Question about Building Materials
How do I change the four digit code on my keypad outside the garage door it's an all star 6000
SOURCE: garage door keypad code. How do I reset it?
garage door keypad code... how do I reset it? I have a craftsman
Posted on Aug 10, 2008
SOURCE: Reprogram garage door keypad?
I have a Liftmaster 377LM wireless Keypad no maual
How do I reset it?
Posted on Feb 07, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Programming kepad for Sears Craftsman Garagedoor opener 1/2 hp
The only procedure I have ever followed is to press the learn button and then enter the code, and not do anything else. I think your last step of holding the button until the light goes out is clearing codes as fast as you enter them. Just stop after you enter your code and let the learn mode time out on its own. That should do it.
And don't put your head through the wall. It just causes more headaches.
Posted on Feb 21, 2009
glenmann62
  • 91 Answers
SOURCE: Chamberlain garage door opener unit-is it compatible with craftsman keypad?
Hello,Linda well this is your lucky day ,I have installed garage door openers for sears for 10 years and i can tell you that craftsman,chamberlain ,and liftmaster are all the same machine and manufactured under the liftmaster name , if you buy it from home depot it will be a chamberlain ,if you buy it at sears ,it will be a craftsman, and if you go to commercial building supplier it will be a liftmaster! now getting that out of the way even though they are all compatible ,there is one thing that stands in their way and that,s time ,For example if your chamberlain machine is 5 years old and you went to sears last week ,the chances of the frequency being the same are not good , most likely you have the wireless keypad , one way to test the sears keypad against the chamberlain machine is to locate the smart button on your machine ,this button allows for programming of remotes and keypads , to test and see exactly what im talking about take your remote and locate the smart button ,if you have three buttons on the remote press one of the buttons that are not being used on the remote ,above the smart button their will be a blinking light ,if you press your remote button you will notice the light go from a blink to a rapid flash , This is telling you that you are sending a signal for programming to the machine , well the keypad is exactly the same all you have to do is push the enter button on the keypad and have someone watch for the rapid blinking light ,if they are compatible the light will blink rapidly on the machine so all you have to do now is have someone press the smart button once on the machine your indicator light will now be a solid light you will have approx 60 seconds then to put a 4 digit code in the keypad and then press and hold down the enter button on the keypad , at this point you will notice the lightbulbs on the chamberlain machine to shut off and come back on this is to tell you that the machine accepted the code , after thats been done you can use your keypad , you can also find the owners manual to the chamberlain and follow the same instructions to programming the remote , they are identical in programing , if your keypad is not the same frequency you can also tell by looking at the frequency code on the backside of the keypad and also the chamberlain unit usually where the light bulb is will be its code
Posted on Mar 04, 2009
  • 25 Answers
SOURCE: change code on keypad for model 61WD liftmaster garage door opene
is it little buttons on the remote change the buttons on the back of your operator to the same has the ones inside your remote. or if it's a newer one you can hold the square button of the back of the operator in for 8 secs. then after that you push the button and let go and then push the button on your remote. done
Posted on Jun 11, 2009
Changing code on keypad
i have a lift master chamberlin garage door opener and need to change the code on my key pad outside, k\my problem is i have no enter button when i put my new code in on my key pad, does anyone know how to help me change my code on my keypad without the enter button....there is a pound and star button
Jan 04, 2014 | Sears Craftsman LiftMaster Chamberlain...
I am trying to enter a new code on my outside garage door opener keypad, however, it does not have an enter button, what do I do after I already erased the old code. thanks
If your keypad is hardwired do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Aug 31, 2011 | Sears Craftsman LiftMaster Chamberlain...
How do i change the code on my keypad outside the garage door on my chamberlain whisper drive? someone stole the sticker from the pad... thanks
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Nov 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do I change the code on my outside touch pad?
  1. Press the four buttons for the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
  1. Press the new 4-digit PIN you have chosen, then press ENTER. The motor unit lights will blink once when the PIN has been learned.
Test by pressing the new PIN then press ENTER. The door should move.
Sep 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
We have just bought a home. I need to change the code on the Sears Wireless Keypad for the garage door opener - this is located on the outside of the garage. What keys do I need to press to change the...
Jul 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
May 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
THE KEYPAD NO LONGER ACCEPTS MY 4-DIGIT CODE. MUST HAVE HIT THE STAR KEY OR SOMETHING & ERASED IT. HOW CAN I RESET IT? THE INSTRUCTION ON THE PAD LET YOU CHANGE IT, BUT SAYS NOTHING ABOUT RESETTING...
If your battery is good and you have followed the instructions for changing it then your keypad is bad. The instructions for changing the code is the same as resetting it.
Oct 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do I reset my keypads outside? My battery
There is no reset. You can try programming it and see if that works. If not it is probably dead.
On the rear of the motor unit you will find the smart/learn button. Press and immediately release this and then walk over to your keypad and key in your four digit code and press enter.
Oct 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have LiftMaster garage door model 41A3039 and Chamberlain wired keypad--how do I change the keypad code to open the garage door
To program the keypad, first unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Jul 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Changeing code for garage door opener
If you want to change the keyless entry code just press the green learn button on the motor, Enter a four digit code and press the enter button within 30 seconds.
Mar 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
189 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
