My fire stick remote does not work..Took out batteries replaced with others. pushed home for 10 seconds still not response Screen stuck on connect to network
  • 556 Answers
SOURCE: Sony TV keeps flipping to Memory Stick screen by itself
My sony HD TV started automatically flipping to the memory stick screen by itself. I thought maybe the remote was malfunctioning so I took the batteries out of the tv's remote as well as the cable boxes remote. Still does it. If I hit the memory stick button on the remote to switch off the screen sometimes it goes back to TV screen and sometimes it doesn't. Eventually, it flips back to the memory stick screen. Is this a known problem for this TV? your problem in system control section check aft &tuning ckt &its voltages check for loose contact in above ckt check tuner thanks
Posted on Sep 10, 2007
  • 154 Answers
SOURCE: Car is a 2006 Lexus
dealers have to reprogram.
Posted on Jun 08, 2009
SOURCE: LG Model LHT754 stuck in demo mode
hold the stop button on the receiver not the remote! for twenty seconds
Posted on Jun 16, 2010
SOURCE: logitech 890 remote
not a solution. i have the same problem with my 525.
Display: choose activity.
Bluelight usually turn on when i pick up the remote but not now after i've changed the batteries. And none of the buttons work either. Need a solution.. plz!
Posted on Aug 05, 2010
wd4ity
  • 4565 Answers
SOURCE: Attempted to start , pushed start button , engine
Ok, make sure your battery is installed and connected correctly. The connections should be clean and tight. Now, look at the end of your starter. You'll see a five sided plate with a tower like thing in the middle on the end of your starter. Just above it is a single wire that plugs onto the starter. Unplug this wire and insert a test light into the wire. Turn your ignition on and press the start button. If the light lights up, your starter is bad. If it doesn, you've got another problem.
If the light does not light up, you'll have to find the starter relay. Harley moves these things around all the time so you never know where to look for one from year to year. I'd start under the seat and then move to the side panels if necessary. The relay is a typical one inch cube made of plastic. When you find it, turn on the igntion and press the start button while holding the relay. It should click. If if doesn't, it's probably bad and even if it does, it's probably bad. I'd replace the part as it's not all that expensive.
If you suspect the starter, go back and remove the three screws that hold the five sided plate onto the starter. Behind the plate you see a plunger with a spring on it. NOW, MAKE SURE THE TRANSMISSION IS OUT OF GEAR. Using a large screwdriver, push the plunger into the starter as far as it will go. The starter should engage and turn the engine. If not, you may have to replace the large copper contacts in the solenoid.
I hope this helps you find and fix your problem
Ride Safe
Steve
Posted on Jan 02, 2011
My fire stick remote won’t respond to Alexa commands from remote
hi Douglas298.
this is all i could find.
Fire TV Remote NOT Responding / Syncing / Connecting: SOLVED I've changed the Fire TV Voice Remote control batteries 5 times already but it still keeps disconnecting and now it's gone completely dead! Update 08/02/17: The most probable cause for your Fire TV remote not working is going to be the batteries. I know, you're thinking I've already changed the batteries twice already. The Fire TV remote is a fickle beast and only likes brand new fully charged batteries before it will re-connect to your Fire TV box. I've tried switching in batteries from other devices that are all working fine, but without any success. Brand new batteries are the key for this power hungry remote.
Has your Amazon Fire TV Box or Fire TV Stick become slow? See my Fire TV Slowdown Solution here.
This need for new batteries seems to be especially true when your Fire TV box is next to a complicated TV setup with AV, Speakers, WiFi Router all next to each other.
AMAZON FIRE TV 4K
AMAZON FIRE TV STICK
If you've tried brand new out of the packet batteries and it's still not working then you might have the same issue I had below. Don't forget to ask any questions you might have in the comments beneath this article.
Update: You can now control you Fire TV Device with the Amazon Echo & Amazon Echo Dot
If you've felt the annoyance of your Fire TV Voice Remote suddenly not connecting then I know how you feel. I've owned a Fire TV since October 2014 and up to now it's handled everything I've thrown at it. This is until one day last week when the remote suddenly kept disconnecting then died completely showing no signs of life.
I went through an array of different fixes to try and get it to work again but then finally I had a brainwave and managed to bring the remote back to life. It wasn't through trawling internet blogs and YouTube videos that I found this solution, it was actually from inspecting the remote more carefully. No, it wasn't Amazon's fault for building inferior products it was actually my own fault and partly the fault of cheap pound stores that litter the UK.
When I took the battery compartment off the Fire TV remote it looked completely normal. It wasn't until I raised the remote up to eye level that I noticed that there was a slight chalky residue on the connectors of the battery compartment. It then dawned on me as I looked across the room at a packet cheap pound shop batteries. One of the cheap batteries had leaked battery acid on to the Fire TV remote connectors blocking the current from getting through.
How to use your Fire TV when the remote won't turn on?
Luckily, Amazon have an App for that called Amazon Fire TV Remote that is available in the Android App Store and the Apple App Store. You can then control the Fire TV using the app and proceed to the next step below.
How to check if your Fire TV remote is connected to your Fire TV?
To see if your Fire TV remote is connecting to your Fire TV box or dongle you need to head to the settings menu.
  1. Settings > Controllers and Bluetooth Devices.
  2. Amazon Fire TV Remotes
This will show you what devices are currently paired and from here you can see if your remote is connecting. In my case when fiddling with the batteries my remote would appear here for a few minutes then disappear.
If all else fails, you can get an official Amazon FireTV Remote replacement.
The Solution
I took a flat head screwdriver and gently scraped the connectors of the Remote at each end. Wiping the residue off with a dry cloth as I scraped. The connector should look shiny and new again at the end of this process. I placed the batteries back in and the remote connected again straight away.
