Question about Powerhorse 166114 9000w Portable Generator Electric Start
A powerhorse 9000 generator the electric starter will not crank with the key. have replaced the solenoid . Can also jump the solenoid and the starter cranks. Is there a fuse on the starter circuit?
  • 18,201 Answers
Manual says there is a fuse, but only covering the 12 volt DC output. There is a number where you can call them on page1.
[PDF]MODEL 9000 16 HP Generator - WEN Products you for purchasing a model 9000 generator. This manual ... Please keep this manual available to all users during the entire life of the generator. 04/06 ...
Questions? Problems?
Please call our customer help line:
(800) 232-1195 M-F 8-5 CT powerhorse 9000 generator manual Google Search
Posted on Aug 13, 2017
  • 1010 Answers
SOURCE: 2004 explore no crank
Sounds like it could be the alternator. Call your local Auto Zone store and inquire with the cars symptoms. They give free advice and even let you use their tools for free.
Posted on Jun 23, 2008
SOURCE: I can't crank my 95' mitsubishi eclipse.
on the sterin coluam theres a plug unplug trust me plug it in it will work
Posted on Aug 06, 2008
  • 23 Answers
SOURCE: 1989 Honda Accord won't crank - starter good - what next?
check powers out of the ignition switch big in big out usually first place to start
Posted on Jun 20, 2009
  • 285 Answers
SOURCE: 01 dodge caravan new starter battery full turn key
try lookin at the wiring harness under the battery tray,seen them corrode there alot
Posted on Sep 05, 2009
  • 5648 Answers
SOURCE: engine shutdown while driving, check engine light
Try turning the advance-trac off. If you have a systems menu (Should be right side of Speedo) you have options for Park assist, bells ,chimes and so on. One selection is the Traction. The traction assist works by throttling down the engine when it detects a difference in rotation from 1 wheel to the next.
You need a scan for the codes but your hunk of metal is not able to go to Autozone or Oreillys until you start it.
You may also want to try to enter the keyless entry code in the door keypad in case the antitheft is upset. Your alarm may block the ignition.
Defeating the traction control and alarm system may get you going.
Posted on Sep 28, 2009
Do you know what a wiring diagram is ? How to use a DMM - digital multi-meter to diagnose automotive electrical circuit's ? Looking at a wiring diagram to see what all is involved in the starter circuit , main battery cables , park neutral safety switch , starter relay etc.. Find video's on youtube . Do you have a manual or automatic trans. ? The purple wire get's B+ voltage from the starter relay in the underhood fuse / relay box .
How to voltage drop test starter motor circuit
When your car wont crank or start part 3 How to check relays fuses...
Nov 08, 2017 | GMC Cars & Trucks
Do you have a wiring schematic for the starting system on a 1994 Ford 4630 Diesel Tractor?
Randy, Check the attached link and scroll through it, hope it has the info. you need.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
1994 Ford 4630 Diesel Tractor wiring schematic for the starting system...
Apr 22, 2016 | Ford Cars & Trucks
I have a 445777/0129-E1 engine that won't crank when I turn the ignition key. What should I check next?
The click will be the fuel switch on the carb that opens when the ignition is switched on. When you jumped the battery to the starter did you have the ignition on? If not it won't be getting fuel. If you find the wire that goes from the ignition switch to the starter solenoid (usually mounted on or near the starter motor) and connect the switch end of this to the battery does this crank the engine over? If so then the ignition switch will probably be faulty or have dirty contacts. If not then I'd suspect the starter solenoid.
Sep 21, 2015 | Sears Craftsman 46 in Mulching Tractor...
