Question about Johnson Boating
Where is the water discharge for a 1955 10gp Johnson outboard
  • 331 Answers
You should have some water sprayt with exhaust gasses in the above water exhaust...
There is no separate water pressure indicator like on newer motors.
Posted on Sep 25, 2017
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
  • 6 Answers
SOURCE: 1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Posted on Jun 30, 2009
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Posted on Jul 25, 2009
SOURCE: Does an 85 johnson outboard motor 15 hp have
breaker/maker. set @ 020" @ the highest point but what is you're real problem. Run only champion spark plugs. We spenta dAY @ omc'S SERVICE CENTRE BEING SHOWN WHY. tHEY KNOW BEST!!
Posted on Oct 20, 2009
  • 49083 Answers
repair the water pump . rubber impellor probably took a leave
Posted on May 24, 2010
How to tune up 15 hp Johnson outboard
For minor tune-up. Remove, clean or replace spark plugs. Use Johnson recommened fuel additive and recommended fuel type. Replace lower unit grease. Spray clean carburetor. Check fuel line and filter. check water pump function.
Oct 14, 2017 | Johnson Boating
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
Please - spark gap for 4 HP twin two stroke johnson outboard
you should be using multi discharge point plugs in out board motors -not regular car engine plugs and the gap is preset on them
the reason being , with multi point discharge they are less likely to foul from oil and carbon build up
available from any good auto parts shop or marine shop
Feb 13, 2017 | Johnson Boating
When running the motor the water goes in cold but comes out hot what could my issue be It is a Johnson 25hp out board
Hi Jason:
This ended up in the washing machine section. ????
Outboard motors are cooled by the water that circulates through them. There is an impeller type pump in the lower end that takes available water and pushes it through the engine. This water collects heat from the engine, and the heated water gets discharged. usually through the centre of the propellor.
What you are describing sounds to me like the intended function of the cooling system.
Aug 04, 2015 | Boating
I have a short shaft Johnson 6hp outboard, the Jon boat I mounted it on is too deep, and motor doesn't reach water. Is there a way to lower motor? A bracket to lower motor to reach water?
outboard motor manufacturers supply a long shaft leg for just this problem
Talk with your Johnson dealer and check used outboards on e bay
Lowering the whole motor may affect the boat and floatation aspects besides making it harder to steer and start
Apr 15, 2015 | Boating
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Video on how to replace a water pump for 1993 30hp johnson
One of these videos on YouTube may work for you
Jun 25, 2014 | Boating
No water flowing out my 40hp envenrude outboard water exaust port
Plossibly clogged intakes (grim in intakes) or thermostats not opening. I would suggest pulling the lower unit and then your thermostat housing and use a water hose to back-flush it out. Also check the thermostats in boiling water to make certain opening.
May 09, 2014 | Clymer Evinrude/johnson 2-40 Hp Outboards...
Jun 25, 2009 | Boating
Boating Logo
Top Johnson Boating Experts
kj henriksen
kj henriksen
Lawrence Oravetz
Are you a Johnson Boating Expert? Answer questions, earn points and help others
