Changing the size of the picture on screen heads are cut off at he top
SOURCE: Picture too large for screen
If the television is connected to a cable box such as Time Warner's HD box, the picture mode can be changed by pressing the '#' on the cable box's remote keypad (where the channel numbers are). This cycles the picture between zoom, normal, and stretch which could be cause of your problem.
Posted on Jan 05, 2008
skotkolr
  • 558 Answers
SOURCE: picture size
http://media.onecall.com/Image_Products/Sharp/LC_GD6UManual.pdf
Please read page 39 or in your manual page 38
Posted on Nov 28, 2008
  • 362 Answers
SOURCE: The size of the picture
You need to change the aspect ratio. From the menu try the different aspect options. Sounds as if it is set to zoom
Let me know what you find.
lone99star
Posted on Jan 08, 2009
MNfisherman
  • 11896 Answers
SOURCE: Picture is cut off at the top and bottom of the
Look on your remote to see if you have a picture butto or you can try and go to the menu settings and see if you can adjust the tv format from widescreen to regular or 4:3 or 16:9
Posted on Sep 23, 2009
  • 336 Answers
SOURCE: after changing color wheel on my samsung hlr 5067w
Hi,If you are experimenting vertical lines ,black bars ,color
distortion,pixilation,or white dots on the screen you might be having an
issue with the Dmd chip.This is how the DMD chip works:
http://electronics.howstuffworks.com/dlp1.htm Basically the dmd chip
is composed of around 2 million pixels that create the image on the
screen.You will need to replace in order to fix your problem.Have a
blessed one!
Posted on Feb 09, 2010
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Picture on 47
You do not worry at all, because the set is under warranty.
Launch a complaint and sit peas fully.
Jul 23, 2012 | RCA 47LA55RS 47 in. LCD TV
Picture too big for screen; cutting off top of heads and bottom of screen
Go to the picture setup of your settings menu.
Somewhere in there are options for selecting picture size.
The options will be similar to: Normal, Wide, Zoom, Stretch
You have probably selected Zoom, try Normal.
May 18, 2011 | Hyundai Q321 32 in. LCD Television
The picture is too big for the screen...heads are cut off and guide is cut off on the top when changing channels
Change the aspect ration in the picture menu for a different apperture.
Hope that helps.
Jan 16, 2011 | RCA Televison & Video
The picture is to large for the screen. The
Try changing your Aspect Ratio, look in your manual.
Feb 09, 2010 | Televison & Video
Picture size is off center
Is this coming in signal is Free air or cables.
If it Free air u can't not adjust sub channels in most stations for screen sizes.
Aug 24, 2009 | Televison & Video
I can't see the whole picture. the tops of everyone's heads are cut off. Normal, stretch, zoom format does not fix it
check to see if tv has a function call aspect ratio
that should take down the picture size not screen size
Aug 17, 2009 | RCA F32650 32" TV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
take zoom offf on dish and the tv it sel use normal 16 .9 ,mode when u push screen in to it use 1024x768 60 hertz ok
Jan 23, 2008 | Compaq Presario 1200,1600, Series CD...
Televison & Video Logo
Top Televison & Video Experts