How to replace starter solenoid , Suzuki 2010 sx4
a/t or m/t transaxle >???? ill guess auto.
fuses tested,good , battery ok, jumper cable jumps fail.?
battery lugs clean ?????
immobiliser light off. key on.?
next test is hot wiring the starter solenoid
keys in pocket (it wont start) but will crank fast, in park.
if yes, you have a good starter. all in 5min work.
we use $5 push button cable to do that, most guys a screw driver jump.
so if that test passes the KEY line is bad. a whole other matter
big lug to tiny. grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr , this work?
if the KEY line is bad.?
then try to crank in neutral as the opr. guide explains
if that works the PRNDL switch is bad.
easy test with voltmeter, ask.....
now ill answser the how to question./
remove starter, replace starter.
or same on the bench remove solenoid , buy one and put it back.
finding solenoid can be hard.... (time to get it , and down time)
Sep 03, 2015 | Suzuki Cars & Trucks
I have a 2005 Toyota corolla and yesterday we went out and the car was parked and turned off for an hour. When we went to start it everything but the engine would start. The lights the radio the heate
You are saying that the starter motor is not working, that the engine is not cranking over, even with a boost?
If so, then either there is a problem in the starting circuit between the ignition switch and the starter, or the starter is bad. There is a way to check the starter on the vehicle: the starter will have 2 electrical connections. One is the positive battery cable, and the other is a small wire connection to the starter solenoid, mounted on the starter. The key should be off, the brake set, and the transmission in park or neutral. Use a small jumper wire or a small screwdriver, and jump the battery cable connection to the solenoid connector. Take off the solenoid electrical connector if you need room to do this. With key off, the engine won't fire and run, but if the starter is good, then jumping those two connections will make the starter engage and spin the engine over. (Of course, if key is in ON, the engine should start and run.) But you are just checking starter operation, so keep the key off. If starter is good it will crank the engine over. If jumping the two connections causes nothing, then it is pretty certain the starter motor or the solenoid is bad, and you need to replace it. (Take off the negative battery cable from the battery first to remove the starter from the vehicle.)
If jumping the starter caused it to operate, the starter and solenoid are good, and there is, again, a problem in the start circuit from the ignition switch to the starter solenoid. It could be simple like an electrical connection (like the one right there on the solenoid), or a component in the circuit between the ignition switch and the starter solenoid, like the neutral safety switch for example. You will need a wiring diagram and a multi-meter to diagnose further. Good luck, and hope you find the problem. Are you sure your battery is still charged up good?
Jan 12, 2015 | 2005 Toyota Corolla
My craftsman 15.5 HP 42"
Hi government32, seeing how you just installed a new battery I'll assume you cleaned all the connections. Not cranking at all sounds like 3 possibilities, Key switch, starter solenoid, or starter. Lets check starter first. Using a jumper cable, jump from positive battery post to starter motor (you'll see the connection on the motor where cable is connected,thats where you hook jumper), if it cranks the starter motor is ok. If it doesn't thats the problem. If it does crank check the starter solenoid, using a jumper cable jump across from side to side (the 2 big terminals). If it cranks now the solenoid is bad or the electrical connections are dirty. There are also 1 or 2 small connections on solenoid from the key switch, make sure they are clean. If these 2 components check out the key switch is bad or the connections on it are dirty. (its usually not the switch).Hope this helps you.
Jan 03, 2011 | Garden
95 jeep cherokee country 6 cyl auto. wont crank all the time
Bad solenoid i would guess. Not making a connection there. Any basic wiring and ignition switch problems should be alleviated by jumping the starter with a screwdriver. I would check the solenoid and starter brushes
Dec 30, 2009 | 1994 Jeep Cherokee Country
Turn the key on and the starter will not engage.
check fuel pressure.if not above recomended spec. replace fuel pump. for starting have solenoid 0n starter checked.
Jan 26, 2009 | 1994 Cadillac Fleetwood
Powerhorse 166114 9000w Portable Generator Electric Start Logo
132 people viewed this question
Top Powerhorse Electrical Supplies Experts
Andrew Taylor
Andrew Taylor
 Generator Guru...
Generator Guru...
Are you a Powerhorse Electrical Supply Expert? Answer questions, earn points and help others
