I want to set up my guest house with Wi-Fi using a Wi-Fi extender is this possible?
    Top Expert:
  • Computers & ... Master
  • 12,744 Answers
Buy a booster look up on line or any store that sells computers or cell phones
Posted on Aug 12, 2017
  • 48 Answers
SOURCE: about wi-fi
Windows XP has a built in wifi configuration tool, previous versions of windows dont have this feature. But if you were to buy a wireless card it comes with software for wireless to work on all versions of windows from 98 - XP most if not all new laptops have wifi built in & that will be able to share your broadband connection through the netgear router. You can configure the laptop & pc to share files & printer between each other, easy way of doing that is by using the wireless network setup wizard which can be found in Start -> All Prograns -> Accessories -> Communications -> Wireless Network Setup Wizard.
Posted on Feb 10, 2008
  • 54 Answers
SOURCE: dna-a211-1 adsl2+ wi-fi modem
What type of policy u want to configure?
Posted on Mar 18, 2009
  • 126 Answers
SOURCE: want 2 use both ethernet as well as wi fi simultaneously
u can use both things 2gether.u have to configure ip at both places,on lan n also on wifi
mail me for further help
Posted on Apr 16, 2009
  • 1606 Answers
SOURCE: No wi-fi signal on Palm Lifedrive
Ok first thing to know is if the LD is detecting networks at all. Tap the wfif icon and hit the scan button. If you see a list of available networks that means its working and the problem is the settings.
I'm assuming that it is detecting the network from your description.
The LD supports WEP and WPA so you have other options if nothing else. WEP is nice and simple (most of the time anyway)
On the scan find your network tap edit, Make sure the SSID is correct, Make sure that it says WEP under scurity and then tap the key box where is says assigned.
Now this is the bit that makes or breaks the connection. Make sure the key type is set correctly. You have three choices hex, ascii or passphrase. Most wireless router just use the first two.
You need to make sure that this is set to exactly the same as the router.
For ten digits that means you are trying to use 40-bit hex which is not the easiest but it works sometimes. Ascii tends to go a lot easier and I would suggest you consider switching over the ascii to avoid the headaches. I don't know why the LD does not want to work all of the time when using the hex key but it does seem to have problems. Assuming you have the hex key matching exactly as per the one you have in the router it should work. Should but sometimes just won't. Check your cases and make sure you are only using the basic ascii set not the extended. Stick to number and letters and you should be good.
I have never had a problem with the ascii or passcode but usually do not have much sucsess with the hex setup even when it is correct. I've assumed that it was something I've missed but have not had these problems using other devices.
Posted on Jul 09, 2009
SOURCE: Trouble connecting ipod touch to password protected wi-fi
Settings->General->Reset->Reset Network Settings.i did this on my touch 3g & it started working!
Posted on Sep 27, 2009
My smart TV has home wifi but is intermittent. Router is in the next room. Tv can find Belkin but then my house wifi is unticked. Does it not work for a smart TV? Why does it switch off my wifi?
Your set may have a defective wi fi detection circuit that is causing all the grief. I had to return a laptop for this reason.
Maybe the signal is weak - try raising the router as high as possible off the floor and also try putting a deflector behind the router to direct the signals in the direction of tv set to maximize strength.
Sep 11, 2017 | Belkin Computers & Internet
How to set up Belkin 300 wi fi extender
Follow our step-by-step guide to Set-Up Belkin Router Wi-Fi Range Extender Call 1 800 335 8177 How To Set Up Belkin Router Wi Fi Range Extender. We are available to fix issues and errors of our customers 24*7 with in a span of time.
Call us: 1-800-335-8177 (Toll-Free)
Sep 28, 2016 | Belkin Components Belkin - Ieee 802.11n...
My kindle cant connect to internet
Go to the Settings Menu, Select the Wireless & VPN option and see if you are in Airplane mode, if you are turn that off. Then select Wi-Fi. See if Wi-Fi is turned on. If it's not turn it on. There should be a list of available Wi-Fi routers. If one is not selected select one that is open or that you have the password to. If none are open or they are locked and you don't have a password, you'll need to get a password for one, or install your own Wi-Fi router.
Jan 13, 2016 | Amazon Kindle Fire HD
N300 Daul-Band Wi-FI Range Extender
call time warner cable and they can help you set it up for free.
Jun 11, 2014 | Belkin Components Belkin - F9K1111 -...
Can not get wifi on different rooms of the house
Many basic wifi connections are too weak to surmount dead spots in a house. Read this to discover what your options are, possibly a better gateway/router.
Jan 25, 2014 | Acer Aspire One D270-1865
Lost password of working wi-fi conneciton
Will likely have to reset you router and set it up again. Check you manual on how to do this.
Dec 29, 2013 | Westell Wirespeed VersaLink...
How do you change the channel
I think first you need to setup wi-fi and enter the SSID code. setting wi-fi in iphone and ipad are all most same process..
Here is a blog to setup iphone and ipad with wi-fi
Apr 08, 2013 | Belkin Play N600 Wireless Dual Band Router...
How do I get my password so a guest can use my wi fi
assuming this is your personal home wi-fi : find your wiless router manual... access from your browser by entering the ip address (refer to your manual)... go to your wireless security setting - some times you all you will see are just series of dots - (some do have a check box below that will let you see actual characters) if not just set up a new password. If you set up a new password you would have to update all computers that connects to your wi-fi w. new password.
Oct 10, 2010 | Computers & Internet
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
