Question about Cell Phones
Nothing is working on my 6.0 ph0ne no menu, no messages, noredial nothing
How to change nokia c7 mms settings
Press the Menu key.
2. Tap Messaging.
3. Tap Options.
4. Tap Settings.
5. Tap Multimedia message.
6. Tap Access point in use.
OR1.From the Front Screen press the Menu button.
2.Tap on Settings.
3.Select Applications sett.
4.Select Messaging.
5.Select Multimedia message.
6.Select Access point in use.
7.Select 3MMS.
Jan 21, 2013 | Nokia C7 (8 GB) Smartphone
Pls help me. .h0w t0 reset my security c0de? My ph0ne is n5000d-2 . .imei is 354840022376645
I have generated the master code for you, try using this code: 4370322012,
Please post another comment if the code didn't work.
Jul 02, 2011 | Nokia Cell Phones
Brother MFC-3360C error message ''PRINT UNABLE 4F .....''
Hi there
Brother 4F is this have a go it could work for you.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Apr 21, 2009 | Brother Multi-Function Center MFC-3360c...
Ink catridges want work
Try this to reset the unit:-
1) Disconnect power cable
2) Press # and 6
3) While holding buttons connect power cable
4) After you see a message on the screen release the buttons.
5) If you still get the error message, powercycle the unit.
6) You should get a message to select your country and language settings, when you see this reset should be completed.
You might have to try this a couple of times, others seemed to.
HP website link here for ref:-〈=en&cc=us
Jan 24, 2009 | HP OfficeJet 6110 All-In-One InkJet...
just go to menu initial setup than full reset setting enter code 000000 (Regards Paljor Lama)
Aug 08, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Replace Transfer Roller
In the Phaser 6250 Color Laser Printer Service Manual (which I had to have emailed to me from my toner supplier since it is not available to the general public) I went to Chapter 6 - Error Messages and Codes. I had to reboot the printer. Here is the procedure.
Entering by rebooting the printer:
1. Turn the printer power OFF
2. Hold down the Back and Information buttons simutaneously and turn the printer
back on.
3. Continue to hold the buttons until the following message is displayed on the front
panel: Service Diagnostics V#.##, Initializing ....., and then release the buttons.
4. The front panel displays the Service Diagnostics Menu.
On the display is a menu. Find Transfer Roller. Press enter on this menu where it says Toner Waste (Not Full). Back out of the menu.
All of a sudden the machine came to life. You may have to turn off the printer and turn it back on again.
Good Luck
Jun 10, 2008 | Xerox Phaser 6250 Laser Printer
"secret menu" doesnt work.
Sounds like you are doing it right, but just to make sure:
  1. Press (but do not hold) the menu button.
  2. Press (but do not hold) the "0" button. This should bring up a "Service Menu" box with 6 question marks.
  3. Press the "0" key 6 times.
As far as I know, this is the only way to get into the service menu.
Feb 25, 2008 | LG VX8300 Cellular Phone
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
