Question about Psi Garden
Would you have the instructions for the crasher Brigg Stratton 2200 PSI 2.1 GPM series 500 158cc. Bought in 2008. If possible in french. Thanks a lot
sandyka77
  • 58 Answers
SOURCE: Need English instructions
Please check this website and download the instruction manual.
Posted on May 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 31, 2009
Dolfoff
  • 148 Answers
SOURCE: i just bought a 2nd hand honda excell psi max vr
Have a helper hold the trigger of the wand open while you try it again. If it starts that way you have a sticky unloader valve in the pump. DO NOT RELEASE the trigger for more than 10 seconds if the engine continues to strain when released! If the engine doesnt run freely when you let go of the trigger, pull it again and shut down the unit!
Add some power steering fluid to your supply hose (about 3 or 4 ounces at a time) and restart the unit with the trigger pulled. Allow the oil to flow through the pump for 1 - 2 minutes for each treatment. Several treatments should make the pump and valve happy again.
Hope this helps.
Posted on Sep 28, 2009
SOURCE: 2200 psi husky briggs and stratton pressure washer
After a long none use, I tried to wash my driveway and powered on the washer,it did, but when i tried to engage the power washer by pressing the wand lever, it did not engage. What can I do to get the power washer working?
Posted on Jan 30, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Blue Max high presure washer, 2200 psi.
Hi Greg. Walk into your nearest Lawn Mower parts supply with your engine model number (usually on the recoil) and they will have the replacement part or repair your old one. It is less expesive to have the old one repaired unless the support struts have broken. 2200 PSI should have a Honda GX160.
engine:
Here is another source....
http://www.northerntool.com/shop/tools/product_200327175_200327175
They can range from $32.00 to $68.00 depending on source.
Honda PN is: 28400-ZH8-013ZA (do net search this number) Or call your local Lawn Mower repair Supply with the number.
If you have a Briggs & Stratton engine I will need the ENGINE model number off of the air shroud just above the spark plug.
Thanks for using FixYa.
Kelly
Posted on May 04, 2010
Testimonial: "yes - your info was helpful Thanks Greg"
I HAVE AVANGUARD 9HP PRESSURE WASHER NEED TO KNOW PSI @GPM OF THIS
most rarely exceed 2600 psi as these can blow right through your hand..gpm maybe 40-45..there should be a plate with all that on the unit..
Jul 10, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
engine:
Kelly
Apr 05, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Where X = a number.
Aug 31, 2009 | Briggs & Stratton Garden
How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Aug 25, 2009 | Briggs & Stratton Garden
Garden Logo
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
