Question about Hotpoint Microwave Ovens
Sears sent me a diode for hotpoint microwave and a video for replacement and the video is different. Can't find the diode for MY Hotpoint rvm1435bk01 to see if it's the same to replace.
    Sergeant:
  • 260 Answers
Most microwave diodes will work just fine from system to system. The most common ones I use are rated at 550ma. When you check your old diode what made you think it was bad? They are such a high rating you will not get a reading on it with a regular ohm meter. Mostly on HV rectifiers if it is not shorted ( Zero Ohms) it is probably good. If you have no high voltage then substitute it and see if you do get high voltage, then you know it was open. Follow the video and give it a try.
Posted on Aug 24, 2017
MicrowaveSvc
  • 9098 Answers
SOURCE: Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
  • 23 Answers
SOURCE: Hotpoint OTR Microwave - Carousel Motor Noise
You should be able to access the turntable motor if you remove the left side filter under the microwave. Disconnect the power, remove the left filter and look up inside that area, the motor may have a cover or plate over it, if so remove it, the motor will be held in with 2 screws (usually) and there will be 2 quick disconnect wires attached to it. If you cannot get to it that way you may have to remove the bottom of the microwave (underneath), should be only 3 to 5 screws holding it in place, the side to the wall will be hinged, once you pull the screws just let it hang or swing down away from you. Then follow the above directions. Make sure that you are getting the correct motor, there are two types, one is a square shaft (WB26X10037) and the other is a "D" shaped shaft (WB26X10038).
Posted on Jan 22, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: changing the fuse in microwave hotpoint mosel JES636WKo1
This model seems to have a fuse in a cylindrical white nylon fuse holder, probably located near the right rear.
It will also have a thermostat on the magnetron which may be out.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here or here.
Posted on Aug 19, 2008
jerryg50
  • 1689 Answers
SOURCE: microwave turntable does not turn
In microwave ovens, I have had the turn table motor unit become defective, or the power source to it has failed.
Jerry G.
Posted on May 15, 2009
  • 636 Answers
SOURCE: does the hotpoint microwave model # RVM1535DM1WW
Yes most of them do, take the outer casing off, should be located either were the power supply is or the control module is,
Posted on Aug 13, 2009
GE Spacemaker XL1800 not working?
  • Open internal fuse
  • Magnetron failure
  • Faulty door interlock
  • Faulty control board
Feb 05, 2018 | GE Microwave Ovens
Will not heat
make this test and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Nov 01, 2013 | Hotpoint Microwave Ovens
Fuse keeps blowing in hotpoint microwave
The magnetron is the other issue, high voltage diode will sometimes crack causing a high level short, the capacitor developes a dead short across the 2 points, the power transformer almost never fails, "very rare"
Apr 08, 2012 | Hotpoint RVM1635 Microwave Oven
Just stopped heating anything last night, it's a Hot Point Counter Saver Plus but says on inside to call GE 1-800-626-6000
On that same label there is a MODEL number that we need to show you a parts listing of what parts may have failed. Hotpoint and GE are on in the same... the only difference is the brand name on the decals. Of course they use different model numbers.... Your model number will be similar to this: RVM1435BD001 I will use that as my parts reference model number as the interal parts that may have failed will be pretty much identical.
When a microwave just out of the blue stops heating usually the either the diode or the capacitor has failed.
See items 49 and 50 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=221110
This unit also has 2 thermostats that can also cause it to stop heating. One actually controls the fan speed and the other is an over temp sensor that should shut off everything. The thermostat that controls fan speed shuts off the magnetron power on some units until the unit cools down and then it will work again.
If the magnetron has failed they usually make a loud buzzing sound when you turn on the unit from being cold. (Stuck oscillator) This can also cause the HV power diode and the unit fuse to fail.
Sears parts direct also has the parts for this unit here:
http://www.searspartsdirect.com/partsdirect/part-model/Hotpoint-Parts/Microwave-Parts/Model-RVM1435BD001/1811/0123370/G0302144/00001?blt=06&prst=&shdMod=
I change out the diode FIRST (after testing the old diode to make certain the diode has in fact failed.) I also test the capacitor while the diode is disconnected from the capacitor.
At this time I think you have a diode or a capacitor problem. If you have someone you know that can use a meter I can pass the information to them on how to test the diode and the capacitor so that you don't order parts that you DO NOT need.
If I got your model number wrong you can enter your model number on the displayed page of either link above. Or respond here with your model number and I will look up your unit.
Thanks for choosing FixYa,
Kelly
Sep 25, 2011 | GE Microwave Ovens
Hotpoint overrange microwave, all the lights and timers work not heating food. there is also a smell when trying to heat is this a common problem with this microwave?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 01, 2011 | GE Hotpoint Over-the-Range Microwave
It won't heat water,but it will turn around
Sounds like you lost your HV diode. Magnetron could be bad but these days they are pretty good. Diode costs about $5 at www.mcmelectronic.com . It is located in left side near the rear and should be straightforward replacement. Let me know how this works out. Thanks for using FixYa. Contact me if you need more info.
hardrocko
Feb 11, 2010 | Hotpoint RVM1435 Microwave Oven
Hotpoint Microwave - won't stop spinning/buttons seem to do nothi
if i understand, u say it is intermittent right? control pad get wet? it is definitely not mag, diode, cap.
Aug 19, 2009 | GE Microwave Ovens
Microwave turntable does not turn
Jerry G.
May 15, 2009 | Hotpoint RVM1435 Microwave Oven
My hotpoint rvm1425 is not heating anything up
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Mar 07, 2009 | Hotpoint RVM1425 Microwave Oven
Microwave Ovens Logo
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
