Question about HP Garden
SI have riding mower with 18.5 hp briggs engine,started blowing oil out the vent on the fuel pump. took hose off of carb and it stopped. smoking a lot, checked oil level and it was good, what's up ?
4 Suggested Answers
xclubcar98x
  • 111 Answers
SOURCE: Briggs & Stratton Vertical OHV Engine 18 hp
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Posted on Jul 05, 2011
bgduff366
  • 14 Answers
SOURCE: craftsman riding mower 2003 DLT 3000 ,Blowing oil out of the fuel
Head gasket is blowed .Its building pressure in the crankcase seen it twice. Remove the head and check for a blowed out spot between piston and the valve side
Posted on Jul 29, 2012
  • 225 Answers
SOURCE: Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
Posted on Jun 21, 2009
5216 simplicity riding mower has gas going in with the oil
the needle and seat in the carb needs replaced. or if it has a vaccum operated fuel pump, the diaphragm may have a hole in it causing the gas to enter thru the pulse hose.take your air filter out and check to see if theres fuel puddling down inside the carb
Sep 30, 2014 | Simplicity "Coronet 30"" Briggs And...
Does my older lowes mtd riding mower have a fuel pump?
If it is a Briggs Twin it is part of the carb , if not it will be a vacuum pump somewhere close to the engine because it is driven by a vacuum hose hooked to the block . As the piston goes up and down the pulse of the vacuum moves a diaphragm in the pump to move the gas from the tank that is lower then the carb .
briggs and stratton fuel pump fix
May 03, 2014 | Mtd Garden
I have a huskee lt4200, engine is a 420cc OHV.
Check for gas contamination in the oil....if the oil itself it gas free....its likely a blown headgasket.
Aug 05, 2013 | Briggs & Stratton Garden
Briggs & Stratton 16HP carb small hose purpose? Have a Snapper riding mower with 16HP Briggs & Stratton16 HP V-TWIN OHV Vanguard, Model 303777 Type 1145-A1 4750 Code 97021011. It started...
Should go to the valve spring access cover. Is the PCV line and keeps engine from building up pressure internally.
To clean the carb you will have to remove it from the engine and give it a through cleaning with small diameter wires run through the ports and blowing out the gunk with low pressure air or WD40's little red tube. From your description, you need to do this as the ports are clogged and not letting proper amounts of fuel through to the engine.
good luck.
Sep 16, 2012 | Tools & Hardware - Others
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
John Deere LA125 riding mower, three years old, 84 hours, Briggs 21 hp engine. I mowed the lawn. I cleaned the machine with a water hose. Now, IF it starts it will die after about 10 seconds. I took the...
Bought a new John Deere LA125 IN 08 only has 106 hrs on it, maintained it to a tee, changed oil etc, now it smokes, blue smoke, smells like burning oil, it does this when i rev up or down or when theres a load on the engine, but doesnt smoke all the time, i chaanged my plug which was amazing it would start it has the 21 horse briggs and stratten engine. Any help appreciated.
May 09, 2011 | Garden
I have A craftsman riding mower 18 1/2 hp 42 inch deck have changed spark plugfuel filter took off tank and blowed it out but the mower still cute off after about 10 minutes like it has no gas what else...
Do you have a Briggs or kohler engine.I am having the same problem.I have changed the fuel filte, fuel pump, and cleaned the carb.Sears has been no help at all.The reason I ask about the engine you have is that people are having the same problem no matter what engine they have.So therefore it probably is not the engine so it is something else on the mower.My mower runs fine for about 10-15 then starts to stutter and backfire.I am continuing to pursue this problem and I will post back here if I come up with anything.
Jul 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower 2003 DLT 3000 ,Blowing oil out of the fuel
Jul 29, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
Top HP Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a HP Garden Expert? Answer questions, earn points and help others
