Question about Sewing Machines
My bobbin broke, and I can't get it out of the machine. Any advice?
    Genius:
  • Sewing Machines Master
  • 1,036 Answers
Magnets unless it's plastic. Pinch nose jewelry pliers?
Posted on Sep 07, 2017
Hello, I recently purchased a brother lx3817 sewing machine and it works but doesn’t stitch, what could be the problem
hi Desiree.
this is all i could find out.
There could be several things that could cause the machine not to pick up the bobbin thread.
  • The upper thread could be tangled.
    Remove the thread completely from the machine.
    The correct size spool cap should be used for the size of the thread spool.
    Re-thread the machine according to the directions in the manual.
One Point Advice Place a spool of thread on a spool pin.
One Point Advice Upper threading
  • Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race.
    Remove any loose threads or lint in the shuttle race.
One Point Advice Installing a bobbin into a bobbin case
  • You could be holding the needle thread too tight.
    Hold the thread lightly to keep the end from going down into the shuttle.
  • The needle could be thread incorrectly.
    Thread the needle eye from the front to the back.
  • The needle could be bent or improperly inserted.
    Install a new needle with the flat side of the needle facing the back.
or this link might help you out some more.
Why won the machine pick up the bobbin thread Brother
or this one.
brother lx3817 sewing machine doesnt stitch Google Search
Dec 06, 2017 | Brother Sewing Machines
My bobbin will not load after my needle broke.
More than likely, when the needle broke, it knocked your machine out of time, ie the needle arrives at the bobbin at the wrong time to intercept the bobbin thread. Search for sewing machine timing or take it for service.
Apr 20, 2017 | Sewing Machines
The needle broke whilst sewing using my Brother machine and now the machine will not work it appears to have jammed ?
check to make sure that all the broke needle has been removed
make sure there is no part of the broken needle in the bobbin area
try putting in a new needle & see if the machine will sew
make sure the bobbin is not damaged
it's very possible since the needle broke the machine could have
jumped time
I suggest to have the machine checked to see if the broken needle
caused any damage to the machine
Jun 09, 2012 | Brother Sewing Machines
Sewing computer bobbin problems
you may need to take it to a sewing machine shop to see about getting it fixed
Apr 25, 2012 | Sewing Machines
I broke a needle while sweng,now my needle hits my bobbin case on my 2030
it's very possible that when you broke the needle it caused the machine to go out of time & would have to be retimed at a sewing machine repair shop
Mar 12, 2012 | PfaFF Tiptronic 2030
Needle won't pick up bobbin thread
check to make sure that the needle was put into the needle holder correctly
all the way up into the needle holder--flat side of the needle to the back side of the machine
if the machine still doesn't up the bobbin thread then
it's possible that when the needle broke that it caused the machine to go out of time which means it has to be retime at a sewing machine shop
Feb 28, 2012 | Sewing Machines
Needle broke and i changed with the same number now it is not picking up the thread and does not stitch
you said the needle broke, did you check in the needle plate where the feed dogs are if there was any needle fragments
also check in the bobbin area for needle fragments, take the bobbin case & bobbin out & clean the area
Oct 21, 2010 | Singer 8280 Mechanical Sewing Machine
Bobbin case is moving out of place
I was having the same problem with my machine and finally the spring broke. I couldn't find any parts for this so my husband made me a new spring out of a coke can! LOL!! Anyway, he messed with it for a while and it kept doing it. He figured out that it was not the spring but the other piece under the spring was not pushed up far enough to keep the bobbin case in place so he took a screw driver and pushed it forward toward the bobbin case and now my bobbin case does not move!! And the machine is sewing perfect! At least for now. Anyway, it's not the spring or the thread adjusting screw!
Jun 06, 2008 | Brother CS6000i Computerized Sewing...
Janome 9000
I have a Janome 9000, was sewing and broke needle, replaced and broke another. I didn't have machine threaded, took out bobbin and would sew a little and stop saying thread broke. I took off top plate and started machine again, sew a little and stop saying thread broke. So I took out bobbin case and sewed again and stopped repeating the message. Everything looks OK, bobbin case and top plate. I guess I want to know if the timing could be off or do you think it is the computer part of the machine...Should I take it to the Sewing Machine Shop??
Apr 30, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
