Question about Brother PE-150V Computerized Sewing Machine
Brother p150 lcd screen is blank and locks machine when pe basic card in inserted
I have saved my design on my pe basic card. I verified the hoop size etc... I turn my machine off and insert my design card, when I turn the machine on the lcd screen in blank and the machine will not do anything. Help.
  • 184 Answers
SOURCE: 180E Hoop problem
Joan, there are 3 micrositches on your embroidery unit arm. these switches are depressed when you attach the hoops, it appears from your comments that one switch is not functioning. This could be simple, it is out of alignment or more complex it is broken. Either way you need to take it to a professional for repair.
Posted on Feb 25, 2008
  • 184 Answers
SOURCE: bernina deco 600
Sorry to inform you but your machine only sews 4" x 4" . The arm on the machine can only move 4 inches up and down and 4 inches left and right.
The size of the hoop does not affect this. If you have a multi position hoop you can sew multi 4 x 4 areas without re hooping.
Posted on Feb 28, 2008
  • 110 Answers
SOURCE: Futura CE-200 Stops in middle of design and says wrong hoop size
Dear cjnations
Firstly we must all remember that the CE200 is a very particular machine and requires that you follow certain procedures in order for it to run smoothly. When using the small hoop, firstly you must make sure that the small hoop is selected on the screen by going to Tools, Select Hoop & clicking on small frame. Once this has been done and the design selected, you must then attach the small hoop before sending the design to the machine. If you attach the hoop after sending the design, the machine will give you the error message.
Good Luck!
Posted on Nov 17, 2008
  • 152 Answers
SOURCE: I'm using the Mega Single Hoop for the Viking
1. If the design came from the internet or a design package, it's possible that it's "center" has not been centered properly. To correct this you need to open the design in the Husqvarna Viking software and click on the "Center in Hoop" icon. That function redefines the center of the design so it will align properly in any hoop that it fits within. If you have 3d software, after clicking on that icon you physically have to put the black crosshair that designates the center in the design, in the very middle of the hoop and then save the design to your computer, then send it to the machine. The 4d software automatically centers the design in the hoop when you click on the icon.
If you have the software and you "combine" any designs together you must always click on the center design icon to recalculate or redefine the center position and then move the design's center to the middle of the hoop before saving the design. This way you center the designs center positoin around the needle position. Meaning that when you hit the start button on the machine, where ever the needle is, is where the center of your design is.
I hope this helps
Posted on Oct 15, 2009
  • 1116 Answers
SOURCE: Have a se270d and just purchased ped basic. Put
Check the design size and format.
The 270 is limited to a 4 x 4 hoop and the design must fit inside this measurement without the foot hitting the hoop.
The format must be pes
Posted on Mar 13, 2010
  • 2069 Answers
SOURCE: Brother 770-PE I have Amazing Design software and
well, from what is indicated in the USB manual for your Brother, check that none of the below issues is causing this.
- Ensure that USB media contains data for no more than 200 embroidery patterns since Embroidery patterns cannot be transferred to the machine if the USB media contains data for more than 200 embroidery patterns. If this is the case, reduce the number of designs saved on the USB media.
- if the embroidery designs contain too many colors (this number may vary within the designs themselves), it may not be possible to transfer an embroidery pattern to the machine, even if there are less than 200 embroidery patterns that have been saved on the USB media. In this case also, reduce the number of designs saved on the USB media.
- Save the patterns in the root directory of the USB media. If embroidery data is saved in a folder on USB media, that embroidery data cannot be retrieved by the machine.
thanks for using fixya
Posted on May 27, 2011
0 characters
1 Points
Totally confused by my machines and these cards!!!! Please please please help
In the software you have to go to "Options" and adjust the "Design Page Property". If it is set to a size larger than what your machine is capable of stitching, the machine will not be able to read the card.
That setting has little to do with the size of the embroidery you are saving, it is more to do with telling the machine how big a hoop the design will be using.
That's why one machine reads the card but not the other machine (hoop size capability).
Mar 22, 2014 | Baby Lock Sewing Machines
A high pitched sound comes out of machine when inserting card.
