Question about Miele Vacuums
I need used cord winder for MIELE S525 Filtration Guard part# 5240303\08 12403.
    Top Expert:
  • Miele Master
  • 35,645 Answers
Fixya does not sell used cord winders.
Posted on Aug 13, 2017
  • 389 Answers
SOURCE: vacuum not running; do I have to replace the cord winder or just cord?
Typically, the cord and winder are supplied as a unit.  It is possible to fit new cord to an existing winder, but the amount of labour involved will make the job more expensive than simply exchanging the complete unit.  Even if you're going to do the job yourself, it's simply not worth planning to just fit new cable (unless you are a masochist with unlimited time and patience).  Pay that bit extra for a complete unit - you'll be glad you did (or you'll be sorry if you don't!).
Posted on May 27, 2009
  • 52 Answers
SOURCE: How do I separate the top of a miele vacuum S 248
A lot of Miele's have similar construction, you might find the instructions here useful: http://www.sannerud.com/house/miele.html
Posted on Aug 19, 2010
  • 4736 Answers
SOURCE: How do I open the clamshell of my Miele S248i
Most Miele vacuums are pretty much the same. Here is a link with pictures, that will describe how to service and dismantle the vacuum.
Hope this helps you. Please let me know.
Posted on Feb 24, 2011
SOURCE: Miele S2511 Vacuum Cleaner Disassemble Question
My problem is with the power brush...I checked the belt and cleaned the rotating bar..still very low suction. The canister is still giving me plenty of power...thanks for any help
Posted on Sep 21, 2011
pkstrun
SOURCE: I have a problem with a miele s524 canister vacuum. While the motor is running and you pull out the power cord for more length it shuts off.
s524 vacuum was vacuuming the floor under the a chair wand everything was floor level it stopped running checked all connections everything was connected no blockages etc help !!!!
Posted on Dec 25, 2013
My Miele Carina Vacuum stopped working. Does it have a fuse that can be replaced that could be at fault here?
although it might have an internal fuse on this model, I dont think that will be the problem.
The miele cord rewinder has been known to have a small fault in it where the cord winder that actually retracts the cord onto will come apart from the electrical connection in the cord winder itself.
As most of these units have a 5 year warranty anyway, I suggest that you take it to your nearest miele dealer for a repair/replacement on the cord rewinder.
Good luck.
Nov 06, 2010 | Miele Carina Vacuum Vacuum
How do I separate the top of a miele vacuum S 248 i from the bottom so I can replace the cord winder?
Aug 15, 2010 | Miele S2180TITAN Canister Vacuum System ...
Have a miele S546 vac. and it won't turn on. Is there a fuse? Can the on/off switch burn out? Thanks.
If you vacuum wont turn on it is most likely the cord winder. This is a pretty big repair, you wouldn't want to attempt it yourself. Most shops should be able to repair the cord winder for about $50-75. If you need a new cord winder expect to pay about $150.
Oct 13, 2009 | Miele S548 Bagged Canister Vacuum
Miele s314 red star-motor stopped working-on/off switch broken?
Most likely the problem is with the cord winder. This is the most common problem with Mieles. It is actually the most common problem with any vacuum with a cord winder. A Miele repair center should not change you to look at the vacuum and tell you what is wrong with it. The Red Star was a great model and if the powerhead is still in goood condition I would get the vacuum repaired. If it is the cordwinder they can usually be repaired and it should cost about $75.00. If you need a new cord winder this will cost about $150.00. The top piece can be pryed off, however if it feels like it is switching than it is not jammed.
Oct 08, 2009 | Miele Vacuums
Vacuum not running; do I have to replace the cord winder or just cord?
May 27, 2009 | Miele S514 Solaris Bagged Canister Vacuum
I have just purchased a used Miele S528 and the power beater bar attachment is a Lindhaus. Is this ok?
as long as all the wiring on the power nozzle looks secure and it plugs safely into the end of the hose then you should be fine.
May 10, 2009 | Miele Filtration Guard S528 Canister...
Won't start
It is most likely your cord winder. They are a little tricky to fix yourself. A repair shop will probably charge about $50. To fix it. The contacts where the cord winder plugs into the motor need to be cleaned and adjusted. Just don't let your repairman tell you that you need a new cord winder.
Jan 22, 2009 | Vacuums
Vacuums Logo
29 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
