Question about Amana Dryers
Remove ball p[oint ink from drum of dryer - Amana Dryers
    President:
  • Amana Master
  • 1,922 Answers
Try lighter fluid or brake cleaner for auto brakes,but for safety sake dry well and let air out before using both are very flammable!!!
Posted on Jul 29, 2009
How to remove ink stains from dryer drum?
Try using EZ off oven cleaner. Spray on and let sit for an hour. Should take most if not all ink off
Jul 21, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Model fde336resi loose drum
There are 2 areas to check for this dryer drum. The back center bearing looks like a small trailer hitch ball which is attached to the drum. It fits into a plastic socket on the back wall of the dryer. To remove the drum, you need to take the dryer front off and disconnect the belt that goes around the drum. Then use the belt as a handle and yank up the back of the drum to lift the ball of the drum out of the socket. The plastic socket is what usually wears but you can get a complete kit including the ball and socket for about $20. While the drum is out, look at the inside edge of the drum opening. Should be a white plastic bearing strip completely around the opening.If cracked or missing replace those also. Should be 2 strips. Thats all that supports the drum in the front.
Mar 24, 2012 | Frigidaire Electric Dryer
How do i get ink out of the dryer
let it cool completely down, and use nail polish remover,, as you do,, be sure and use it on a cotton ball, and clean up any residue left over, then wash it out with a mild soap and water, when cleaning it, do a spot check to make sure its not going to remove the coating in the drum ,
Jul 09, 2011 | Dryers
Somehow a ball point pen went into the dryer. I now have ink on the inside of the drum. What can I do to get the ink off the drum. It should be noted that the dryer weny through a complete cycle before...
You may have to experiment with solvents to find one that will remove the bulk of the ink. Start with rubbing alcohol, then try a mineral spirits (paint thinner) or WD-40 oil, and finally some acetone. Make sure there are no sparks or fire nearby while using these solvents. Be sure to clean the areas with a spray cleaner after any success to remove a lingering smell. You may have some permanent stain left that will just have to wear off, but shouldn't affect your clothes. Hope this helps!
Dec 11, 2010 | Whirlpool Dryers
Dryer makes lots of noise when drying..squeaky ans sometimes a "thump"
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 07, 2010 | Kenmore 64882 Electric Dryer
Dried ink in dryer
Ask a copier repair person to give you some D-Ink.
Jun 10, 2010 | Whirlpool LER4634J Electric Dryer
Dryer is making a banging sound even when drum is empty
The dryer drum support is worn and must be replaced.Unplug the dryer. Open the top lid and fold it back. Remove the front panel,dryer belt and drum. To remove the drum pull UP on the rear of the drum. There is a ball and cup support on the rear of the drum and rear cabinet. They are worn down.
Nov 03, 2009 | Frigidaire Electric Dryer
INK PEN IN DRYER INK MARKS ALL IN DRYER HOW DO REMOVE INK
use a cotton ball with a small amount of Eucalyptus oil and wipe clean.
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 12, 2009 | Whirlpool GEW9250P Electric Dryer
Dryers Logo
52 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
