Question about Car Audio & Video
I know where the wires go but my stereo was ripped outta my dash and it pulled wires out of the plug that goes into the back of CD player n don't know where they go does anyone have a picture of that plug
  • 132 Answers
SOURCE: wire harness diagram
www.scosche.com will give you the cars wires, u may want to just by a harness adapter, cutting wires=bad
Don
Posted on Jan 02, 2008
shaggyrat
  • 1224 Answers
SOURCE: connect ipod to cd player wit built in aux input.
solution to ipod problem some ipods do not work in directly with after market sterios some do now a good solution is to go to your local radio shack buy the rca jack one end proper male femal connectors on one end then head phone jack on the other this will play anything its just like the old days when you had to buy that clunky tape with head phone jack attachted it works all the time make sure ipod is powered so that it wont loose power while playing its kinda old school stuff but works since most ipod products dont work with aftermarket sterios
Posted on Apr 21, 2008
SOURCE: No harness plug that goes into the back of my stereo
go to ebay and search this exactly the way it is wrote. ISO Wiring Harness connector/adaptor for KENWOOD 12 Pin
Posted on Mar 22, 2009
  • 9 Answers
SOURCE: just need to know which wire goes where
orange is normally illumination(not necessary) other is probably cell phone mute
Posted on Jun 12, 2009
  • 132 Answers
SOURCE: I would like to know the wiring conections for the
All name brand radios have a standardized color codes coming off the harness.
Yellow- Constant
Black- Ground
Red- Switch power
Blue- Antenna
Blue/white- Amp turn on
White- Left front +
White/black- Left front -
Gray- Right front +
Gray/white- Right front-
Green- Left rear side
Purple- Right rear side.......the black stripes are your negative speaker outputs.
Posted on Apr 06, 2010
Replacing radio with an after market cd player in a 1999 ford au sedan jjust need to know what color wires what on the car
  • You did not list the model of Ford Sedan you are inquiring about. Here is a link that has quite a lot or car stereo wiring diagrams http://www.modifiedlife.com/request-a-ford-car-radio-stereo-wiring-diagram/ Look at the upper right of the page and scroll down a little bit as I have it on Ford vehicles already. Find the make and go to the year.
  • That being said if I can make a suggestion. I have hooked up hundreds of car stereos in my life. When I pull a factory radio I don't use the same wires that powered that factory stereo to power the after market stereos, DVD players etc. I go into the dash and find suitable wires a little thicker gauge to handle to often more powerful output of the aftermarket stereos.
Regards, Tony
May 20, 2011 | Car Audio & Video
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Thanks
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
How can I remove the radio CD from dash of 2004 F-150?
Look carefully at the plastic frame that goes around the stereo. Figure out if it's one piece or two pieces etc... You are going to have to remove the trim around the stereo and then you will have access to the screws that hold the stereo in place. Don't force the trim, it may be held with a screw that you don't see right away. Pull the stereo carefully because there are wires plugged into the back along with the stereo antenna. You don't want the antenna wire to fall down behind the dash, it can be difficult to retrieve. Just remember where all the screws came from. Take a digital picture before you start if you have one available to you.
Apr 17, 2009 | Car Audio & Video
Jan 12, 2009 | Durabrand Car CD Player and AM/FM...
Im trying to get my nintendo 64 to work on my avic d3. i know i need a power inverter, what else do i need? also, do you know where the red white and yellow plugs from the nintendo 64 goes into the d3?
the red white yellow wires plug into the rear of the unit (white and red RCA will go into video or aux input) the yellow wire will go into video in (the red and white RCA from Nintendo they can go into either video 1input or aux input) on back of in-dash unit
hope this helped
Dec 15, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Dash Board Light's
verificaste que ese no va en el control de intensidad de iluminacion?? el control que esta debaj de la ventanilla de aire acondicionado del piloto....
Nov 14, 2008 | 2001 Hyundai Elantra
How can I replace the stereo of a 2002 dodge caravan with 2001
The whole front plastic cover over the stereo and heater controls is screwed in with two screws at the bottom of the cover, just above the cupholders. Take out those two screws and then pop off the cover, which is held in place by clips up the sides and at the top. There are four bolt/screws that hold the radio/cassette/cd (whichever you have) in place. Unscrew them and replace the stereo. Plugs SHOULD fit, and if they do just replug it and you're good to go. If the plugs DON'T match up, get a wiring harness from Best Buy or Walmart.
But be warned! Just because the stereos look VERY similar and fit very nicely into the other spot in the dash, they may NOT have matching wiring plugs. I just put a 2003 Neon CD player into my 2002 Caravan, and the harnesses didn't match up and neither did the antenna.
Nov 11, 2008 | 2002 Dodge Grand Caravan
Stereo removal
you will need to unscrew your dash and pull off the front plate of your dash, then you will need to unscrew the stock radio, then you will need to go ahead and pull out the adapter from the back of your radio. Next you will need to attach your adapter harness to your car harness and splice the color coded wires to the harness on your new cd player.After that, you will need to plug your antenna back into your new cd player, Note that some cd players will require an adapter, these can be found at circuit city or at your local car dealerships.-Shocker
Sep 07, 2008 | 2006 Pontiac G6
Installing CD Player
i supose the am fm radio just dosnt cut it anymore well lets give this a try . first u must disconnect positive battery cable so you dont short any wires . remove screws that hold in factory radio pull radio out a feww inches as no to rip out any wires.next you must locate positive 12 volt power supply wire usually red or orange .if not shure connect battry cable again and use a 12 volt test light by attaching the ground cable on the test light to a good clean metal bracket under dashboard or connect to a black groundwire with a screw into the steel under dash next probe the wires goin into the factory radio ur looking to find power 12 volts once you have found the correct power wire use tape and mark it this will be the power wire for your new stereo next u must figure out what wires for what speakers osually 2 wires per speaker 2 rear speakers and 2 front speakers meaning a total of 8 wires follw me so far ? now disconect car battry again so not to have sparks and cut or disconnect remaining wires speakers first label all with tape and mark front right front left rear left rear right there is a + and - the wire with the stripe on it is usually the + the other wire is the - being negitive ground . this operation is important in order for your fade ballance controlls to work properly now with your new cd player inhand look and see what wire is gonna be 12 volt most times its red with a fuse eg white plastic connector small fuse inside there it a must proper fuse to protect new cd player now there will be a black negative this will go to the matal ground area under dash close to where cd player goes into dash red to the orig taped 12 volt supply now ur spks one pos+ and one neg or common to each speaker now make all conections with stereo before you push stereo into dash you must hook up car battry leaving cd player hanging out so you can make wire changes if you wish on the speakers you need to use one pos front right or rear right + with one common or neg black - to the spkr the same common or ground or - whatever its called one common or neg can be used for all spkrs .good luck tape and solder all connections after you feel all is good im sorry this is all the help i can offer you be careful
Jun 12, 2008 | 1978 Ford Granada
Wire harness diagram
Don
Nov 21, 2007 | JVC KD-S680 CD Player
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
