Question about Plumbing
Water is not coming out of faucet on our Arbor faucet. The first one we had leaked so we returned it for another one and no water comes out!
  • 68 Answers
SOURCE: Single handle Pioneer shower faucet
its the mixing slide in there its stuck u can take it apart at the handle it pulls out shake it if it doesnt move its bad. what happens is over time sediment gets in there and seazes it up. if you take it apart and its not stuck then its ur mixing valve on your boiler is bad good luck
Posted on Dec 21, 2008
SOURCE: water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
Posted on May 23, 2009
  • 6674 Answers
SOURCE: hot water comes out lukewarm
Pop out center of handle, and remove the screw from center, and remove handle. There should be a little nylon gear like sleeve that will pull out from center. Pull it out, and rotate it one way or the other, a little at a time, and slide it back in. Now just slide your handle on long enough to try it, no need to attach with screw yet until your done. May take a few tries to get it where you want it, then simply put handle back on, secure it with the screw, and snap cap back over screw.
Posted on Jan 06, 2010
  • 11 Answers
SOURCE: just installed shower and faucet in bath tub when
Depending upon which valve you used and how it was plumbed, you may need a twin elle or a specific part to match the ROHL pressure balance valve. if your second outlet is plumbed off the bottom of the valve, you need 18" of pipe between the valve and the outlet. Anything shorter than this and you can have back pressure issues.
Posted on Dec 18, 2014
  • 3 Answers
SOURCE: the hot water stops coming out of faucet
Similar problem on a two-handle Rohl faucet. Hot water running for a minute, then all of a sudden the flow stops with a "thud". Strangely, this won't happen if cold water is turned on at the same time. Turns out hot water flow is restricted by an 90 angle valve (I was hoping to save some hot water) and the faucet somehow created a vacuum in the line and shut itself off. Problem solved by opening the supply line valve fully.
Posted on May 20, 2015
Neither the wave sensor nor the ready sensor will turn the water on.
I would return back to the place of purchase and get a different brand of faucet.
Dec 05, 2015 | Moen 7594EC Arbor Single Handle/Hole...
No water
No water, there is a host of problems that can cause this.
1. no water to the faucet
2. Sensor is not working
3. clogged water port
4. Dead battery for sensor
Does the faucet work on manual mode?
If not remove cartridge and check for debris. Flush out faucet before replacing cartridge to make sure water is getting to faucet. Replace cartridge. Check debris screens on pull out handle. There are a number of other things that could be wrong but first try the simple and report back on your findings.
Mar 20, 2014 | Moen 7594ESRS Arbor Single Handle/Hole...
How do remove the faucet cover of a moen 7594EC
MOEN Motionsense Faucet Leaking????
Turn off the water valves beneath the sink. Cover the openings to both the drain and the garbage disposal. Use an allen wrench to remove the tiny screw holding the handle in place. Once the handle is removed, the leaking is most likely from the seams around the large plastic nut behind the metal-like plastic cover. You might be able to see water dripping from around the big nut. Remove the nut and wrap nylon plumber's tape (Costs probably around a buck at any hardware supply store) around the threads for a much better seal. Wrap the tape tight at least a couple of times around the threads.
Screw the nut back into place with your hand, then tighten with a wrench.
Place the cover back over the assembly, install the handle. You can apply clear nail polish on the threads of the tiny allen screw that holds the handle in place to minimize the risk of it coming loose and falling into your garbage disposal.
Jan 19, 2014 | Moen 7594EC Arbor Single Handle/Hole...
We had to turn off the water to our house to fix a leak in a pipe in our attic. When we turned the water back on, no water is coming out of our two danze faucets. Everything else in the house works fine....
remove the aireators and then turn the faucets on to see if they work, the aireators is the where the water comes out and there are screens in there that may have gotten plugged with debris.
Sep 15, 2013 | Danze Plumbing
Water meter keeps running. When I turn off the water supply to the hot water tank the needle on the water meter stops, does that mean that I have a leak in the hot water pipe coming out of tge tank.
Yes you have a leak on hot pipe or TP overflow tube.
Put ear against pipe to listen for sound of running water.
If TP valve goes into drain line, check if water is running down TP overflow tube.
Check each faucet for leaks.
If pipes are under slab, put ear against each faucet to determine which faucet is closest to broken pipe.
Mar 23, 2013 | Water Heaters
When water is turned on, water leaks from faucet and hot/cold water handles but when diverter is engaged the shower works fine with no leaking from the handles or faucet. I have a three handle system. Any...
Write down the type and model of faucet you have. Most hardware stores have rebuild kits for faucets.( washers, rubber o-rings and or gaskets) You will have to turn your water off and do some minor repairs.
The kits come with step by step directions.
Dec 13, 2012 | Home
Cold water is leaking on to hot side causing luke warm water
i have a 7570 salora that took the top off and i can't get it back together right
Feb 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Moen kitchen faucet set wsprayer can't shut sprayer.
there is always water pressure on the sprayer when water is on. if sprayer is leaking check if trigger is stuck in . best to just change the sprayer handle it comes off at the base of the handle
Jul 20, 2009 | Plumbing
Plumbing Logo
179 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
