Question about Tools & Hardware - Others
I need help how to open craftsman tool box with a 5 button push lock
I tried Push 2 and 4 at the same time then push 3 but it did not work for my tool box. I do not know how to post my image in this
  • 33 Answers
SOURCE: 1994 chevy s10 blazer 4x4 push button type
small sylinoid on the top of the transfer case needs replaced. easy to do. it has three vacumelines going to it just trun out and replace like a bolt.
Posted on Dec 13, 2008
  • 14 Answers
SOURCE: 99 Blazer-push button 4wd not working
Make sure that all 4 tires have the same tread on them, if one or more of them are different, then the 4wd may not engage. I had the same problem with my blazer, I changed only 2 tires at a time. The front tires would rotate faster than the rear ones, the gears in the transfer case won't line up right.
Posted on Apr 29, 2009
SOURCE: programming keyless remote
2003-04 Mazda 6 REMOTE PROGRAMMING
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Good Luck.
Posted on Jul 10, 2009
mikesagenius
  • 24 Answers
SOURCE: 97 GMC Z71 4X4 Not Locking in
If it's a shift - on - the - fly 4wd, then call your local Chevy truck dealer. There was a recall on the Electronic 4wd on these trucks. (common problem). Try this just for the heck of it. With the truck stopped, put in 4hi/lo, then put it in reverse. Back up slightly, (about 5ft or so) and then put it in drive (or first in a manual trans) and go forward. Did it lock in? If it locks in but won't unlock, try backing up to unlock. Hope this helps.
Posted on Jul 26, 2009
SOURCE: Chrysler T&C Power Door Problem
If it stops in roughly the same spot every time, and won't respond after it has stopped, it sounds like a broken wire. It is likely losing its electrical current to run the motor. It should be right where the track bends when the door has stopped. Check for loose or frayed wiring inside the flexible plastic track just below the door. The wires will often wear after being bent over and over again. If you find a broken bit of wire, cut out that section and splice in a new length of wire. Be sure you do a good job splicing, or you may end up with the same issue again soon. I am not a mechanic by any means, this just makes sense to me, and I'm considering buying an 01 town and country with this issue, which is why I'm on this site to begin with. Best of luck -
Posted on Sep 07, 2010
I have a 2010 Hyundai Genesis with the Homelink in the rearview mirror. I have a Craftsman 3/4 opener mod # Y 139.54918. I have tried every way to program homelink to opener with no success . Help.
You only have a short time to get into program mode and push the remote button. there Should be a button on the garage opener as well, try having someone push the button on the garage door opener while you push the in car button. If that doesn't work your opener may not be compatible.
Jan 21, 2015 | Hyundai Cars & Trucks
How to program my new control remote to my Honda passport 2000
Try this please!
'98 - '02 Isuzu Rodeo and Trooper and Honda Passport(with factory keyless entry) Instructions for programming. 1. Get in car and make sure all doors are unlocked. 2. Open driver's door and leave open. 3. Put key in ignition. 4. Turn key to 'on position' (dash lights on, but do not start) and back to 'off position' 3 times in 5 seconds or less. (you must turn the key very fast) 5. Close and open driver's door 2 times in 5 seconds or less. 6. Turn key to 'on position' and back to 'off position' 5 times in 5 seconds or less. (turn key very fast) 7. Close and open driver's door the doors should lock and unlock twice after this happens push the lock or unlock button on the remote, doors will lock and unlock. Push the lock or unlock button a second time and doors will lock and unlock again. You are finished! The above sequence erases all previous codes and adds the new code as #1. If you are adding a second remote, you should follow the same sequence with the exception of step 6; instead of turning the key to the 'on position' and back to the 'off position' 5 times in 5 seconds or less, do it 3 times in 5 seconds or less and then continue to step 7. ***Remember to turn the key to the on and off position very fast. This works! Follow directions EXACTLY. I had to try 3-4 times before getting it to work. I failed to go exactly by the instructions the first few times.
Jan 03, 2013 | Cars & Trucks
Cannot get remote for garage door to work
push the green button on the opener then push your remote button
Jan 25, 2010 | Locks & Locksmithing
Garage Door opened but will not close. I opened
I think the trolley has jammed against the bolt just in front of the motor unit. Remove the bolt and then run the door until it is closed. With the door closed locate the 'up limit' control on the side of the motor unit. Turn this 2 turns in the opposite direction of the arrow printed on the cover. Replace the bolt.
Sep 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Aug 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO - Remotes not working
I think this is an easier way to program. Press and hold the button on the remote and then press and immediately release the smart/learn button on the rear of the motor unit. Do this for each remote you have.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a 2001 Accord and if I hit the unlock button and do not open any door within a certain amount of time (2-5 minutes) it automatically re-locks it. Is there a setting I can change to prevent this...
Hope the following procedures helps.
TRANSMITTER TEST
NOTE:
If the doors unlock or lock with the transmitter, but the LED on the transmitter does not come on, the LED is faulty; replace the transmitter.
If any door is open, you cannot lock or unlock the door with the transmitter.
If you unlocked the doors with the transmitter, but do not open any of the doors within 30 seconds, the doors relock automatically. ?
The doors do not lock or unlock with the transmitter if the ignition key is inserted in the ignition switch.
1. Press the lock or unlock button 5 or 6 times to reset the transmitter.
If the locks work, the transmitter is OK.
If the locks don't work, go to step 2.
2. Open the transmitter and check for water damage.
If you find any water damage, replace the transmitter.
If there is no water damage, go to step 3.
3. Replace the transmitter battery (A) with a new one, and try to lock and unlock the doors with the transmitter by pressing the lock or unlock button 5 or 6 times.
If the doors lock and unlock, the transmitter is OK.
If the doors don't lock and unlock, go to step 4.
NOTE: The transmitters for LX models and EX models are different and are not interchangeable.
4. Reprogram the transmitter, then try to lock and unlock the doors (see Transmitter Programming ).
If the doors don't lock and unlock, replace the transmitter.
TRANSMITTER PROGRAMMING
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 15 sec., aim the remaining transmitters at the keyless receiver unit (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
Cheers!
Ryan
Jun 11, 2009 | 1998 Honda Accord
Transmitter not working ( 3 of them)
don't hold down green button. push for one second. do yu have console with vacation or lock button. deactivate it.
Dec 27, 2008 | Sears Craftsman LiftMaster Chamberlain...
Thanks, my imei number 355547011058691. The phone is a Nokia 6288 made in Germany, currently locked to O2 network.(United Kingdom)
IMEI: 355547011058691
You should use code number 7. If it does not work, try code 1. Different codes work on different phones. Remember that you only have 5 tries. After that you have to leave it to an unlock shop.
To enter the code:
1. Push #
2. Push * 3 times in one second. (p will show)
3. Push * 4 times in one second.(w will show)
4. Push * 2 times in one second(+ will show)
5. Enter the code from below.
6. Push * 2 times in one second.(+ will show)
7. Enter the code number
8.Push #
Your code's are:
#pw+043163773133660+1#
#pw+314136445273437+2#
#pw+428347756625340+3#
#pw+986262613464563+4#
#pw+937402062526307+5#
#pw+772210000054510+6#
#pw+718040540672647+7#
Now a message like "Sim restriction off" should be displayed. That means your phone is now unlocked.
If it doesn't work the phone will have to be connected phisically to a device (unlock box) and to a computer.
Aug 25, 2008 | Nokia 6288 Cellular Phone
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
