Question about Top Vacuums
Dirt goes to top of cylinder only..Not the bottom. Help!!
2 Suggested Answers
SOURCE: dtson dc05 plus turbo brush
Unfortunately you need a new Bin Assembly. you have inadvertently thrown your Bin Inner away when you have emptied your machine. You can get these from either www.espares.co.uk or www.dyson.co.uk. There is only a couple pounds difference between the two suppliers. i've just paid £20 plus £3 delivery.
Posted on Aug 20, 2008
How to replace filler tube on Kirby G4 vacuum?
first take cloth bag off, held on at bottom with bag clamp, then wash cloth bag in washing machine at 40, inner hose is held on by 2 cable ties top and bottom, your new hose should come with 2 new cable ties, ask kirby agent when ordering, them simply refit.
Aug 25, 2014 | Kirby G4 Bagged Upright Vacuum
How do you separate the top of the canister from the bottom? Dirt Devil Reaction. There is dirt trapped in the top section and it needs to be cleaned.
Hold the top firmly, and twist the bottom of the canister anti -clockwise and you will be able to clean. Re-assemble by lining up both parts and twisting clockwise to lock!
Jul 05, 2014 | Dirt Devil Reaction Twin Cyclone Upright...
N2000 clean filter
The red guard goes on top of the foam after it is installed. The purpose of the red guard is to keep the bag from sucking down against the filter when you get a few inches of dirt in the bottom of the bag. If it sucks down against the filter the dirt in the bag will cause an airlfow restriction even though the bag is not full.
Jan 25, 2014 | Riccar Vacuums
Sounds stupid but how to i connect the hose?
the hose on a dirt devil upright attaches on the side near the bottom of the plastic container that hold the dirt; that end goes in and gives suction to the power head.the other end goes on the other side closer to the top of the plastic container again on the side. If you look at the bottom of the machine you should see a hose going from the power head to the machine and it leads up and attaches to the long hose. It is the other side it attaches near the suction to create the air flow. You can also check your owners manual.Thanks and good luck. If this helps don't for get to click on the yes box on your way out.
Oct 08, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Our dirt devil vacuum is blowing out air instead of pulling in air.
my dirt devil is blowing out air instead of sucking up.Tried new bag.any other solution to fix
Aug 29, 2009 | Dirt Devil 12 Amp HEPA Filter Vacuum...
No suction through top of hose - HELP
disconnect the hose where it goes into the clear tube on top of the base.there will be a little flapper door there when yo take it off.open the door and take a coat hanger with the end bent over like a hook and pull the dirt clog out of there.but first take the dirt cup off and remove the filter,if its clogged with dirt you won't have any suction.try using the vacuum without the filter in the dirt cup.if you have suction then then thats your problem ,a cloggeds filter
Jul 01, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Vacuum hose has little suction.
There is most likely a clog in the hose. If the hose has poor suction the foot probably has poor suction as well seeing that the hose is what gives the foot assy suction.
Jan 05, 2009 | Bissell 6594 PowerForce Bagless Upright...
Holes in top of dirt bin keep clogging
Make sure that your filter is clean. The holes are normally clogged.
Oct 25, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dtson dc05 plus turbo brush
Jun 15, 2008 | Dyson DC05 Cylinder Bagless Canister...
I have an optima 437az and the cylinder that the dirt goes has cracked and the bottom of it came off! I haven't hardly even used it!
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=544623
Generic problem for all Vacuums
I have an Optima 437AZ
Posted by aliendiva05 on Apr 25, 2008
I have an Optima 437az and the cylinder that the dirt goes has cracked and the bottom of it came off! I haven’t even used it!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
If you have purchased the Optima 437AZ within the 1st year, you have a factory warranty on the vacuum and the part should be covered under warranty unless that if the part was dropped or damaged by the customer the part would NOT be covered under warranty and would be under miss use and abuse. You can order the part from your local vac dealer or contact the factory. They would need the brand name and model # of the vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Vacuums
Vacuums Logo
Top Top Vacuums Experts
Vernon Taylor
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Top Vacuum Expert? Answer questions, earn points and help others