I've had no problems with the remote since and I guess the moral of the story is sometimes you get what you pay for... utter leaky batteries this time.
Fire TV Quick Tips
  1. Hold down the Select button for 5 seconds to put the remote into pair mode.
  2. Hold down the Select + Play buttons together for 5 seconds to Restart the device.
  3. Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in.
  4. or try this link.
fire stick remote wont respond to Alexa commands from remote Google Search
Nov 29, 2017 | Televison & Video
How do I open the remote to replace the batteries on my Fire Stick.
To remove the back cover of the remote and insert the included AAA batteries:
  1. Rotate the remote so the top edge is facing downwards.
  2. Apply pressure on the indent of the battery door and slide upwards. ...
  3. Pull away the battery door and insert the batteries.
  4. Slide the door back into place and push in to secure.
Amazon.com Help: Remote Basics
https://www.amazon.com/gp/help/customer/display.html?nodeId=201452700 Feedback
About this result
Amazon Fire TV Stick: How To Open The Remote's Battery Door ...
? 0:44
https://www.youtube.com/watch?v=F__fFr7nZOE Nov 30, 2014 - Uploaded by The App Store Chronicle
Here's how to put the batteries into the remote for the new Amazon Fire TV: Read our review of the Stick ...
Amazon Fire TV Stick Remote: How to Change Batteries - YouTube
? 0:54
https://www.youtube.com/watch?v=sBbTLXvWjzg
Jan 25, 2017 - Uploaded by WorldofTech
I thought I'd make a quick video on how to change the battery on your Fire Stick remote since my father said ...
Open Amazon Fire TV 2015 remote battery compartment - YouTube
? 2:35
https://www.youtube.com/watch?v=FyTHjZu3L6M Oct 6, 2015 - Uploaded by sfsilicon
then once it's open you push it down. it's still a little tough okay to about this this length okay. and then once ...
Installing batteries into Amazon Fire TV Stick with Alexa voice remote ...
? 0:40
https://www.youtube.com/watch?v=cZ1tidv478M
Mar 9, 2017 - Uploaded by Richard Robinson
You would think this part of getting your new device would be easy, right? Here's my easy to follow video ...
Amazon Fire TV Stick Remote Battery Replacement - iFixit
https://www.ifixit.com/Guide/Amazon+Fire+TV+Stick...Battery+Replacement/65199 If you follow the easy steps you will successfully change the remote batteries in your Amazon fireTV stick. Step 1 Remote Battery. Use the plastic opening tool to press into the seam between the remote and battery cover. Place two fresh batteries back inside the remote and slide the cover back on
replace the batteries on my Fire Stick Google Search
Jul 31, 2017 | Televison & Video
My firestick remote wont work
1.Replace batteries.(in remote)
2.Get within 12 inches from firestick.
3.Press and hold home button for 10 seconds.
This should now pair with firestick, and should work.
Jan 07, 2017 | Amazon Fire TV Stick
When I went to settings I accidently turned off blue tooth wi fi now remote will not allow me to do anything It will not scroll off home screen
straight from amazon,reset firestick,
Please unplug the Fire TV stick from power source and then plug it again after 5 seconds.
Once the Fire TV stick is back on, please take batteries out of the remote and re-insert
Apr 03, 2015 | Amazon Fire TV Stick
Accidentally turned off my blue tooth on my fire stick now my remote will not work
1,Before you pair an Amazon Fire TV Remote or Amazon Fire TV Voice Remote, verify that the remote is compatible with Amazon Fire TV, is within range, and has the required batteries installed. 1. From the Home screen, select Settings, and then select Controllers. 2. Select Amazon Fire TV Remotes, and then select Add New Remote. 3. Press and hold the Home button on your remote for five seconds. Fire TV Stick searches for the wireless signal of the remote. After the remote or game controller is discovered, select it from the list of discovered devices using your already paired, existing remote or game controller.
Apr 02, 2015 | Amazon Fire TV Stick
Accidently turned off blue tooth
How to set up ml-l3 remote control nikon D3200
Set the camera to one of the remote modes. The quick-response remote mode fires the camera when you push the button on the remote, just as if you were pushing the shutter release button on the camera. The delayed response remote mode gives you two seconds to hide the remote behind your back before firing the camera.
See "Release Mode" beginning on page 31 of the manual: http://cdn-10.nikon-cdn.com/pdf/manuals/dslr/D3200_EN.pdf
Feb 16, 2014 | Nikon ML-L3 Remote Control
Nikon ML-L3 remote control working d7100
Set the camera to one of the remote modes. The quick-response remote mode fires the camera when you push the button on the remote, just as if you were pushing the shutter release button on the camera. The delayed response remote mode gives you two seconds to hide the remote behind your back before firing the camera. The remote mirror-up mode raises the mirror the first time you press the button, then fires the camera the second time to prevent camera shake.
See "Remote Control Photography" beginning on page 127 of the manual: http://download3.nikonimglib.com/archive1/jx33T00TFfqq00nXNhJ55CBmTl26/D7100_NT(En)03.pdf
Jan 29, 2014 | Nikon ML-L3 Remote Control
How do I get the nikon ML-L3 to work for D90 camera
See "Release Mode" beginning on page 64 of the manual: http://cdn-10.nikon-cdn.com/pdf/manuals/kie88335f7869dfuejdl=-cww2/D90_en.pdf
Jan 29, 2013 | Nikon ML-L3 Remote Control
DSC-HX5, Lens is Stuck in Zoom out mode. Turn On works but screen stays black. Automatically turns off after 10-20 seconds.
Since there is nothing you can do to fix this at home you have 2 choices, replace the camera or send it back to the manufacturer for exchange (very expensive)
Jul 27, 2017 | Sony Cyber-Shot DSCHX5 Digital Camera
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
