Question about Leader Garden
I was given a Underwood Leader 10 key manual adding machine by my father who used it in his store. The model number reads 789 and serial number is 765434. I'm just trying to find out date produced.
SolutionGuy
  • 331 Answers
SOURCE: What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
Posted on May 02, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: lennox serial number - how to read
This may help. http://www.lennox.com/pdfs/Lennox%20Model%20and%20Serial%20Nomenclature.pdf
Posted on Feb 24, 2010
SOURCE: setting the time and date
To set the date, make sure that you are in Rate Set. type in the date such as August 3, 2010 would be entered as 08.03.2010 then press the date time key. This will set the date. To set the time type in the time such as 4:20 PM would be entered as 16.20 then press the date time key and this will set the time.
Posted on Aug 03, 2010
lock123
  • 6831 Answers
SOURCE: Autodesk Maya 2010 Key serial number where
Hello
Unfortunately we are not permitted to provide serial numbers in accordance with our terms and conditions and the DMCA copyright laws.
If you bought the product legally you should contact the manufacturer. The contact details should be on the side or back of the box or CD cover.
I hope you understand. Feel free to contact me if you have any questions.
Kind Regards
Andrea
Posted on Sep 29, 2010
SOURCE: How to set time/date, welcome mess. on 1184 model Bell South ans. machine
For BellSouth model 1184 digital answering system:
To set day and time, hold down "time/code" button for a few seconds. Press "time/code" again to select what you want to change. To adjust the day, use the forward and backward arrow buttons to scroll through the days. When you find the correct day, press "time/code" again, and this will allow you to adjust the time. Again, use the arrow buttons to scroll through the hours, minutes, and am/pm, pressing the "time/code" button to set the correct selections and move onto the next setting option.
Posted on Oct 21, 2010
What is the difference with Leader 725 bike with 8 digit serial number or one with a letter + 10 digits ?
If you post this query in a forum dealing with bicycles, someone may be able to help you. This forum is for Cameras.
Jul 11, 2017 | Leader Cameras
What year was my Underwood Universal Quiet Tab typewriter made? The serial # is B2600688.
http://typewriterdatabase.com/underwood.4.typewriter-serial-number-database
Apr 21, 2015 | Office Equipment & Supplies
My husband has an old Orbit Machine Tools drill press, model OR1412. Any idea where he can get an owners manual?
Looked it up on Internet possiblely found need serial number go to www. Milwakee.com
Dec 05, 2014 | Drills
Maytag M# fav6800aww top loader major problems
Marco;
You have a Clutch malfunction read this post Clutch Fix. You may be able to get away with just a Clutch One-Way Roller bearing clean up and re-lube. What are the first two numbers of your Serial Number it will be 10 thru 17?
That is your Series number. Series 10 and 11 from what little feedback I have received from FAV6800A/FAV9800A owners use the upper bearing ring you will see described in the Clutch Fix post.
Here is where the Serial number is located if you haven’t already observed. Thank you for calling out your model number. This board is structured very poorly for not asking up front info of model number and serial number. Let me know if I can help…..Rich
Mar 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I need an unlock code for a clarion car radio i have been given, model number PU 2325A serial number CL0410Z0136440? Any one help me please? Thanks
and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also  has a BARCODE SERIAL NUMBER beginning with
C7000000 + + + +  on a label somewhere on the metal casing.
If not then it will only be available from  your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Jan 24, 2010 | Car Audio & Video
Reset users pin
Settings for the Administrator Mode 1 Call the Utility Mode to the Display. ❍ Calling the Utility Mode to the Display (p.7-1) 2 Making sure that ?U--? appears on the Display, enter ?5? from the 10- Key Pad. 3 Press the [Start] key. Input Account Procedure (A-2) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?2? from the 10- Key Pad. 5 Press the [Start] key. 6 Enter the 3-digit account number from the 10-Key Pad. ? Do you know the restrictions on entering the account number? ➜ The account number must be in three digits ranging from 001 to 999. ➜ If an account number entered already exists, the entry will be rejected. Enter a different number. 7 Press the [Start] key. This stores the account number. ✎ Tip To program another account number successively, repeat steps 4 through 7. Using the Utility Mode 7 Di152/Di183 7-21 Delete Account Procedure (A-3) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?3? from the 10- Key Pad. 5 Press the [Start] key. 6 Press [ ] or [ ] key to select the account number to be deleted. 7 Press the [Start] key. The selected account number will be deleted. ? Do you know what to do to delete another account number? ➜ Repeat steps 4 through 7. 7 Using the Utility Mode You can go to the Konicaminolta US web site and down load a operators manual for youself
Apr 23, 2009 | Minolta Office Equipment & Supplies
Garden Logo
Top Leader Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Leader Garden Expert? Answer questions, earn points and help others
