How do I program the Venstar T1010 digital thermostat. I did not receive a manual with it.
  • Heating & Co... Master
  • 5,481 Answers
Venstar has the documentation for the T1010 thermostat on their Small series (Residential) support page: http://venstar.com/thermostats/small-series/literature/ . The direct link to the user manual is currently http://files.venstar.com/thermostats/small-series/documents/T1010ManualRev1.pdf .
To set the time, press Mode and Fan at the same time and hold for 2 seconds. This will put the unit into set up mode. Use the up/down arrows to change the currently flashing item. Press and hold Fan while pressing either the Up or Down arrows to quickly change the item. Press Mode to move between time sections. After you advance to the section for heating/cooling mode, you can press Mode to change between the available options. Press and hold Mode and Fan to exit this setup area.
Press and hold Mode and the Up arrow for 2 seconds to program the timed heating or cooling intervals and temperatures. Press Mode to move between time period, desired temperature for heating or cooling for that time interval and the next time period. Use the Up/Down arrows to change each section. When finished, press and hold Mode and the Up arrow to exit.
I hope this helps.
Posted on Aug 12, 2017
2 Suggested Answers
grumpytoolgu
  • 69 Answers
SOURCE: I just installed a venstar digital thermostat non programmable and i cannot get it to start heater
Did you turn off power for your unit before changing out the thermostat? If not you may have blown the low voltage control fuse. If you did and it is wired correctly, you may have a defective thermostat.
Posted on Dec 14, 2011
How do you unlock it?
How to Over-ride the settings on your Honeywell Thermostat ...
? 0:58
https://www.youtube.com/watch?v=ofenS8mOJDs
Oct 18, 2010 - Uploaded by Sherlock Homes Austin
If you've just bought a new David Weekley Home at Mueller, youmay ... How do I "factory reset" the th8320zw honeywell thermostat? ... Would that be the same for Trane thermostats? ...is there a way to unlock the screen?.
Venstar. T-1700 Thermostat. Which Buttons Do What ...
? 4:21
https://www.youtube.com/watch?v=PbfyzplRYco
Mar 9, 2013 - Uploaded by OcRefrigeration & H.v.a.c.
I will do a Video on Programming the T1700 at a Later Date. Soon. Similar thermostats include---Pv100 and the Pv110. Serving--- All of Orange ...
Oct 18, 2015 | Universal NIB LUXPRO PSP511L Digital...
I have a venstar t1700 thermostat which required a 24v transformer, hooked the two wire to R and C. Thermostats lights up and functioning. I have two wires running to propane heater a red wire and whi
R and C are the power terminals to the thermostat allowing it to run on 24 volts and not under battery power alone. Assuming that you used the R and C terminals from the propane heater to power the stat and NOT an external transformer, the W terminal on the thermostat then is connected to the W terminal on the propane heater. W energizes the heating control circuit when the thermostat calls for heat. The remaining portion of the control circuit should be prewired from the factory internal of the heater. If you do NOT have these terminals, more information is required for us to help you.
Nov 16, 2014 | Venstar T1700 Thermostat T1700
I have a T1700 in my apartment and my air want shut off and i see a lock symbol on it how do i shut it off
Do you mean a Venstar T1700 thermostat? If that is the case, the Lock symbol merely indicates that the keypad is locked to keep people from reprogramming the thermostat. This prevents anyone from quickly changing the target temperature or the swing temperature (the temperature at which the unit turns on) for the HVAC system. To unlock the keypad, press and hold the Mode button. Then press both the Up and Down arrows. Release all three buttons when the lock symbol disappears.
If the AC has cooled your apartment to a temperature below the target temperature for the current time period, then the control board of the HVAC may be damaged. (It isn't getting the message and has failed in the on position.) Contact an HVAC repair professional.
If the thermostat is indicating that the room hasn't reached the target temperature, then you should replace your thermostat. The thermistor has failed. (Contact Venstar if the thermostat is less than one year old.)
I hope this helps.
Sep 27, 2014 | Heating & Cooling
Venstar T5800 goes offline how do I Resolve it
My T5800 has firmware versions 3.1.8 and went offline. Debugging the issue, it appears that it is attempting to connect to connect.skyportcloud.com and that the DNS lookup for this address is failing. Venstar does not seem to have much in the way of customer support. The Current version of firmware for this device is VR4.08 so I may attempt to upgrade the firmware to see if that helps.
https://venstar.com/thermostats/colortouch/desktop/
Update: After updating the firmware on my T5800 to VR4.08. It is now back online. The device is now connecting to connectcl.skyport.io
Mar 25, 2014 | Venstar T5800 Thermostat With Acc0454...
Can't get the gas furnace to heat.
All York/JCI thermostats made by Venstar
The setup is probably incomplete. Did you configure the thermostat for a 2 stage heat pump? The heat pump should have a thermostat wire connected to R, C, Y1, Y2, and O, that makes 5 wires. I suspect you are only using first stage compression and or first stage blower speed.
Nov 23, 2013 | Source1 CTS Series Model S1-THPU32P7S...
How to replace battery on Totaline P474-1100RF
Complete Manual for T1100RF and P474-1100RF Made by Venstar
See picture, and yes, Lithium batteries need to be used. Alkaline may work in a pinch until you can get some Lithium.
Mar 08, 2013 | Heating & Cooling
HOW TO UNLOCK VENSTAR T 2800
how do I get the lock off the keypad
Mar 01, 2013 | Venstar T2800 Slimline Platinum...
Dec 14, 2011 | Heating & Cooling
Heating & Cooling Logo
156 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
