sense the dryness of the clothes ussaly in front or rear of drier drum or rather back or front wall inside wet clothes short the bars and stalls timer when they are dry does not short bars so sensor knows dryness by resistance of short tilt drier front or back where ever bars are to make shure clothes main tain contact lots of time this cures the promblem
Posted on Dec 28, 2007
MNTECH
  • 1543 Answers
SOURCE: I am trying to open my lg tromm dlg 5988w dryer to
Remove three screws on the back holding the top cover, then standing in front of machine, use the palms of your hands to sharply push back on the L and R edges to move the cover back about 1 and a half inches, then lift cover off. Top cotrol panel is held on by a screw at the top corners and tabs along the top edge. Watch out for sharp edges. Remove control panel and place on top or dryer drum with wires still attached. Open door and remove screws at 4 and 8 O'clock positions, the the four screws along the top of the front panel. Unplug the light and door switches and remove the front panel. That should get you most of the way there.
Posted on Nov 12, 2009
Testimonial: "perfict just what i needed. Thanks"
heatman101
  • 43501 Answers
SOURCE: LG DLG 2526W dryer running but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
  • 32 Answers
SOURCE: HOW CAN I OPEN THE
Stick a screw driver between the top of the dryer and the body, the top should pop up znd you can see where the front bolts to the sides.
Posted on Mar 03, 2011
Locating the reset button for LG electric dryer model # DLG2532W
what is the problem with the dryer?there is no reset button,if it doesn't start you could have a broken belt,or one of the thermostats is blown,the only way you could try to reset it is by unplugging it for a few minutes and then plug it back in,this will reset the computer board,or if you have no heat there is a resettable t-stat part 6931EL3003C if that's what you mean,and your dryer isn't electric it's gas,if you look at the model number DLG the G is for a gas dryer,go here hope this helps you out.
https://www.youtube.com/watch?v=EUqVqmEmrbQ
Feb 11, 2018 | LG Dryers
Where is the drain filter on lg 4408dle
Lg Washers have model numbers that start with WM
LG dryers start with either DLE(electric) or DLG(gas)
so check your model number and add comment below
May 01, 2017 | LG Washing Machines
HOW CAN I OPEN THE DRYER LG MOD DLG 59885 I NEED TO REPALCE THE DRUM ROLLERS
Mar 03, 2011 | Dryers
LG Tromm DLG 5988B Need to give the drum a spin by hand to get it to move
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 20, 2010 | LG DLG5988 Gas Dryer
Replacement of fuse and thermostat
NEED FUSE AND THERMOSTATE AND DIAGRAM
FOR MY
LG DRAYER
MODEL NO.
DLG 2524W
ART
THANK YOU
Jul 05, 2008 | LG DLE2532W Electric Dryer
Nov 18, 2007 | LG DLE2532W Electric Dryer
Dryers Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