I'm new to embroidering and mine did the same thing a few weeks ago. I discovered the buzzing sound was because the design I saved to the card was too large. I decreased the size and the design worked perfectly.
May 18, 2013 | Brother PE-150V Computerized Sewing...
Have a se270d and just purchased ped basic. Put designs on card and put card in machine, but it won"t read the card at all. No error message or anything, but it does recognize there is a card present....
Mar 12, 2010 | Brother SE-270D Computerized Sewing...
Nothing happens when i insert any of my embroidery cards
You have used these cards before?
The designs are pes format and 4 x 4 or less in size?
Page 40 of the manual states to turn the power off when inserting and removing memory cards.
Feb 15, 2010 | Brother PE-150V Computerized Sewing...
Blank Card, PE Design says it's a ''read only''
Hi - I think the problem is that although the Magic Card is compatible with your machine, it is not recognized by with the PED writer. I have the Brother PED-Basic sfotware and a Brother PED-Basic USB card writer box. The only blank card that the my Brother reader can read is the blank cards made by Brother. Which embroidery machine do you have (not critical - I'm just curious).
If you have both a Magic card and Magic Box, the box should have it's own software. I don't think the PE Design software recognizes non-brother equipment (bummer). The link I've provided below is to a dealer that sells two different blank Brother Cards. One of the cards is 1 mb. The other is 4 mb. They are the same price. You might check your documentation to see whether both cards are compatible with your reader and software. If you're not sure, you can call the dealer directly and ask. I have dealt with this dealer many times and find that they have great prices and are very knowledgeable. This link should take you to the page on which the blank Brother Cards are displayed - scroll down if you don't see them right away.,20
This dealer is located on the East Coast, so you probably won't be able to reach them by phone until tomorrow. I don't know of a dealer on the West Coast to whom I can refer you. One more thought - Babylock equipment is often interchangeable with Brother equipment. If you have a Babylock dealer in your area, you might be able to find a blank Babylock card that you can buy off the shelf. Just make sure you can return it just in case it won't work.
Let me know if I understand your situation correctly - if not, send me another comment and I'll be happy to research further. BTW - if it turns out that you can't use the Magic card and can't return it, you can probably sell it online.
Thanks for getting back - I really love doing this. If you have general questions about embroidery, feel free to ask. I own several consumer embroidery machines, and I operated a commerical embroidery business for several years.
Feb 05, 2009 | Brother Sewing Machines
PED basic card
I haven't got the 600 buyt I do have a Bernette Deco and when I save designs on my USB stick I have to ensure they are saved to a particular folder in the stick. Perhaps there is a similar type of requirement?
Apr 07, 2008 | Bernina Bernette Deco 600
Unable to read original card
I called brother and I had set the hoop size to the wrong demension. I had it set for a 5X7 hoop and my machine uses a 4X4 hoop, It works fine now. Hope this helps you
Jan 27, 2008 | Brother SE-270D Computerized Sewing...
check the hoop dimension size that is set when you are saving to the card. mine accidentally got changed to the larger hoop size and as soon as I changed it back to 4x4 it worked fine
Nov 05, 2007 | Brother SE-270D Computerized Sewing...
Connecting to a computer
Are you asking how to connect the Brother PE-400D sewing machine?  You have "how to connect the '4000D' to a computer and what risk if any".  Which machine are you asking about - these are two different sewing machines.  If you are inquiring about the Brother PE 400-D, then your answer is... this machine is NOT capable of being connected to a computer.  However, if you wish to purchase or download embroidery designs from the internet, you may look into purchasing the Brother PE Basic. This allows you to download embroidery designs from the internet to your computer hard drive and then load them on to a Brother memory card.  The Brother memory card can then be slipped into the proper slot for the memory card on the sewing machine.  You will need to purchase embroider designs that are in the PES format for you Brother machine to read it.  Hope this helps!
Oct 31, 2007 | Brother Disney PE-400D Computerized Sewing...
Brother PE-150V Computerized Sewing Machine Logo
225 people viewed this question
Top Brother Sewing Machines Experts
Bargain Box
Bargain Box
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
