Question about Vacuums
Dirty water not going into tank, leaks out of bottom. Cleaned suction.
5 Suggested Answers
  • 14 Answers
SOURCE: 5500 model
change the filters & ensure that the water container is properly seated in the machine.If the water tank is not sealing correctly the machine will not genrate any suction.
Posted on Mar 06, 2009
SOURCE: Dirty water is not going into the tank, it's leaking out the bott
i would check the lower hose assembly. it seems they wear out where the handle closes and opens put the handle down and look in to see if its broke. if so its only like 20 for a new one and a pain to get the old one out....
Posted on May 12, 2009
  • 190 Answers
SOURCE: water tank leaks
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Posted on Oct 03, 2009
SOURCE: Hoover Agility Steam Vac has no suction for the dirty water
it is a broken suction hose i had the same issue cleaned the whole thing then i opened it up and leaned it all the way back when it sits up right it sucks it up but when you pull it back to do your dirty work the hose seperates cause its broke
Posted on Dec 21, 2009
My Bissell carpet clean will not extract water
Possible the water pump has gone out. I changed mine out it was not too hard.Also make sure the pump lines are all still attached and not clogged.This will take a little dis-assembly.
May 17, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Royal carpet extractor not picking up water well
Try to follow the suction from the machine through the dirty water tank to the front floor suction piece. Make sure the dirty water tank is seated properly. Make sure there are no suction leaks any where.
Mar 21, 2014 | Royal Procision 7910 Carpet Extractor
Suction problem
Possible Problem #1: The dirt water tank lid may be the reason the machine is not sucking up the water. There is actually a gasket on the bottom of the lid where it connects to the actual tank itself. If the lid is not put back on properly (this is really easy to do, I've done this myself many times on my Hoover SteamVac), and the gasket is not sealing the lid to the tank, this will allow the suction to leak, greatly diminishing the suction power to **** the water back up. Try removing the lid and reinstalling it, making sure that it's put back on the correct way, and try to see if this fixed your problem.
Possible Problem #2: The Hoover SteamVac's like yours have a very poorly thought out design flaw to them on the attachment hose. Where the attachment hose connects into the SteamVac when the machine's handle is lowered to get underneath furniture, and is close to the ground it puts a lot of stress on the hose where it connects into the machine (not the end the attachments go on, but the other end). This will cause the hose to tear at the stress point. This is a very common problem unfortunately, and I suspect might be the cause of your suction loss. To check this, remove the dirty water solution tank from the machine completely. Step on the handle release pedal to lower the handle part to the ground. Look at the lower part of the handle portion of the machine for where the hose enters into the handle section, then follow the hose to where it connects into the machine. Right at the end of the hose, before the hose cuff that's connected to the motor, inspect this part on all sides to see if you have a tear here. If you do, this is the reason the machine is not sucking water up off of the carpeting.
Possible Problem # 3. If neither of the first two possible problems were the source of your suction loss, try this one. Turn the machine upside down (you should probably remove both the clean water tank and dirty water tank before doing this, just to ensure that no water spills when you turn the machine over) so that the brushes are facing upwards. Look right behind the brushes for two red plastic tabs that are slightly sunken into the bottom housing of the machine. Pull these two tabs upward as far as they will go. There is a metal filter screen that will be exposed when you pull the tabs. Make sure that this screen is clear of debris. This screen protects anything from going into the motor, and if it has debris blocking it, this can cause the machine to loose suction.
Also make sure that there is nothing in the clear plastic suction channel on the top of the machine where you can see the water being sucked up. Sometimes if something gets stuck in this suction chamber, this can also cause the machine to loose suction.
Also it may be that your motor is dying, and loosing suction power. Usually if this were the case the motor would continually get louder and louder, until it just stopped working. To test this, put the machine in the upright position, and remove the dirty water solution tank. If you look at where the dirty water tank rests, you should see a circular tube underneath of where the dirty water tank sits. Here's a picture that I took, that has this part circled: Put your finger down into this suction port and see if you can feel any suction coming through when the machine is running. If there is suction, then your problem is definitely going to be one of the above problems, and if there is no suction, this indicates a more serious problem with your motor. If you don't feel suction here, you may want to consider taking the machine into a repair place, or even consider to possibly getting a new machine at this point.
I really hope that this helped you find the cause of your suction loss. If you were able to diagnosis this problem, and would like me to help you fix the cause of the suction loss, I'd be more then happy to now walk you through the repair as well. Please just use the Clarification Request form here on the same page, and I will then help you out with your repair. I just ask that if this repair was helpful to you, please help other Fixya members to find it, and rate the repair helpful by clicking the 4 Thumbs Up icons in the top corner of the repair.
Thanks,
Chris Jones
GoVacuum.com
May 11, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Why is the "dirty water" reservoir still empty after I cleaned the carpet?
There could be several problems that would cause the dirty water tank to be empty after you've cleaned the carpets. I'll try and walk you through each to help you diagnosis the problem.
Possible Problem #2: The Hoover SteamVac's like yours have a very poorly thought out design flaw to them on the attachment hose. Where the attachment hose connects into the SteamVac when the machine's handle is lowered to get underneath furniture and is close to the ground it puts a lot of stress on the hose where it connects into the machine (not the end the attachments go on, but the other end). This will cause the hose to tear at the stress point. This is a very common problem unfortunately, and I suspect might be the cause of your suction loss. To check this, remove the dirty water solution tank from the machine completely. Step on the handle release pedal to lower the handle part to the ground. Look at the lower part of the handle portion of the machine for where the hose enters into the handle section, then follow the hose to where it connects into the machine. Right at the end of the hose, before the hose cuff that's connected to the motor, inspect this part on all sides to see if you have a tear here. If you do, this is the reason the machine is not sucking water up off of the carpeting.
Thank you very much,
Chris J.
GoVacuum
Apr 09, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
It is leaking water from the bottom
I had this problem, and after some research found out I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
I purchased this gasket from Bissell for 1.39 and the suction is night and day. No more leaks. I purchased my SpotBot Bissell new at Target, so I have no idea where the black gasket went.
Jul 07, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell spotbot: leaking the dirty water from bottom. I took the bottom plate off and there is a really crappy rubber seal. I think it is leaking from there.
I had the same issue. After some research, I determined I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
This caused reduced suction, and for the water to pool at the botom of the spotbot, thus leaking.
I purchased the gasket at Bissell for 1.39. The part number is 203-6646.
I purchased my SpotBot new from Target, and never remember seeing this black gasket, but the difference is night and day.
Sep 07, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
We used our Hoover SteamVac F6207-900 for the first time today and it did not suction at all. Please help. It emptied all of the clean water/detergent as I cleaned the carpet, but no dirty water came up...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=639624
Generic problem for all Vacuums
Posted by medglen on Jun 01, 2008
We used our Hoover SteamVac F6207-900 for the first time today and it did not suction at all. Please help. It emptied all of the clean water/detergent as I cleaned the carpet, but no dirty water came up into the empty tank.
Thanks!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you may have a clog or a vacuum leak in the vacuum line. The suction should be able to pickup the water into the holding tank for you. So please feel free to contact your local vacuum dealer or you can use a wire coat hanger to try to unclog the vacuum but if that fails contact the factory or your local vac dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 01, 2008 | Vacuums
Hoover agility--poor suction, still!
When you remove the dirty water tank, on the machine, there is a screen that gets clogged and will prevent good suction, is this one clean? If it is, do you feel suction at that screen, if so then there is a problem with the tank. If no suction there, then you will have to check it over for a air leak or a bad seal.
Apr 29, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Vacuums Logo
41 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
