Question about Coffee Makers & Espresso Machines
Why is my Tassimo T65 making weak coffee? - Coffee Makers & Espresso Machines
  • 60 Answers
SOURCE: Coffee is weak
Check where the water comes out under the brew filter. It sounds like you may be missing the sprayhead. It is a round metal or plastic piece that is screwed on to the water dispense area and acts like a little showerhead forcing water evenly over the coffee grounds. If it is missing, the coffee will be weak. Check the water temperature. If it isn't hot enough, the coffee will be weak.
Posted on Jul 18, 2008
  • 2039 Answers
SOURCE: weak coffee
what does the coffee puck lock like in the dump box nice round farly hard if its like that descaled the machine with descaler not vinegar if the puck is loose and broken that the am ounth of coffee or how fine its grind the coffee let me know pierre please give a good rating pierre
Posted on Jan 16, 2009
  • 5 Answers
SOURCE: All the lights are flashing on my Braun Tassimo
Several possibilities: (1) No water in tank.
(2) Tank not inserted properly. Try removing tank and then replacing it, making sure that the hook-tab at the back of the tassimo body engages the matching slot at the front of the tank.
(3) Tank not seated properly. Try pressing down on the tank and twisting left or right. If this stops the blinking and allows your drink to brew, at least you know where the problem is. If you have to do this all the time, consider exchanging the unit.
(4) The lights will all also blink if there is residue (coffee, milk, etc) on the bar code reader window. The residue is usually plainly visible. The bar code reader window is a horizontal rectangel directly under where the bar code of the T-Disc sits in the Tassimo. To fix this, just wipe the window clean (no need to scrub), close the lid again and check for blinking.
Posted on Dec 24, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Where can I locate the part of the Tassimo coffee
You need the piercing unit, and you can find them here at Braun's parts site. Thanks for using Fixya!
Posted on Feb 22, 2010
rolyat532
SOURCE: Bunn thermofresh makes very weak coffee
I don't know what the flow restrictor looks like, but I know what a spray head looks like.
My new Bunn BTX-B brewed weak coffee also. I was wasting coffee to get it stronger. I decided to inspect the spray head. What The hey! What Spray Head? The coffee maker didn't even have one. I guess the assembler forgot to put it on. Yet it made it thru quality control. No wonder it was making weak coffee, and I was wasting coffee to try get it stronger.
Is your making weak coffee? CHECK YOUR SPRAY HEAD. Make sure the coffee maker has one on it.
Posted on Dec 02, 2012
Why does my Tassimo stop and flash refer to user manuel which I haven't got
If you put Bosch Tassimo user manual into Google you will be able to get download and print off a manual.
Mar 12, 2016 | Bosch Tassimo T65
Tip
Bosch tassimo T65 - water draining in to drip tray possible cause and resolution
I had a problem on my Tassimo T65 where water was entering the bottom drip tray through the small hole at the rear. It seems many people have this problem but after researching on line there is little help although I found on this sit how to take the coffee maker apart and from that thread the possible cause for my own issue.
So if your machine seems to be leaking from the small drain hole to the rear of the drip tray try this before you think it is either in need of specialist repair by Bosch at a cost almost the same as a new machine or before you start to take it apart and have a look yourself.
CAUSE - The water is coming from the drain hole because the pressure valve at the top of the machine is blocked with calcium deposits through prolonged use without descaling sufficiently.
SOLUTION - Purchase a good quality coffee machine descaler. Sit the whole coffee machine in a tray or large oven tray so you can collect the overflowing descaler throughout the process, it's not economical to waste this solution. Remember to clean down and dry the coffee maker each time.
Use at least half strength descaler do not water it down more than 1:1
Follow the descaling process by inserting the yellow disc and holding the start button down for 3 seconds.
Repeat this process several times, recovering the fluid leaking in to the tray and cup or container. If you start to see small lumps being dispelled in to the cup try to remove these for further descaling.
After several cycles you should notice that the leaking or flow of water from the bottom drain hole becomes less until it stops. To force the dissolving scale out of the pressure valve try running the normal clean cycle but with the descaling solution, the flow is longer and will help flush the restriction.
After a number of descaling and clean cycles the leak or flow from the drain hole will have stopped, if not continue till it does.
Note: I ran cycles for about 2 hours with periods of rest to allow the solution to do its work.
Now the leak or flow has stopped clean out the reservoir and replace with clean water and run at least 4 clean and rinse cycles.
i hope this works for you and now enjoy your coffee.
on Jul 02, 2014 | Bosch Coffee Makers & Espresso Machines
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
I do not have a washing machine, I was asking about a Bosch coffee machine; I already sent all of the information that was on the coffee machine. please look up my letter about the yellow light stayin
here is a link to manuals. If that doesn't help you, give the customer service folks a call - they are really nice To reach them by phone: 1-877-TDISCS1 (1-877-834-7271) 7 days a Week: Monday - Friday 8AM - 10PM EST, Saturday - Sunday 9AM - 6PM EST Tassimo T20 T45 T47 T55 T65 T12 User Guides Manuals For Single Serve...
Feb 09, 2015 | Bosch Tassimo TAS1000UC 1-Cup Coffee Maker
Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it
Bosch Tassimo T65 Repair Questions,... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > Bosch > TASSIMO
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it · Bosch Tassimo... ' Posted on Aug 23, 2014 ' Be the ...
Bosch TASSIMO red light water full Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/red_light_water.../tassimo
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it. Aug 23, 2014 ' Coffee Makers & Espresso Machines.
Bosch TASSIMO cleaning condensation tray Unsolved ...
www.fixya.com/unsolved_problems/...condensation_tray/.../tassimo
Aug 23, 2014 | Bosch Tassimo T65
Tassimo low water light will not reset
The problem is because Tassimo water tanks have a floating magnet in them which operates the water level switch inside the body. The magnet gets weak over time. Replacement tanks cost too much to be worth the cost. The simple answer is to stick a fridge magnet on the back of the unit (just above the power switch) using blue tack or similar (you can experiment to find the right position). Our unit has been working fine like this for a few years now. :-)
May 24, 2014 | Bosch Tassimo TAS4511UC Coffee Maker
My tassimo coffee comes out watery
Make sure you push the lid down all the way before putting the clamp down on the front.
I've noticed that the back of the lid on my vivy (t12) can get stuck up (even with the clamp down) causing the water jet to not be inserted all the way - which produced very weak coffee.
May 14, 2012 | Braun Tassimo Coffee Maker
My tassimo coffee maker is ruining the coffee it taste like water
i too had this problem BUT it was AFTER i descaled it and did the cleaning, now coffee tastes weak, and ive tried different discs (other coffees) and all come up weak.
Nov 13, 2011 | Bosch Tassimo TAS 4012 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
