Question about Tablets & eReaders
Y tablet is off line how an I get it back on line. Also no internet connection?
I wiped it clean and it won't go on line or connect to internet, says this webpage is not available
Can you specify what tablet you talking about?
Your internet connection is for wifi or data plan?
Sep 12, 2015 | Tablets & eReaders
Orbo jr tablet won't stay connected to internet. Have 2 exact same tablets, one connects and stays, other does not. Especially when in Play Store
Power the tablet off then back on.
Check the internet settings under "settings" "wifi". Compare to the one that works well.
Visit the company website for tech support or read user forums.
Update the firmware from the company website.
Aug 02, 2015 | Tablets & eReaders
I can not connect to the internet with my zeepad. I bought both of my daughters the same model tablet and they can get on the internet with their tablets.
Most tablets connect to the internet through WIFI. Only a few can use SIM card to connect through 3G or 4G data connection. For WIFI connection, you must have a WIFI router at home. You will normally password-protect the WIFI rounter. To connect the tablet to the internet through the WIFI-router that is in operation, you will configure its WIFI settings to match the router's password. This will be done by going to tablet's Setting, turn on WIFI, click on your router in the list of detected routers, enter the password when prompted. Ensure that Connected is shown against your router. You can then browse the internet.
Jan 10, 2015 | Tablets & eReaders
The keyboard on my grandparent's tablet doesn't work. It's just one line. The keyboard e one installed in a black cis thase that came with the tablet. The rest of the lines work.
Try disconnecting the bluetooth connection in the Bluetooth menu and then re-sync the two. If this does not work I think the keyboard is got issues that cannot be fixed unless sent back to factory
May 24, 2014 | Kocaso M1066 Android 4.1 Dual Cameras 8GB...
Not connecting to wifi
Virus check your tablet first thing.
Open a command line and try to ping 8.8.8.8
Dns may be snafu
What is the error message you get when you try to get to website?
May 11, 2014 | Hipstreet Flare 2 9 inch Tablet with 8GB...
Internet problem
turn off your internet for 30 seconds and then turn it back on and it should connect
Feb 20, 2014 | Android 7 inch Tablet
NO ACCESS TO WI-FI
u can also check power setting, it might be on "power save mode"
Jun 04, 2013 | Kocaso M1052S 10.1" Android 4.0 Tablet PC
Have lost Internet connection to my tablet but it is OK on the PC.
You need the name of your network and the password for the network. If you have forgotten it, contact your internet service provider tech department. They will be able to help you. They will help you with resetting it renaming your network and password. Once you have that you will be able to get your tablet on your network.
Aug 03, 2017 | Tablets & eReaders
My laptop wont connect to the internet...it connects to the router but then wont connect to the internet and its not the router or modem wont connect to a wired connection either
I would hook your laptop up directly to your broadband modem and bypass your router to rule it out. Plug the network cable from your modem into your laptop. Unplug the power on your broadband modem and plug it back in. Restart your laptop and see if you get on-line.
If you can...your router is the issue. If you cannot....I would check with your internet service provider before troubleshooting further.
Jun 04, 2010 | Gateway CX2726 Tablet PC
Tablets & eReaders Logo
91 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
