Question about Home
What replaces the kidde model 1275 smoke alarm
frcs68
  • 1605 Answers
SOURCE: 1 chirp every 30 seconds
it is not the battery problem, you need to get a replacement.
the circuite board is bad.
Posted on Dec 02, 2008
szanti
  • 36 Answers
SOURCE: kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Posted on Sep 28, 2009
  • 13 Answers
SOURCE: kidde smoke alarm won't stop chirping
Most smoke detecotrs have a limited lifespan of 5-10 years. On the underside of the detectors should be a sticker with installed dated or replace by date. If changing the batteries doesn't stop the chirping it is most like time to replace the detector. If you check the manufacturer website they will give you a life expectancy for your detector.
Posted on Mar 23, 2010
  • 13 Answers
SOURCE: I just fixed a new Kidde alarm hardwired with both
The normal condition for the green LED is solid. A flashing green LED indicates memory of a prior alarm condition. Press the test for at least 2 seconds to reset the detector memory.
TeaCii
  • 90 Answers
SOURCE: Smoke alarm keeps bleeping
Here are the steps:
Was this always like this? If not, change the batteries, clean it up. Consult the local fire dept. The help for free.
If that does not work, you will need to get it serviced/repaired.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Posted on Apr 23, 2010
How can I change battery of smoke alarm model 1275?
If this is a Kidde 1275CA alarm, then grip the outside and turn it to release from mounting bracket, then on the underside is the battery housing to be slid off to replace!
Dec 29, 2014 | Home
My Kidde Model 1285 keeps chirping even after I changed the batteries, any ideas why?
Be sure you are using a well known brand battery. The store brands, in my my opinion generally are not quite up to par. Try this and see if the chirp will stop. Thanks for asking me.
Dec 21, 2014 | Kidde 1275 Hardwire Smoke Alarm with Hush...
My Kidde Frynetics 1275 smoke alarms started going off intermittently. (Slower than when there has been smoke in the house from the oven). THere was no fire and no smoke. Not sure why?
Make sure to only use a brand name alkaline 9 volt battery. Don't use a used battery or a dollar store battery (bargain store). Then press the test button for 10 seconds to reset this unit and any more down the line.
Oct 28, 2013 | Kidde 1275 Hardwire Smoke Alarm with Hush...
No, I didn't find what I was looking for, an answer to the following question. The Kidde Ionization Smoke Detector 1275 is electric only as it has no battery backup and it continues to chirp after the...
The 1275 does have a battery backup according to the manual on the Kidde website. Try this URL to get a copy of the guide:
https://portalgb.knowledgebase.net/al/15121/16372/article.aspx?aid=295779&tab=browse&bt=4&r=0.1818646
Aug 04, 2011 | Kidde 1275 Hardwire Smoke Alarm with Hush...
How can I make my kidde 1275 stop chirping. We've changed the batteies
if the batterys are good then there is a fault in the supply from them to the board
Dec 24, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Kidde Smoke detector 1275 continues to chirp. I located the detector and opened it but I can't get to the battery. Please help
When you say you opened it, what do you mean? The unit should come off the trim ring and expose the bottom which I believe is where the battery is located. Just so you know, if the unit is more than 10 years old the entire unit must be replaced per NFPA 72.
Sep 19, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Kidde smoke alarm won't stop chirping . I have replaced the batteries and nothing seems to fix the problem
Mar 21, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Hello I have a KIDDE FYRNETICE smoke alarm.
According to the Kidde website, this unit was discontinued in 2010. If the unit is more than 10 years old it must be replaced per NFPA 72 (assuming you live in the US)
Dec 22, 2009 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
