Question about Vocopro Televison & Video
Vocopro DVD Duet multi function won't turn on
  • Vocopro Master
  • 384 Answers
Here is the repair manual good luck!! it will explain to you what procedures you need to do to see if you either can get it running or call a qualified professional to repair it !!
http://appliancejunk.com/forums/index.php?action=downloads
Posted on Aug 12, 2017
2 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: vocopro dvd-duet model, doesn't recognize
You must clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
Now, if no cables are disconnected, and if you can verify nothing is touching the TV or DVD chassis, you can plug in the unit and check if this helped the player to "see" again. Most of the time you can check as is, though on the combo units you're going to have to slide the chassis assembly all the way back into the cabinet to get it to work because the cables are often too short. If this didn’t fix the problem, please read on.
Other things to check
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc.
f the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit.
Also, in a DVD/CD player there are many complaints where the disc gets stuck inside of the unit. This could be as described earlier, but there’s also what’s called a drawer/disc tray opener and closer mechanism to contend with. On many models, old and new alike, there’s a small belt that goes bad and wont let the tray open. You can usually put your ear very close to the front of the unit and, if this is happening, hear the motor spinning when you press the eject button. Another cause is the nylon gears, which can get jammed up with dirt and dust. Also, in other cases, you could have a motor problem, or the driver IC could be at fault. If you suspect that the motor is at fault, simply measure the voltage on the tray motor while pressing on the eject button. If the voltage comes up between 6 to 12 volts, depending on the manufacturer, then the motor needs to be replaced.
Alignments
If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Posted on Jul 15, 2008
Clean cd-g lens
You can purchase a cd cleaning kit with instructions to clean the laser lens.
Jul 08, 2012 | Vocopro DVD-Duet 80W CD / Dual Cassette /...
I picked up a vocopro karaoke machine at a yard sale and the echo makes a loud hum also i need a owners manual and remote where can i get help with this. model#890G thank you
Hello. For the manual and remote your best option is to search online. As far as the echo goes, this is just a cheap microphone with a cheap system. It will not go away unless you turn the volume down on the system. If you want to put good money down on a nice SHURE brand microphone it will definitly help with the echo, however it will not make the system any better.
Apr 17, 2011 | Vocopro DVD-Duet Multi-Format Karaoke...
My speakers make a humming noise when i use the microphones
It's feedback! You need to move the speakers further away from them.
Feb 19, 2011 | Vocopro DVD-Duet 80W CD / Dual Cassette /...
It says no disc when you put in a CD.
Please clean your lens with lens cd cleaner and retry
Jan 13, 2011 | Vocopro DVD-Duet 80W CD / Dual Cassette /...
My cd player frequently ails to read the cd and recently the audio goes in and out.Its a Fleco.
Try CAREFULLY cleaning the CD reading lens with a Q Tip moistend with 91% isoprophyl alcohol... DO NOT use rubbing alcohol.
Check if your CD's have fingerprints or other contamination. Clean those with windex and a soft cloth rubbing ONLY outward from the center, NOT circular.
Dec 27, 2010 | Vocopro DVD-Duet Multi-Format Karaoke...
I have a Voco Pro Model DVD-Duet. The problem is when you put a cd in the little center knob is stuck down that keeps the cd on tract it looks as if someone has pushed it down and it want come back up so...
It is possible the carriage that the CD goes in does not lower onto the center hub rather than the hub being too low.
The carriages move by a small motor and often there is a belt that slips so carriage doesn't move. Replacing the belt is usually required.
Working on the CD drives is very tender fragile work so you should take this to a repair shop. Contact the manufacturer for a recommendation.
Feb 19, 2010 | Vocopro DVD-Duet Multi-Format Karaoke...
I need a schematic for the vocopro entertaner model no HKH000011
You might try emailing the service centers listed here and see if you can get lucky:http://www.vocopro.com/servicecenter.php
Jan 23, 2010 | Vocopro DVD-Duet Multi-Format Karaoke...
It does not play all the CD , VCD , it s CD player has gone bad.
its happaning because of bad optical lence.
please replace it.
nuwan.
Jan 16, 2009 | Vocopro DVD-Duet 80W CD / Dual Cassette /...
Televison & Video Logo
29 people viewed this question
Top Vocopro Televison & Video Experts
Afolabi Bello
Afolabi Bello
Demonic-2011
Demonic-2011
Donald Pera Deane
Donald Pera Deane
Are you a Vocopro Televison and Video Expert? Answer questions, earn points and help others
