Question about Taylor Exercise & Fitness
After we changed the battery on our Taylor #7345 scale, it is never the correct weight for either of us. If I step on it a few times in a row, it could be 50# different! Am ready to chuck it! Help!
We have to weigh in at our local gym to know what we weigh...
errorkilller
  • 10 Answers
SOURCE: Different Weights
201.4 bcs 205.4 not correct weight its depend on u r standing position and when give weigt on u r legs then weight change and u r 201.4 bcs is correct bcs weight depend on u r happness or tension and blood speed and plz reply
Posted on Oct 24, 2008
ButtFuzz
  • 463 Answers
SOURCE: My Scale stoped weighing me, now it reads 1-ld .
The sensor has been worn out or has been pushed past it's weight limit. When you get on it, it pushed the sensor past the point of working... When she gets on it, no problemo...
Posted on Mar 16, 2009
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
  • 67 Answers
SOURCE: Fluctuating weight on Digital Scale from one minute to the next..
i believe that, like most electronic scales, the first time you get on the scale you must step off to allow it to zero itself. Then step back on to get your correct weight.
Posted on Jul 28, 2009
SOURCE: hello my taylor 5589 fat scale doesn´t work
Had the same problem with mine and sent it back since it's under warranty. Taylor did not need a receipt and I just received a new scale today, model 5742 although it cost me just about $20 to ship it back and that's UPS ground! The scale retails for $29.99 on amazon.com. Good luck!
Posted on Feb 15, 2010
Gives me diffrent weights even though I am weighing myself within seconds of time, and in the same spot on the floor.
I've found I have to weigh myself, step off, weigh myself with something in my something heavy in my hands, then weigh myself again. The 3rd weight you get will be your correct weight. If you needed the manual, I have uploaded in into photobucket...although it doesn't really address this issue.
http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
Amy
Jan 07, 2011 | Taylor 5568 Fat Scale Stainless Steel ()
THE SCALE WE HAVE IS A "TAYLOR CAL MAX BIGGEST LOSER SCALE" AND IT ALWAYS SHOWS "ERR1" WHEN YOU STEO ON IT.
When you step on it and get the err1 message step off wait a few seconds and step back on, remember that while the scale is processing your weight you MUST remain STILL.
good luck
Aug 12, 2010 | Taylor Biggest Loser 7206 Electronic Cal...
The taylor lithium electronic scale says 00 and then ERR. there is no ERR2. should i change the batteries? it never said lo.
If you get an "Err" or "Error" message, you will need to step off of the scale, wait a few seconds and then step back onto the scale.
Aug 10, 2010 | Taylor & Digital Scale Lithium Scale
When I weighed myself 4 times in a row today it read 4 different weights. Is the battery wearing out? What do you think.
hello. Definitely change the battery. Also make sure the scale is on a hard surface, not carpet.
please rate my answer as helpful. thank you.
Feb 23, 2010 | Taylor DIGITAL SCALE BODY FAT WHITE 1.0'...
Nothing will display on the read out
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 03, 2010 | Taylor Dgtl Body Fat Scale
How to calibrate a taylor scale 5571
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jun 13, 2009 | Taylor Body Fat Analyzer & Scale, Model...
display the Error.
REMOVE YOUR FOOT.
Regards,
Linda DLT
Consumer Relations
& Salter Housewares
866-843-3905
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Exercise & Fitness Logo
29 people viewed this question
Top Taylor Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Taylor Exercise and Fitnes Expert? Answer questions, earn points and help others
