Question about Garden
The sound bar won't stay on - Garden
My sound bar itb382b switches sources on its own. Any idea why it won't stay on source we choose?
if you are using a remote that is the same or similar to the brand name of your sound bar then particular buttons my trigger your sound bar to change devices for example when you change the channel on your TV with your TV remote it might trigger your sound bar to change as well. this is common for infrared receivers
Dec 08, 2014 | iLive ITB382B - 37" Bluetooth Sound Bar
I plug my tv in the light stays green it turns red sometimes it turned on last night the light was red when it was off turns green when its on I plugged it in now won't turn on but the light is green
It sounds to be a panel fault. Contact any service technician, and make it sure. If you wish to get some screen-shots about faulty displays http://electronicshelponline.blogspot.com/ check this link. Pull up previous posts there, either by its left side bar, or view it in Timslide option.
Jul 01, 2013 | Televison & Video
Klipsch soundbar (SB1) won't power on ... green light on power adaptor seems to trip and go off when I power on the SB
I have read that this may be due to the order in how the AC adapter is attached to the sound bar. After some research I found that you need to unplug the AC adapter from the wall and the sound bar and let it sit for about 15min. Then flip the power switch "ON" on the sound bar and connect the AC adapter to the rear of the sound bar. Lastly, plug the adapter into the power outlet.
Feb 21, 2013 | Klipsch Audio Players & Recorders
My towel bar won't stay tight
maybe you need new screws in the bar?
Nov 30, 2012 | Delta & Soap Dispenser
WIPERS WON'T STAY ATTACHED TO RUNNER BAR
once the pivot sockets are warn out you need to replace them
Aug 30, 2012 | 2000 Isuzu Rodeo
Bernina 630 pressure foot won't stay up. What do I do?
Make certain that the foot is firmly attached to the bar. If that is the problem (it won't stay in place on the bar) you may need a new or different foot.
Feb 07, 2018 | Sewing Machines
Doors won?t stay up
95% of all problems with “droopy” doors can be solved simply by replacing with a set of the correct, proper struts, which we can be supplied by DMC. Unqualified persons should never attempt to adjust the torsion bar(s) as severe personal injury and extensive physical damage are possible.
May 19, 2008 | 1983 De Lorean DMC-12
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
