Question about John Deere Garden
LA 145 ,,, new battery,, ran fine last week,,,,complety dead,,even with jumper cables,,, lights work
  • Clyde Ottaway Aug 12, 2017
    I always remove my battery and put it on a trickle charger you can buy one for 8 or 10 dollars even if a lawn mower is ok you will get a little drain if it is hooked up.
  • 148 Answers
SOURCE: 1993 Mercury Grand Marquis
starter cylinoid
Posted on Jul 07, 2008
  • 3 Answers
SOURCE: 97 outback legacy; won't start
not sure if this will help, but I recently changed the engine in my subaru and changed battery + starter also. Would start but then not restart once warmed up. Turns out the engine ground got forgotten, had that hooked back up after banging my head on a wall for a week and it runs like new
Posted on Apr 12, 2009
  • 131 Answers
SOURCE: 2002 Cadillac DeVille wont start (even w/new battery!)
well first off, check the glove box light blub, make sure it shuts off when you close the door, check it by pressing the switch with your finger to make sure it shuts off, also check under the hood for the light there if there is one, pull the bulb, and the same thing for any bulb in the trunk, then check again after a day to see if the battery dies, if it is dying while the vehicle is not running then it is the battery, if it is dying after it is running then it is the alt. you can check that also tho with a multimeter set to the DC volts setting, place the black end <the ground to any grounded area> and the red end <the hot lead to the back of the alt. > it should be reading higher then 12 volts, normally should be a higher reading then 12 volts... if you are getting a lower reading or just 12 volts then the alt. is bad and needs to be replaced...hope this helps you out...
Posted on Jun 15, 2009
  • 534 Answers
SOURCE: I replaced the battery 3 weeks ago and everything
Battery charge voltage should not exceed 14.5V when the alternator is charging.
Your battery may be faulty- the high charging voltage you observed (15.5V) indicates :-
1) a faulty battery- or poor connection due corroded / loose terminals causing battery to not accept charge current,
2) faulty alternator voltage regulator,
3) battery / or alternator ground are not properly connected.
Battery open circuit voltage (12.7) does not indicate much.
Try measuring the terminal voltage of the battery with the park or headlights on.
It should hold approx 12V under load condition.
Your jumper leads getting hot indicate they are carrying very high current. This is probably the starter motor current being drawn from the jumpstart battery- again indicating a flat or poorly connected 'in vehicle' battery.
Posted on Aug 31, 2009
Testimonial: "Out of all the help I received, yours was the most helpful. I really appreciate expertise. Thank you"
  • 14036 Answers
SOURCE: 04 Pontian Montana DVD, dead battery
sound like a fault in dvd player.its running battery down.have dealership check it out.sound like a electrical problem.
Posted on Jan 03, 2010
Why is battery draining ford 2002 Taurus SES
Remove negative cable from battery, connect a test light to negative terminal, opposite end off light to negative battery post. ( let sit for 3 to 5 minutes). Then start pulling fuses, when the light goes out that's your bad circuit. God-Bless! Its worth a try.
Oct 01, 2015 | 2002 Ford Taurus
My chevy 95 Tahoe has been parked for a while with no battery, now I put a new battery, it cranks but won't sta st?
I ran into a similar problem with a Cavalier, turns out that the on-board computer needs to have constant power. Even if the battery is very low or even dead, it still has to be connected. If the battery is removed it breaks the circuit and stops the command that lets the engine start. After the new battery was installed it would crank but not start, the dealership told me that I had to have it towed to them to have the comp reset, which would have cost around $150 total. Thankfully a mechanic friend of mine had a diagnostic machine and was able to reset it for me - cost me a case of beer. He then showed me a (not so simple) trick around this for the future. Once it is running again remember this. 1 Have the new battery and jumper cables ready, 2 Loosen the battery terminals on the dead battery but DON'T take them off. 3 Connect jumpers to the car battery cables and to the new battery, like you were jump starting from just the new battery. 4 Remove the terminal cables from the dead one in the car and remove dead battery (be careful not to let them come off the cables OR the good battery) it's OK if it disconnects briefly, but reconnect it A.S.A.P. 5 Put the new battery in and connect the terminals BEFORE removing jumper cables. Once they're on the terminals just take away the jumpers and tighten the nuts. That's how you change a battery without letting the car ever lose power. Hope that helps Jose. Good luck, safe driving. Grimm
Mar 16, 2015 | Cars & Trucks
What could be the cause for my vehicle NOT to even turn over, but all dash lights & security seem to work?
the dash draws but 100x less thatn the head lights.
so even a near dead battery make weak lamps work
starter needs 100amps
the had lamps 10amps
the days 0.1amps 100x less.
for get the wheels, engines dead ,wheels are last. never first.
why not jumper cable start the car just like all AAA members do.
see? do it.
and the results will solve this fastests.
if car cranks and starts and runs. then the battery was low
if low charge it , if it wont take a charge replace it.
if it does hold a charge and goes dead driving the charges system is failing, if it fails, clean battery terminals first. and at ever 30k miles.
there are many systems on the car,
each must work in there turn.
Aug 28, 2014 | 2006 Jeep Liberty Sport
My 97 accord has always ran with no problems. I recently replaced the battery and it started and drove fine for 3 months. After not driving it for 1 week, the car is dead, not even an inside light and...
If the battery is completely dead, you'll need to slow charge it for a few hours before trying to use a jumper battery. And you could have something shorted to ground in the car that drained the battery in the first place.
Try disconnecting the battery cables and using a battery charger to bring the battery back to life first.
Jan 26, 2014 | 1997 Honda Accord
On my granddaughter's 2003 - I ran driver's side, electrical seat back, drove the car up the driveway, and parked it. About a week later I tried to start the car but battery was dead. A brand-new, 3-year...
I think you have a short in the seat motor. Doublecheck circuit breaker for electric seats. It has a reset button on it. Perhaps it has tripped. If yes, need to find short in seat.
Sep 03, 2010 | 2003 Chevrolet Impala
Truck will start for two weeks then wont. put a new starter in it ran for two weeks then wont start again. old starter tested bad so replaced it. put a new one in and coil pack ran for few weeks then won't...
check alternator output at the alt and at battery also put a test light on the starter solenoid at the little wire on solenoid see if it lights up when turn key ? possible positive or negative cables have good ohm checks but not carrying enough current ?
Jun 01, 2010 | 1998 Chevrolet S-10 Pickup
2000 Vitara won't start, but battery is fine.
try this take a set of jumper cables and find a good ground on the motor and with the battery hooked up like normal run another test ground to the battery if motor starts replace ground cable. hope this helps THUNDERBOLTZ
Jun 23, 2009 | 1999 Suzuki Vitara
2002 Suzuki ls 650 Savage Ekectrucak problem
sounds like either the battery is past its useful life (will no longer hold a charge while under load) or the recharging circuit is no longer working. i'd focus on the battery especially if its the original from 2002.
even if the trickle charger shows a full charge, remove it from the charger and immediately measure the voltage. wait about 10 minutes and recheck the voltage. if it has fallen to below 11volts without any load applied, then change the battery. be sure to trickle charge the new one before using it.
Feb 26, 2009 | 2000 Suzuki LS 650 Savage
Garden Logo
43 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
