CHECK MEMORY - Computers & Internet
My phone has 212 mb free memory,and 3.1 gb on memory card,i have memory problems since i have gotten it two years ago.recently had it reformatted by eurocon,israeli nokia agent.i do not have many programs...
Hi Ellen,
Your problem seems to be rather unusual as I have used the eseries for a long time and have never had a memory problem like yours. Though a google search seems to suggest otherwise. I am suggesting a few things that you cross check and set on your phone which should eliminate these problems. This is how I have setup my devices and it seems to work on them.
  1. Check that your applications are installed on your memory card instead of phone memory. If not then please reinstall them there. Check settings for each application to ensure that it uses the memory card instead of phone memory. The only applications that I have installed on my phone memory are those that cannot be installed on the memory card. Check settings for your camera and music as well. Only your sms messages and your contacts are allowed to occupy your phone memory (as it is faster) everything else that is optional goes on the memory card.
  2. Check software version of your phone and update it if there is a new version available.
  3. WhatsApp: Check settings to ensure that all your messages and files received on whats app are stored on your memory card.
  4. SMS: Check sent items and drafts. Limit Sent items to 20 or 40 only.
  5. Email:
    • Email settings should be for upto a maximum of 7 days. Make sure it syncs your important folders only. I suggest 3 days for you right now. You can always increase it later.
    • Email application should be updated. Check from here
Keep restarting the phone (to clear up the memory) and checking the usage after each important item (such as shifting from phone memory to memory card in whatsapp) so you know which one was the culprit and you know what to avoid in the future.
I hope the above items help.
Feb 18, 2012 | Nokia E72 Smartphone
Insufficient memory File: zedgec.c Line Number: 91
Probably it's vitrual memory problem Check memory assigned for vitual memory.
Check your RAM, might have a bad memory stich
Oct 13, 2011 | Computers & Internet
While playing music player it shows not enough memory
Like computer, your phone need space to run applications /programs ( chaching). It seems you phone need more free spaces ( if there is no virus, on the phone). To get more free spaces, you need to move some programs/ applications/ files from phone memory to card ( if any). Otherwise you need to delete some files on phone memory.
Best luck
Sep 06, 2011 | Nokia 2730 Cell Phone
"Memory low. Delete some data from phone memory" message comes frequently. I have nothing installed on phone. Even I can't back up in PC suite
Yes may be you have not installed any application.But check message folder,contacts in phone memory,the files in gallery,which are located in phone memory,check memory status in file manager.etc If you found delete it or make back up to memory card.Lastly,check the memory card because the inserted memory card might be exceeds to the instructed expandable memory.
Aug 13, 2010 | Nokia E71 Smartphone
Mobile unable to read memory card and giving information that "memory card not formatted"and then sain"operation failed" pc is also unable to detect
Initially check whether the memory card is working fine.To ensure it use it in other mobiles.If the memory card is working fine means remove any password set in memory and check in your mobile.Then check the memory card in your mobile if the problem persists Memory card IC is the problem.
Most probably the problem is the memory card .
Jun 29, 2010 | Cell Phones
When i insert memory card in the camera it says reinsert memory card
check memory card with your pc...if it works fine there then get your cam checked from local service center
Oct 09, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Phone memory full delete data.i have a 2gb memory card
Your memory is full. It is now fully occupied. Try increasing the memory or try to free the memory by deleting objects.
Sep 07, 2009 | Nokia N95 Cellular Phone
Get Memory card not inserted
simply check the memory card through card reader if it works then u have to check the socket of phone where the card is to be inserted..
that one is causing problem...may be its pins are not propely being connected with the memory card..
if  the card doesnt work even with memory card reader then the card is faulty...or if u dont have memory card reader just put your memory card in another compatible phone to check..
or get another card and put it in your phone for checking..
hope it will fix the issue so dont forget to rate it...
Jul 06, 2009 | Nokia 5800 XpressMusic Smartphone
3 beeps - Base 64 K memory failure
  • Reseat the memory.
  • Make sure that the contacts on the memory and the socket are clean.
  • Try removing one bank of memory modules at a time. Note: Some systems might need to have a memory module in Bank 0.
  • Try using RAM chips from the same manufacturer with the same part number and speed.
  • Check for a faulty memory module by trying the memory in a known good system.
  • Trying known good memory in the system.
  • Check the power supply and check for power fluctuations.
  • Swap the motherboard.
Feb 23, 2008 | Computers & Internet
N73 me
try worked!!!!!!!!!!!!!!!!!!!!
take a backup of all u need n memory card...
remove memory card from the cell
go to lifeblog application then mark all and delete them...
then put back memory card and check it!!!!!!!!!!!!!!1
the lifeblog application eats up memory
Dec 19, 2007 | Nokia N73 Cellular Phone
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
