My Xerox 6280 is getting an ADC Sensor Error 092-651 when I have printed several jobs of about 12 pages each. Is this a known problem?
  • 92 Answers
Hi ....
There could be 2 solutions for this problem ...
1) Switch off the device ... wait for 10 seconds and then switch it back on ... most of the time it resolve the problem ..
2) If this does not resolve the problem, you need to remove and re-install the transfer unit which will resolve the problem for sure ...
Follow the below steps to remove and re-install the transfer unit.
CAUTION: Be careful not to touch the black Transfer Belt when replacing the unit. Handle the Transfer Unit by the release latches and the tabs on the left and right side of the unit.
  1. Power OFF the printer using the power switch located on the right side of the printer, toward the back. Press the power switch to the (O) position.
  2. Disconnect the power cord.
  3. Press the button on the top, right side of the printer to open the FronMy Xerox 6280 is getting an ADC Sensor Error - 6180-cov-front-open.jpgg src="http://i.fixya.net/uploads/images/6180-cov-front-open.jpg" alt="6180-cov-front-open.jpg" class="h_mi" />
  4. Grasp and squeeze the green release latches located on the left and right side of the Transfer Unit. Rotate the transfer unit up until the notch on the shaMy Xerox 6280 is getting an ADC Sensor Error - 6180mfp-trans-unit-latches.jpgg bracket cutout.
    6180mfp-trans-unit-rotMy Xerox 6280 is getting an ADC Sensor Error - 6180mfp-trans-unit-remove.jpg/><br />
<li class=Pull up on the right side of the unit to free it from the bracket, and then slide the unit to the right to remove it from the machine.
    6180mfp-trans-unit-remoMy Xerox 6280 is getting an ADC Sensor Error - 6180mfp-trans-unit-install1.jpglass=Hold the unit by the release latches and insert the left shaft into the left mounting bracket.
  5. Slide the unit to the left while rotating the unit to align the shaft-notch with the right My Xerox 6280 is getting an ADC Sensor Error - 6180mfp-trans-unit-install3.jpgen press down until the shaft fully seats into the bracket.
  6. Gently rotate the unit down until the release latches snap into place. Do not push on or touch the black belt.
  7. Close the Front Cover.
  8. Connect the power cord, and then power ON the printer. A 'Ready to Print' message will be displayed on the Display Screen.
Please vote if this helps ... Cheers :)
Posted on Jul 27, 2009
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
Xerox workcentre 6015 092-651 error
That error indicates a bad ADC sensor. Try cleaning the adc sensor which is on the rear of the transfer belt. If that doesn't work, replace transfer belt as sensor is not sold separately.
Sep 18, 2013 | Xerox WORKCENTRE 6015/Ni Color
Adc sensor error
adc sensor error / error 092-651 .....docu print cp205....please help me...i cant find the solution....
Jan 21, 2013 | Xerox FUJI DOCUPRINT CP205 COLOR LASER...
Service req e547
I can tell you that a Engine Service Error Code #E526, stands for a "SOILED ADC SENSOR". ADC stands for "Automatic Density Control" [sensor]. Hopefully, you will have your printers "User's Manual/Owner's Manual" and it will show you exactly where that ADC Sensor is located, because I do not know. I think its a removable board, that probably slides in and out, somewhere near the upper right section on the inside of the front of the printer. If you use the round knob [on the inside of the printer, near the center] as the center of a clock, then I would guess that the sensor board assembly would be around the one-o-clock to the two-o-clock position, but really don't know for sure...Basically if there are any parts of wrong specifications used, improper mounting, damage, distortion, dirt, or adherence of any foreign material, that can cause that particular error code. Hopefully the ADC Sensor is just dirty and needs cleaned. The major parts that need to be checked, are the "ADC Sensor Assembly", the "Main Harness Assembly" and the "MCU Printed Circuit Board". E532 error means there's a drain on one of the several motors within the printer. Reseat all the consumables within printer (especially the waste toner)and the paper tray the error clears. If the error doesn't clear then you have a real hardware fault and the job of changing each motor until you get the right one. This particular printer has a problem with waste toner. The toner seems to clog up and be the main cause of this error - you may find this occurs after the printer has been sat idle for sometime i.e. after a weekend. Once this particular printer starts giving this message its best to run through this routine each morning... open the front cover, unlock the two lockovers, pull out the consuambles about half way and then slam them back in - hard enough to loosen the toner but not hard enough to break the printer. Switch it on and it should remain error free all day.
May 27, 2010 | Epson Aculaser C1100 Printer
My docucolor 12 say 9-612 error in the adjustment
9-612 TRC RADC Out Of Range RAP Initial Actions Clean the ADC Sensor. Clean the IBT Belt. Check that the P/J139 on the ADC Sensor PWB, IBT connector J702A, J702B and P/J416A on the IOT Drive PWB are firmly connected. Videc
siriusdigitalbox@gmail.com
Sep 23, 2009 | Xerox DocuColor 12 Color Copier
PRINTING ERROR
> Home > Support & Drivers > Knowledge Base
Solution --> ERROR 0082" name="Note" /> Phaser 790 / DocuColor 2006 Printer's: Cancel print job and cycle the printer's power
  • On the printer's Control Panel, press the Cancel Key (12 KB).
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the CANCEL key.
  • If the error message persists, turn the printer off for at least 30 seconds and remove the computer interface to the printer (17 KB) before turning the printer back on.
  • Use the menu keys to perform a front panel reset (under RESETS menu).
  • If the printer redisplays the error message upon reboot, a file is likely STUCK at the front of the print queue. Use the front panel RESETS menu to CLEAR LOGS AND QUEUES, which will delete all print jobs in the printer's disk spool.
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the MENU key to gain access to the front panel menu.
  • If the front panel menus can not be accessed turn the printer off for 30 seconds and then turn the printer back on.
  • If it is known which print job was last sent to the printer, try to reprint the last job spooled, which may be the cause of the error. Step 4 on clearing logs and queues may need to be repeated to eliminate the crashing job.
Note: Most XX82 or XX1E front panel error messages are NOT hardware related, but caused by a specific print job or application.
Mar 04, 2008 | Tektronix Phaser 860DP Thermal Printer
3,432 people viewed this question
jasbo
jasbo
