Question about Dehumidifiers
I have a Hisense Model # K-J36S Serial #KJ26SJE0729 Water dehumidifier. It has stopped collecting water in the water basket. Everything else appears to be operating properly. Can you help?
SOURCE: Dehumidifier m7dh65b2a
Mine leaks. Had leaked at other times but i took the vacuum cleaner to the front drain spout, that leaks into the removable basin. That worked in the past, but i't's not working now . The water is overflowing at the back of the catch tray and leaking out through the bottom underneath. The holes are clear, so it shouldn't be doing this. I am stumped.
Posted on Aug 22, 2008
SOURCE: I have a Whirlpool dehumidifier that doesn't collect water
I have a Whirlpool dehumidifier model AD50LJ0: the compressor starts but then appears to trip out. The fan keeps running. It does not condense and water. Can you help?
Posted on Jun 12, 2009
Sheikhtijani
  • 1284 Answers
SOURCE: Danby Dehumidifier Model # DDR557HE Serial #
If you are having problems with your dehumidifier freezing up them here are a few things that you can check and also a few things that may help you.
First check the ambient temperature of the room at the level of the dehumidifier. If it is below 65 degrees and you do not have a special low temperature dehumidifier then you are asking for trouble. Most units are only designed to work in temperature 65 or higher and will freeze if they are working at lower temperatures. Some even will not work well below 68 degrees F.
Many dehumidifiers will shut off when the coil starts to freeze to let them thaw, then they will restart when the coil is warm enough again. This can take an hour or so. Some will not shut down the compressor and when the dehumidifier coil starts to freeze it reduces the air flow and only compounds the problem.
Check the air flow over the coil. If the coil becomes dirty or the fan motor stops or even slows down a bit, you will get freezing. The dehumidifier is very dependent upon the proper amount of air going over the coil to keep the coil warm enough to not freeze. Any restriction will cause problems.
The final and worst thing that can happen is for your dehumidification unit is to develop a slight leak in the refrigeration system. This will cause the coils to run even colder then they would normally and this will create the same problems. If everything else check out then you may have to have the refrigeration system checked by a professional. The problem with this is that many of these units only cost a few hundred dollars and a service call can soon add up to more then the unit is worth.
Some things that you can do to help out a dehumidifier that is freezing up are:
Raise the temperature of the room and provide a bit of heat for the room as the dehumidifier is actually a very small A/C unit.
Raise the dehumidifier up off of the floor… the air is usually warmer when you go higher up in the room, hot air rises.
Clean the coils off so that the air can flow through them easier and keep them warmer.
Make sure that the fan motor bearings are oiled and that the fan is running freely. Even a tiny bit of resistance will slow the fan enough to make a difference.
By checking all these things out and making some small changes you maybe able to make your dehumidifier work much more effectively.
Take care
Posted on Jul 23, 2010
heatman101
  • 43501 Answers
SOURCE: My dehumidifier star but not collect any water...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Oct 09, 2010
  • 4736 Answers
SOURCE: The dehumidifier is not collecting water in the
The lack of water in the bucket, may be a result of the humidity setting on the unit being to high. Try setting the level at 45% or lower. Also, be sure there's adequate air flow around the unit itself. It should remain a minimum of 12' from a wall or furniture. 24" is better.
If the above doesn't solve the problem, try this at home test. Place the unit in the bathroom, turn it ON and set the level as low as possible. Turn the shower ON hot enough to generate steam. Do not turn ON the bathroom's exhaust fan. As you exit the bathroom, close the door. Wait 15 to 20 minutes, before returning to the bathroom. When you do, turn the shower OFF and allow the unit to run for several more minutes. Then check the bucket for water. If there is any sign of water in it, it's working fine. It was probably a case of the humidity level being set to high the first time.
If there was no water in the bucket, the refrigerant gas in the cooling coils and the compressor may need recharging.
Hope this helped your to troubleshoot and solve the problem. Please let me know. Thanks.
Posted on May 22, 2011
The dehumidifier stopped collecting water. It was working great, then just stopped collecting water one night.
heatman101
Jul 17, 2011 | Bionaire Dehumidifiers
Haier DM30EA-L Serial #AJ0240E0200A99251074. Comes on and runs for a short time then goes off does not collect any water. Sometimes comes on agail, runs a little and quits again, no water collection. I...
heatman101
Apr 28, 2011 | Haier HDN655E Dehumidifier
I have a Amcor MD 250 about 5 years old..Everything appears to be correct but it is not producing water. Can you help
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 13, 2011 | Amcor MD250 Dehumidifier
Runs but doesn't collect water in basket.
It is not very humid in North America yet ...
May 26, 2010 | Dehumidifiers
0GE Dehumidifier AHM65LKM1 not taking moisture out of the air
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 23, 2010 | GE AHK65LK Dehumidifier
No water in basket
heatman101
May 10, 2010 | Friedrich D50C Dehumidifier
Jun 08, 2009 | Whirlpool Dehumidifiers
LG45EL dehumidifier no longer collects water.
heatman101
Jun 01, 2009 | LG DH404E Dehumidifier
Dehumidifiers Logo
76 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
