Can you add purex crystals and oxy10 to the wash? When do you add it before the wash or during the wash?
Whirlpool repair manual pdf
iGOODS Dell Jaipur
iGOODS Dell Laptop Exclusive Store in Jaipur Get Best Price For Students and Professional Call@9649926999
Showroom Add-: S-9, Basement Royal
Bazar ,Crystal Court Malviya Nagar,
JLN Marg, Jaipur 302017.
Call-:0141-5105799, Mobile-:91-9649926999
Office Add-: 192, 1st floor, Jaipur Stock
Exchange Ltd.BLDG Malviya Nagar, JLN
Marg, Jaipur 302017
Call-: 141-4003675,5103675
Mobile-: +91 9649989999,9828068025
Email-: igoods.jaipur@gmail.com
Visit us- http://www.dellstoreinjaipur.com/
Dec 10, 2013 | Washing Machines
Tip
Hubby followed your directions. WOW, found 3 PUREX washing sheets in the drain....
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Oct 01, 2010 | Kenmore Elite 45986 Front Load Washer
Tip
Fantastic info here, we are back up and running. |||| Consumer Tip ||||| Our...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F02” error code.
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. Check the drain hose to make sure it is not kinked or clogged.
  2. Check the electrical connections to the pump and ensure the pump is running.
  3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
on Dec 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to wash
Crystal should be washed with mild soap (like Ivory) and lukewarm water.
1. Line the bottom of your sink with a couple of dish towels.
2. Fill with lukewarm water and add *mild* dishwashing liquid.
3. Wash one item at a time.
4. Rinse with solution of lukewarm water and vinegar, 3:1 ratio.
5. Dry with soft cotton or linen cloth.
Items will spot if allowed to air dry.
Oct 05, 2012 | Washing Machines
Even though I keep the door open when not in use it smells when actually in the wash cycle. How can we fix this as it is embarrassing.........
Hi and welcome to FixYa. I am Kelly. The yellow line is usually a resul of iron particulate in the water the machine uses. There are a few thing you can try to clean the machine.
You will not find this one in any manual.
Put one cup of bleach and 1/4 th cup "dishwashing powder" straight into the tub and run an empty or "cleaning rags cycle" with HOT water. You can add the juice of a freshly squeezed lemon or use lemon concentrate also with that. You may initially have to do this for 2 to 3 cycles to get rid of the iron deposits. After that you should use one of the products below before returning to reugular wash cycles.
There are other producs out there that you should use per their directions once a month.
http://www.affresh.com/#/home
and http://www.tide.com/en-US/product/tide-washing-machine-cleaner.jspx
Also make sure you using HE washing machine detergents vs regular washing machine detergent. Here is just one example:
http://www.purex.com/detergents/ultra-purex-he
Thanks for choosing FixYa.
Kelly
Jul 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer leaves a yellow line on my white clothes
Put one cup of bleach and 1/4 th cup dishwashing powder straight into the tub and run an empty or "cleaning rags cycle" with HOT water. You can add the juice of a freshly squeezed lemon or use lemon concentrate also with that. You may initially have to do this for 2 to 3 cycles to get rid of the iron deposits. After that you should use one of the products below before returning to reugular wash cycles.
Kelly
Jul 22, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Strong musty damp smell - tried soda crystals, vinegar etc and nothing shifts it. any ideas?
Try a full bag of soda crystals on a hot wash...and then add them regulalrly. They are not a deodoriser but will help clear the gunk that is causing the smell. Bicarbonate of soda is a better deodoriser though.
Mar 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Clothes re: towels smell like mold!
sounds like high lime in your water, try Purex pouder with renewzit
Jan 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Flame blow back in an outdoor propane fired unit causing thermal fuse to open. fails Intermittantly How to fix?? suggestions please
Add a high wind stack to ensure positive vent pressure. It is a seperate option available from whomever in your area carries Purex heater parts.
Oct 20, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Washing machine smells when door is open
Hi, set your machine to 60 degree wash, add 1/2 a cup of Washing Soda Crystals and run the machine with no washing in at all...
Your drain will sparkle. All the gunge will be cleared from the door seal, and your washer will be lovely and clean...
Add 1 desert spoonful of Washing Soda to every wash... I sprinkle it along the crease in the door seal.
There was black spotted mold festering for ages and little by little this is disappearing and the washer is keeping lovely and clean... and my drain, which was always gungy and collected leaves, is now really clean and the leaves dont stick anymore, so easy to clear away.
Washing Soda Crystals come in 1kg bags and cost around 50p from most supermarkets... They stock it at Asda, Sainsbury's and Morrisons for deffinate.
All the best
sue
Aug 03, 2008 | Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
