Question about Rain Bird Garden
Rain Bird 3500 sprinkler gets stuck in the set right hand position. Will start rotating if touched. What is causing it not to rotate?
SOURCE: Upper washer arm not rotating on KitchenAid dishwasher
Make sure that the top rack is pushed all the way back, before you close the door to switch it on. Look at how it rests in the connection in the back. You'll see what I mean. That's most likely the issue.
Posted on Feb 29, 2008
SOURCE: D80 shutter is stuck
Followed the mirror lock procedure as outlined in the manual for cleaning the sensor. That solved the problem.
Posted on Nov 13, 2008
jsrock516
  • 5911 Answers
SOURCE: washing machine starts, fills and then stops
This problem is usually attributed to a lid switch malfunction. The lid switch is mounted under the washer top casing on the right hand side. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If the lid switch is broken, the following link explains the steps necessary to replace it:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
A replacement lid switch may be purchased on line at searspartsdirect.com. Just type in your model number and look under the "Top and Cabinet" heading for item number 11. The lid strike will be listed as item 20.
If you do not wish to purchase parts on line, use the part numbers provided and go to your nearest appliance parts retailer. These are standard parts they should have in their inventory.
If you have questions, or if you require additional assistance, please let me know. I hope this helps you.
Posted on Jan 21, 2009
SOURCE: adjusting toro Super 600 PC-2.5 sprinkler heads
Try this. Should work.
www.mickman.com/irrigation/tips/toro600.html
Posted on Jun 25, 2009
  • 583 Answers
SOURCE: Impulse sprinklers stick after cloclwise rotation; no return
i wouldbet it is a pressure related problem , can you isolate them so you are only running 1 at atime? at least reduce the number of sprinklers running at the same time just to test them, drop the number by1or2 and i`m sure your problem will be fixed youdoit
Posted on Jul 27, 2009
Rainbird sprinkler manuals
The top of the head has a diagram that shows the pattern and the amount of water flow.
Sep 07, 2014 | Rainbird Rain Bird 5000S-PLPC-NP Part Cir....
Pop up rain bird gets stuck in one position, won't rotate correctly
it is dirty take apart and clean it or buy new sprinkler pretty cheap 10.00 jest buy new one install it
Aug 22, 2014 | Garden
Rainbird troubleshooting
It could be not enough water pressure, dirt on the shaft or it is worn out assuming the parts are all there. They are not very expensive you might just want to buy a new one.
Aug 10, 2014 | Rainbird Rain Bird Maxi Paw Ag-5 Inground...
Run times for 22sa sprinklers
If it is a rotating glorified streamer nozzle designed to conserve water. Double the run time. Not sure what your watering plants or lawn. if it's a lawn 20 min should work.
Mar 20, 2014 | Rainbird Rain Bird 22SA-Q 6-Inch 17 to...
A station does not come on as sceduled for rain bird
Okay, then you answered your own question. I like it! However, did you test the wire to see if it will start a different valve and vise versa?
Sep 08, 2012 | Rainbird Rain Bird 6 Station Automatic...
I have 4 zones can run them manually; but they will not come on the automatic setting. Springs are strong; timer itself keeps accurate time. I did read inside the box about a "Silver Pin"...
If zones are not advancing, then 1) Clock motor is not rotating dial > replace clock motor, 2) on-off trippers are worn down > replace trippers, 3) or the day skipper is set to skip all days and all skipper pins are pushed down, 4) or sprinkler valve is bad.
The sprinkler timer dial rotates each 24 hours. The trippers cause sprinkler head to turn on zone 1 for example. Zone 1 waters until the dial rotates to part of dial with no tripper. Without a tripper on the dial, the timer turns off circuit to sprinkler. At this point, the sprinkler valve mechanically advances to zone 2 and waits for timer to turn off again. The timer does not advance sprinkler to next zone > the sprinkler valve is designed to advance each time circuit turns off. The timer just turns on and off. When next tripper rotates around, the timer turn on the circuit and zone 2 begins to water.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
The silver pin inserted at 12midnight position is for advancing the day skipper wheel.
Open following link for parts and resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Jul 27, 2011 | Intermatic R8806P101C -...
Jul 22, 2009 | Orbit Sprinkler System Power Source...
Garden Logo
Top Rain Bird Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Rain Bird Garden Expert? Answer questions, earn points and help others
