Question about Jenn-Air 7920P202-60 Jennair Cooktop
What is causing my Fisher and Paykel OR61 Duel element to on work high heat when turned on?
Likely a bad resistor Unit, I suggest replacement before it gets worst and possibley causes a fire.
May 27, 2014 | Fisher and Paykel CT560QX 23 in. Electric...
JEC9536bdb12 knob & gromet
call the company or e-mail the manufactor and see what they have in the store.
Jan 05, 2013 | Jenn-Air 35 in. JEC9536 Electric Cooktop
2 right burners on my Jenn-Air JEC9536 cooktop stopped working.
I have a JEC9536ADB electric Jenn-Air Cooktop. We replaced the class top and now the knobs are all spliting and won't work. 2 of the main burners will only heat in the "high" position? What do I need to replace?
Sep 25, 2009 | Jenn-Air 35 in. JEC9536 Electric Cooktop
JEC9536 2 right side burners will not work
Sounds like a broken wire, but if the service people already knew what was wrong, you should be bale to type in the Make and Model number into a Google search and find more information about it.
Maybe SearsPartsDirect will have a wiring diagram that you can look at to help diagnose the problem.
Jan 23, 2009 | Jenn-Air 35 in. JEC9536ADS Electric...
Wiring diagram
The wiring diagram is usually inside of the stove folded in a corner, or get the manual at the link I have provided and call them and they will email you one.
Check here:
Eddie Rentas
Tupper Lake NY
Aug 19, 2008 | Jenn-Air 35 in. JEC9536 Electric Cooktop
Indesit PI 640
i find your problem is short of desame line that why it remained lighting,try to hang the connection to that light,try to find it one by one , the principle of the lighting here is like in the rice cooker when warm the light is yellow when cook it turn to red when you going to see it ,it is one connection only.there is a thermal plate ,when it sense extreme heat it will move that to switch off ,,then when it warm its switch on. maybe there is short to thermal plate or the thermal plate not working even extreme heat it will not shrink...try to find this plate .if my solution help you to understand the problem please rate me FIXYA...
thank you in advance Stevecarr.....
Jun 25, 2008 | Cooktops
On light flashes
i would replace the custom control kit. elemnt usually fine that contorol kit is a new circuit board that only controls that one burner
Mar 09, 2008 | Jenn-Air 35 in. JEC9536 Electric Cooktop
Inop burner on new jenn-air JEC9530 elec flat cooktop
I'm having the same problem with my jec9530. The dual burner just quit working one day. I called jennair and they sent me a replacement "custom control" for free. 6 months later it quit again. I am now considering attempting to put an infinite switch (dual), part #PS786568 in its place. It is not electronic, and it looks like it is used for the jec9536 middle back dual burner. It is only $35, even if it doesn't work like the electronic one I don't care. My wife usually only uses both burners at the same time anyway.
Sep 04, 2007 | Cooktops
Cooktop light stays on when cool
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Jenn-Air 7920P202-60 Jennair Cooktop Logo
60 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
