Question about Honda Maxus Pressure Washer MX5222
HONDA PRESSURE WASHER WILL NOT PULL SOAP..SPRING TURNED IN FEED
NEED TO KNOW SET UP FOR THE SPRING AND BALL IN DISPENSER CONTROL..
motorhead427
  • 24 Answers
SOURCE: Pull cord is loose on my Honda 2500 Pressure
complete pull rope units are available for appx $23
Posted on May 30, 2009
  • 174 Answers
SOURCE: I have a 3000 PSI Honda pressure washer. The motor
Your nozzle could be plugged or partially plugged. Also, try running it with the high pressure hose taken off to flush the pump.
Posted on Jun 05, 2009
  • 384 Answers
SOURCE: pressure washer won't pull the from the soap dispenser
Nozzle dirty, clean out nozzle with small diameter wire. Soap dispensing only happen at nozzle low pressure setting
Posted on Jul 27, 2009
  • 615 Answers
SOURCE: I have a Honda 3500 pressure washer. The motor
You need to start the unit and let it run for few minutes to get worm, make sure the water is fully open and the unit is fully cleaned. Push on the trigger on and off for few times not letting the unit shutdown, then start increasing the fuel mixture ¼ turn and push on the trigger again and see…this could be that the unit need service or the governor springs getting week if you got one on your unit…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 20, 2009
Testimonial: "The problem was the governor spring. Thanks"
  • 57 Answers
SOURCE: Crank pull cord doesn't pull out on honda pressure
if the fuel tap has been left on it may have fuel on top of the cylinder and would not able to pull cord.
if so take the spark plug out and turn over,fuel may come out of hole.replace spark plug and try to start. if it still won't turn over,you will need to take the face plate off the motor. remove and inspect if there is any foreign objects. try to turn motor over by hand., grab on to fly wheel & turn. if it moves freely it may be the pull start it-self. try pulling the cord out. if no problem assemble and try to start.
Posted on Jan 10, 2011
Kranzle electric washer will not suck up soap
Hi, if it has a chemical injector on the machine then the pressure at the lance will have to be lowered for it to pull in soap. it works on a similar principle to how carburetors on cars pull in fuel, bernouli principle. high pressure at one side of an orifice going to low pressure at the other side which causes a negative pressure ( vacuum) which should pull in the soap. there should be a non return valve at the orifice (hole) which prevents the water back feeding into the soap container, it is quite common for this valve to get stuck, it is just a ball, spring and o ring , and the ball sticks to the o ring. if it is this system then take the soap pick up pipe off the injector and just push the ball off it's seat with a bit of wire.
If it is a high pressure soap system then that is different, but they usually work with an injector in my experience.
try taking the high pressure hose off the front off the machine and running it, if it has an injector on it it should pull in plenty off soap.
hope this helps ,
andy
Oct 12, 2013 | Electric Kranzle Professional 1600 PSI...
I have a Troy-Bilt pressure washer #020344. When I turn on the water supply and start the engine I get so much back pressure that it blows the soap dispenser hose off, and when I put hose clamps on it...
There is a check ball and spring within the soap dispenser that may be worn or lost. Easy fix however. If the parts are there and installed correctly, seat may be worn. If parts are missing or valve worn out, just plug the valve and purchase an aftermarket dispenser to install in the line between the pump and hose (not expensive and ez to do. )
good luck
Aug 05, 2011 | Honda Garden
I was able to use soap all last season, this year, i cannot get it to come thru, i know all about the low pressure deal, it seems to be clogged/ is there any way to specifically clean it where it enters...
Soap injectors are easily clogged or will not work because of design (air leaks will prevent chem from entering if chemical has to be drawn uphill) . They work with siphon action and will only work with very little pressure at the tip but good volume. If your siphon valve has the ball in place, however is missing the fine spring that holds the ball against seat (fine spring holds ball aginst intake fitting), the soap will not be sucked into stream. If ball and spring are in place, try elevating the soap container higher than the opening of the port (gravity feed may help to feed soap into system) . May be better to use an aftermarket downstream injector valve sold on ebay or many outlets. Cost about $20 but work better and are adjustable to save on soap. Search ebay for "Chemical Injector For Pressure Washers" or google "Pressure Washer Downstream Chemical Injectors" Various prices but lower price units work better than factory. Good luck
Jul 18, 2011 | Honda Black Max 2600 PSI Pressure Washer
How to make the soap dispenser work
1. Make sure that you are using the black quick connect nozzle supplied with your machine. If you have a vario nozzle (turns back and forth to adjust the spray pattern), you are going to want to pull out on the nozzle to get the machine to a low pressure setting.
2. If you still have an issue, take a paper clip, straighten it out and stick it into the hose nipple on the pump where your chemical hose is connected, push in and out a couple times to free up the ball and spring.
3. If it still doesn't work, take the chemical nipple assembly apart, make sure there is a o-ring, ball and spring. If one of these are missing you are going to have to order a chemical injector repair kit. If you have all the parts you can streach out the spring a little and put it back together which should make it work.
Oct 20, 2010 | Honda Garden
Will not draw soap solution
Follow the pipe back to the pump and you will find a ball and spring inside.This could well be stuck closed if it has been stored for some time. Oil this part and it should draw soap again.
Jun 23, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
G-3050 - area to draw soap - how to put washer/ball and spring
First off you must be using the low pressure nozzle for the chemical injector to work. It will not work on high pressure. The spring goes into the injector body first with the ball in metering valve.
Apr 17, 2010 | Karcher 2500 PSI Pressure Washer
Pressure washer won't pull the from the soap dispenser
Jul 26, 2009 | Honda Maxus Pressure Washer MX5222
Wont pull detergent
problem is that u have to use with lowest pressure i believe black tip
Jun 20, 2009 | Honda Maxus Pressure Washer MX5222
No soap comming out of my power washer
I had the same problem on the same unit. All you need to do is pull out the front tip of the gun nozzle to engage the soap dispenser. It's as simple as that, but because there is only a tiny footprint mention of this in the instructions, it turns out to be a long drawn out problem for many of us. Hope this helps.
RP
Apr 22, 2009 | McCulloch FHH18A Electric Pressure Washer
Pressure cleaner stops running
vieira1 The ball and spring go in the soap inlet valve. It closes this valve when the pump is on high pressure. Your engine may need a tune up, oil, or the idle adjusted. Choke problem. Sounds like your carb needs a real good cleaning
Jan 25, 2009 | Honda Pressure Washer PSI 3000
Honda Maxus Pressure Washer MX5222 Logo
429 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
