Question about Sewing Machines
I have a empisal AE 390 slimline, all of a sudden it does not want to make a stitch...Please help
Myy machine is suddenly sewing as if it is doing a tacking stitch is it bobbin tension or something else wrong
Not sure what you mean by "tacking" stitch. Are the stitches exceedingly long like a basting stitch? That would need a stitch length adjustment so stitches are closer together.
Or, do you mean the tension is loose between stitches? You can try tightening the top tension to see if that helps. (Be sure to ALWAYS RAISE the presser foot when threading the top thread so the thread will seat completely in the tension disk or you may end up with lots of top thread showing under the fabric.) If the bobbin thread is too loose, you may need to adjust its tension.
Understanding Thread Tension Threads
Feb 27, 2018 | Sewing Machines
Empisal creations and episal EXP889 sewing machines.... which is the better one and more recent model
It really depends on what You envision yourself doing with the sewing machine and then finding the machine that has the most functions that fit your needs.
Empisal 889:
  • 36 Stitch functions
  • Front load bobbin
  • On/off switch
  • Left and middle needle position
  • 18 Stitches
  • 4 Step buttonhole
  • Stitch width control
  • 4.5mm Maximum stitch width
  • Soft cover
  • 4.5mm Maximum stitch length
  • Reverse stitch
  • Twin needle
  • Free arm
  • Carrying handle
  • Uncoupling bobbin winder
  • Clip on, clip off foot
  • Drop feed
  • Sews on buttons
  • Zipper foot
Empisal Expression 889 Sewing Machine Empisal Sewing Machines
Empisal Creations
  • 4 Step buttonhole
  • 19 Built-in stitch patterns
  • Oscillating hook
  • Sews on zips
  • Adjustable stitch length: 0 - 4mm
  • Adjustable zigzag stitch width: 0 - 5mm
  • On / Off swithch
  • Free Arn
  • Accessories
  • Reverse stitching
  • Horizontal spool holder
  • Self uncoupling bobbin winder
  • Cover on accessory compartment
  • Large working surface
  • Thread cutter
  • Adjustable presserfoot pressure
  • Built-in tension
  • Darning plate
  • Fold away carry handle
  • One touch snap on foot
  • Versatile utility stitches
  • Sews through heavy fabrics
  • LED lighting
Empisal Creations Sewing Machine Empisal Sewing Machines
https://www.russells.co.za/empisal-creations-sewing-machine
Dec 11, 2017 | Sewing Machines
Manual Empisal Slimline AE390 please and I need the assesories that comes whith the machine
sorry we do not have that nor do we know what was to come with it .search through Google
Jan 26, 2017 | Sewing Machines
What is the tension settings on the empisal model S4D
Tension on sergers will vary based on the type of stitch you want to create. For basic overlocking, the tensions are usually set at the midway point. However, every machine is different, so some tweaking will most likely be required to get the stitch where you want it.
Empisal S4D Instruction Manual
Nov 03, 2016 | Sewing Machines
Can a Empisal Electronic Overlocker 760DE do topstitching?
Thats a 4 thread serger, you cant do a top stitch unless its a 5 thread
Sep 19, 2014 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
