Question about Dryers
Where can I get a Viscount Deluxe dryer heater element?
    Top Expert:
  • Dryers Master
  • 45,036 Answers
Fixya does not sell dryer heater elements and is unable to suggest sources.
Posted on Aug 13, 2017
My dryer will not heat up
Could be switch broken, heater elements or wiring broken.
Nov 06, 2014 | Crosley Dryer Heater Element Replacement...
HOW DO YOU CHANGE THE HEATING ELEMENT ON A WHIRPOOL DRYER MODEL LE7000XTW0
The heating element is on the back side under the dust cover.
You gotta remove a strap at the top of the heater chamber and then you can get the heater assembly out. Remove the filter and raise the top:
The element is on the right
The heater
the heater element slides out after ya remove a screw at the base.
Service Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 29, 2011 | Whirlpool Dryers
Krups Sensotoast Deluxe -- Stopped working!!! Checked outlet. Not the problem.
Did the same to me
The ceramic heater to wire connection broke off
not a prayer of fixing it
The heating elements are in a series circuit, so as goes one element, so goes both elements.
Aug 06, 2010 | Krups SensoToast Deluxe 4-Slice Toaster
No heat, but dryer turns.
There are three common causes of a dryer not heating. First is a busted heating element. Second, the thermal cut-off has blown. Third, the high limit thermostat is not working.
Disconnect power to the machine and remove the screws at the bottom of the lower front access panel (toe panel) holding it in place. Pull the panel down and off the cabinet. You now have access to the heating circuit.
Remove the heater shield by removing its mounting screw and pulling it off the heater housing.
The heater terminal block is located at the left opening of the heater housing. Disconnect the wire from one of the heater terminals and measure the resistance of the heating element using an ohmmeter set to X1. The resistance should read 7.8 -11.8 ohms. Replace the heating element if the resistance reads open.
Disconnect the wires from the terminals of the heating element and remove the screw securing it to the heater housing. Slide the busted heating element out of the housing and install the new heating element. Secure it with the screw and put the terminal block in place. Connect the heater wires and reinstall the heater shield.
Slide the lower front access panel up into the cabinet and secure it with the screws.
Feb 28, 2010 | Kenmore Elite HE4 Electric Dryer
Procedure to replace heating element on 84152 electric dryer
This is a simple repair. Just follow these steps:
1. UNPLUG dryer. Dangerous voltage is still present even with the dryer turned off.
2. Remove the dryer vent exhaust hose and remove the back of the dryer.
3. The heating circuits are located on the right hand side (as viewed from the rear). The heating element is located inside the heater box. Simply remove the mounting screws on the heater box and remove the two wires on the heating element terminals. NOTE: You can leave the two remaining components (Thermal Cut-Out and Hi limit Thermostat) connected on some models. If you need to remove them in order to remove the heating element make sure you label the wires.
4. Locate the mounting screw(s) on the outside of the heater box that hold the heating element in place.
5. With the mounting screw(s) removed the heating element will slide out of the heater box.
6. Insert new heating element, making sure you avoid touching the coil and align the screw holes so you can reinsert the mounting screws.
7. Re-install the heater box and any remaining components.
Now...are you sure you have a bad heating element? Just because a dryer does not heat, does not necessarily mean the heating element is bad. The following link explains:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
The most common fail item that causes a dryer heating circuit failure is a blown TCO caused by poor dryer ventilation. Just something you may consider.
If you have any questions, please let me know. I hope you find this information helpful.
Aug 22, 2009 | Kenmore 84152 Electric Dryer
Electric dryer not heating...works fine, but no heat
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Jun 04, 2009 | Roper RGS7646KQ Gas Dryer
Just quit drying clothes
If it does not dry them all then the element is a good guess or the thermostat.
If it dries them but not all the way check that the moisture sensor is not turned down too far.
The following should help you.
How to Repair Heating Elements A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Troubleshooting the Gas Heater
In a gas dryer, heat is provided by a gas heater that is controlled by an air shutter. The gas heater is generally the source of no-heat or drying problems. You can often correct such problems by adjusting the air shutter on the gas burner, which is located along the bottom of the dryer.
To adjust the shutter, take out the screws and remove the panel that covers the gas flame. Turn on the dryer so the flame is burning. If the flame has a deep blue color and you hear air whistling around the burner, the air/gas mixture is receiving too much air. If the flame has a yellow tip, the mixture is not receiving enough air. Turn the thumbscrew or loosen the two screws slightly to increase or decrease the flow of air to the burner. Keep turning until the flame is a light blue color, without any yellow, and the whistling stops.
Gas dryers use an electric ignition device rather than a pilot light to light the gas heater: An element becomes hot and glows like the filament in a lightbulb. Electric ignition systems are always sealed; you can't adjust or repair them. If an electric ignition device fails, call a professional service person for replacement.
©2006 Publications International, Ltd.
In a gas dryer, heat is provided by a gas heater, controlled by an air shutter.
Electric dryers have self-contained electric heating elements.
Servicing the Electric Heating Elements
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher than 20 ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
The heater may also malfunction because it's grounded. To test for this, set the VOM to the RX1 scale and remove the leads to the heater. Clip one probe of the VOM to a heater terminal and touch the other probe to the heater housing. The meter needle should jump to a fairly high reading. If the needle flicks back and forth at a low reading, the heater is probably grounded and should be replaced. Here's how to replace the heater:
Step 1: Remove the back of the dryer. If necessary, also remove the cabinet top.
Step 2: Disconnect the leads and remove the screws that hold the duct in position. Then lift the entire heater unit out of the dryer.
Step 3: Remove the screws that hold the heating element in the duct.
Step 4: Slip the new heating element into the heating duct the same way the old one came out. Be careful not to damage the resistance coils. Replace the screws that hold the heating element in the duct, reconnect the leads, and screw the unit back into position.
Servicing the Fan
The most common dryer fan problem is lint clogging the air passages through the heater and through the dryer drum. To clear a clogged air passage, remove the back service panel of the dryer and back out the screws holding the air duct in place. Then reach into the duct and remove all the lint and dirt possible. Reassemble the parts.
Also inspect the fan for a loose screw connection where the motor shaft is set on the dryer's drum. Remove the back service panel, tighten the screw, and replace the panel.
May 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer: pye2300ayw
yes, it will. you should be able to take off the panel on the bottom of the front of the dryer. way in the back is the heating element. do not put your hands in there with the power on, but start the dryer and look in there and you will see if the heating element comes on. it will be like looking inside your toaster.
Oct 27, 2008 | Maytag PYE2300AY Electric Dryer
Kenmore gas dryer 110.97566200 gas dryer is running throught the cycle but no heat.
Your Heating Elements could have problemA dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Aug 04, 2008 | Kenmore 63942 Dryer
Dryers Logo
Top Dryers Experts
