Question about Whirlpool Washing Machines
The underside nd around the softener cup in my Whirlpool Calypso Washer is fill of semi hardened softener and black gunk. Can this be removed for cleaning?
    Problem Solver:
  • 13 Answers
  • Yes is the short answer. Sometimes they can take some force to pull out. The gunk is semi-dry softener and the black part is mold, YUCK! BTDT and cleaned it with a scrub brush, hot water, and bleach.
Posted on Aug 13, 2017
  • 213 Answers
SOURCE: fabric softener not going into the machine
yes it should come in during the rinse cycle. if its not coming in at all then youll need to replace the valve that goes to the softener. to get to it take the top off the washer. youll see 3 valves where the hose connect. trace the hoses from the dispenser back to see which valve you need to change
Posted on Nov 27, 2007
SOURCE: AEG lavamat w 1020
You can pull out the dispenser. Just apply a bit of pulling power and it comes out. When you get it out, you can pull off the middle section that has a small overflow dispenser bit - you'll know it when you see it - that is the clogged bit. You need a flexible thing to clean it - a curtain wire did it for me. Good luck.
Posted on Mar 02, 2008
jsrock516
  • 5911 Answers
SOURCE: fabric softener dispenser
If you cannot get the dispenser cap opened, submerge and soak it in some hot water. Liquid fabric softener is a type of wax that, over a period of time, will harden and clog the dispenser (as you well know by now). In many cases you do not have to take it apart if you just use the hot water method. You may have to rinse and repeat several times. Try this and let me know if you have any luck. If you require further assistance, please post back with your complete model number, so I can see what type of dispenser cap we are talking about. I hope this helps you.
Posted on Aug 14, 2008
Nicesuit
  • 61 Answers
SOURCE: I have a Whirlpool Cabrio washer (WTW6400SW). It
try cleaning the dispencer first, it has a small syphon assembly in it whcih can get blocked with concentrated fabric softiner and sometimes powder.
Posted on Jul 30, 2009
SOURCE: whirlpool washer fabric softener dispenser
The fabric softener dispenser in my Whirlpool washing machine is caked w/hair and detergent. I have tried to take it out by unscrewing it, but it won't come out. What's the secret? Please help!
Posted on Sep 20, 2009
How to remove black mould from rubber door seal
the best thing to do is replace the rubber boot.
Mar 19, 2011 | Washing Machines
Strange yellowish circle appearing on white shirts
i believe the stains are actually semi burn marks. If you are drying your whites try a lower heat setting. i had this problem with my kenmore dryer before too. Got bad especially with towels. Make sure your vent is not clogged and your filter is cleaned regularly to let the heat flow better. should help.
Sep 17, 2007 | Whirlpool LER8648L Electric Dryer
Water colects in lid sometime during the cycle.Drains onto washed clothes when lifting the lid to remove clothes. Water seems to be combined with fabric softener. Bleach holder also is filled with water....
I had the exact same problem. The problem is that your fabric softener dispenser is clogged up with a lot of dried, sticky fabric softener. The flooding comes from the part of the cycle when water that is to be flushed through the fabric softener dispenser can't drain properly so it spills into the bleach dispenser and onto the top and into the lid gasket as well.
To remove the dispenser for cleaning, you need to open the top of the washer. (First pull it away from the wall.) Carefully pry off the little emblem in the front center of the washer lid. Then remove the screw. Then slide the top forward to you about a 1/2 inch and prop it up carefully.
You then need to remove both hoses that are attached to the bleach and fabric softener dispenser (part of the same unit). Then unsnap the combined unit from the washer top. Then clean all the gunk out by running it under scalding hot water in the laundry tub and swirling the gunk out. Don't attampt to remove the blue round fabric dispenser part from the unit.
Put it all back together and you're good until you clog it up again with too much fabric softener; maybe several years again.
Good luck.
JRR
Mar 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Super Capacity Plus washer drum removal
What kind of residue? Grease? Sometimes a buildup of fabric softener will look like grease. If so, removing the agitator and inspecting it will show a buildup of fabric softener on underside. Rinse with hot water to remove. If you need to remove the inner drum, you will need a special tool for that. Try a local appliance parts business. They might loan or rent one, or sell you one. No filter to clean though. Grease should not be present as there is only the shaft of the transmission coming through a seal into the outer tub. Not likely to have grease migrate into tub. Fabric softener will be present on outer tub as well. Remove with hot water and plastic dish scrubber. Rinse and re-assemble washer.
Aug 01, 2009 | Whirlpool Washing Machines
My Whirlpool calypso top loading washer poured water from underneath, water everywhere, what do I do and how do I do it?? No codes showed up. Thanks for any info. Rose
Sounds like the seals & gaskets have failed. If you removed the wash plate trying to unjam the washer and did not also replace the gasket kit, you may have violated the integrity of the water tight seals. However, sometimes also the fabric softener dispenser especially, gets clogged and may overflow and leak if the tubes are clogged with coagulated fabric softener. As I am writing this, my washer's fabric softener dispenser is clogged and the method I use to clear it has not worked this time - a cup of boiling water to melt the congealed fabric softener. One has to open the top lid (method varies by Calypso model - Whirlpool or Kenmore) to get to the dispenser tubing and reservoir underneath to get things flowing again, and in fact I have a small water leak on the floor where the dispenser overflowed a bit. That you have a leak, if it happens to come from such a clog, at least gives you a sign that your dispenser solenoids are not malfunctioning, requiring replacement of one of the circuit boards.
Apr 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Gunk in middle of agitator
the fabric softener spins out of the cup after the wash cycle when spinning the water out of clothes, then the washer fills back up for the rinse w/ your softener having been dispensed. is there a nut at the bottom of your agitator where you see the gunk? If so you can take the agitator out by removing the nut but be careful of the little parts that make the agitator agitate. Do not disturb these little parts if you don't know about them. Does the gunk smell like grease or a mechanics garage? If so chances are it is a lubricant and should not be removed replace the cap and your softener cup and continue enjoying your machine.
Jan 05, 2009 | Kenmore 98702 Stacked Washer/Dryer
Fabric softener dispenser
Aug 14, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
GETTING SL error
Suds lock, use he soap and be sure to use the cup at mark 1 or less. If you have a water softener use a 1/4 less.
Aug 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer Will Not Fill
Could you retype this to better describe?
Feb 24, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
