Question about Emerson Televison & Video
19" Emerson flat screens tv. Remote and buttons on tv not working. Tv is stuck in DVD mode. No way of even changing movies.
SOURCE: Tevion 19 LCD TV Model Number 1961HDT
eh, that should be 0871 663 1540
Posted on Jun 25, 2008
freetek
  • 5568 Answers
SOURCE: Emerson flat screen tv with red stripe
The pixels on your screen are controlled by a matrix composed of switches that turn off and on to produce light.
They are located vertically and horizontally, row-wise and must function together to produce everything from black (everything turned on so no light, or very little, can escape) to layers that represent the three colors that are used alone or in combination to produce the millions of possible shades of each.
One of the switches that controls one of the vertical columns has failed and has turned on the entire column that allows red to display.
The problem switch (a semiconductor combined with many) is permanently turned on, probably part of the screen assembly itself, and was placed with others by robots.
The pin spacing on these 'chips' is very small and often makes the assembly unrepairable.
While LCD panels have fallen hugely in price, you may be looking at a parts cost (labor is probably not too bad) that may make you decide to replace the set.
Unfortunately, the once-proud Emerson name has sadly been degraded and there is a lot of their electronics available from companies that specialize in 'refurbished' products, an indication that they have a large failure rate.
Posted on Jul 07, 2008
SOURCE: emerson tv stuck in video mode
Done - channel scan put the TV back in the correct mode
Posted on Nov 19, 2008
SOURCE: TV stuck on Video
I had this problem, I replaced the remote and it works now
Posted on Nov 03, 2009
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
How do I get out of video mode if remote will go to tv mode?
there should be several buttons along one side of the tv that work all functions . if remote is not working try new batteries
Feb 11, 2015 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
TV picture is smaller than screen, how do I make it bigger?
See if there is a "wide" button on the remote. Should scroll through the display size options
Go to menu and picture adjustments are there as well
Mar 20, 2014 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
I fell asleep on my Emerson LC320EMX 32 hdtv remote; when I awoke, the tv was flashing ONLY colors (red, black,blue,white)...Now, How do I get it out of that mode....I was told its stuck in set-mode ?
I had this problem with the LC320EMX, after extensive searching on the internet, I found a solution. The TV has entered some kind of test pattern, to escape from the flashing color test pattern do the following:
While the screen is changing from red,green,Blue,White, & Black, and is Unresposive, Take your factory remote, Press the up arrow, then the down arrow, then (ON THE TV) press the power button. Turn the set back on and it should be functioning properly. (BTW: the set gets into this test pattern if you press too many buttons on the remote, or if you use a universal remote with the wrong code)
May 31, 2012 | Emerson LC320EM8 32 in. LCD TV
Lost remote for emerson lc320em8 32 in. lcd tv, how can i adjust the screen mode to get full screen without the remote?
Hello
It is immpossible to set its screen resolution or screen size, without it remote control. Try to get one original remote control, from the authorised service center for Emerson at your town, or buy a universal remote control, which have setup codes for Emerson TV with it. OK.
Feb 09, 2012 | Emerson LC320EM8 32 in. LCD TV
Need codes for emerson tv
Here are the codes for you Emerson TV and DISH remote:
632,
672, or
846
I have provided instructions on how to program the remote to your TV:
AddressRemote to TV
  1. While at the device location (TV, etc), point the remote at the device. Press and hold the device button on the remote (TV, Aux, etc). - All four mode buttons should light up
  2. Enter the three-digit remote control code - The mode button (TV, Aux, etc.)you selected should light up
  3. Press the Pound (#) button - The mode button you are programming should flash three times
  4. Press the large, red POWER button - The device should turn off
Dec 31, 2011 | Innovage Jumbo Remote Control
I have a new Emerson LC320EMX 32" TV. The suddenly stopped working right. It will not turn off. There is no picture, only colored screens. When you change the channel it just shows a different color...
Your TV is still in the factory test mode. To remove from the tech service mode try this.To exit the service mode, grab the original remote. Press the cursor left followed by the cursor right button. Now press the off button on the remote or on the TV itself. Hope this helps. Thanks for asking and show a few hands of support!
Nov 11, 2010 | Emerson LC320EM8 32 in. LCD TV
Can't get picture to fill entire screen on Emerson 32" LC320EM1
Hi
On the remote there's a button labeled "screen mode". Depending on what you're watching this will change the screen to what you like.
Jun 05, 2010 | Emerson LC320EM8 32 in. LCD TV
Need remote code for emerson LC195emx LCD TV to program my uverse remote. ATT codes don't work. Thanks
hi! i have here a couple of codes for your emerson tv. you could try them 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037 hope it would work! goodluck!
Jan 21, 2010 | Emerson LD195EM8 19 in. LCD TV
Televison & Video Logo
46 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
